Drivetrain M7 vs Alta intercooler, what one and why?
Old Jun 16, 2008 | 09:39 PM
  #401
big howe's Avatar
big howe
Originally Posted by El_Griton
What progressive water/meth system do you have?
Coolingmist S-HSV with the Smart-jection Upgrade, still waiting on the new IDC flash to use the Smart-jection properly
Old Jun 17, 2008 | 08:58 AM
  #402
Intense's Avatar
Intense
252whp 200trq RMW style
Originally Posted by Dr Obnxs
I used a G-Tech performance meter, and a nice long freeway onramp near my house to do the testing. Real world airflow.....
One of the other things I found was that if I let the car idle for longer than about 30 seconds after I came to rest from my "conditioning" drive, I could see a roll off in peak HP number due to heat soak.
Besides having a way to measure the performance of the car, you need some sort of OBD-II data access so that you can make sure that a) the coolant is at proper temps, and that b) the IATs aren't too high (a signature of heat soak). With carefull car conditioning, I could get data that had a standard deviation of a bit less than 2%. If I let the car idle longer and heat soak issues came up, the standard deviation would expode, and it's impossible to really measure the differences in a meaningful way.
Matt
ps, and it gets messier as well. What works best depends on octane as well! What I really learned from all the testing is that the car is much more variable in day to day use than most mods add to performance; that testing parts well is a royal pain in the butt; and that ICs really shouldn't be the start of the mod list..... They should be wayyyy down the line of things to work on.
So Matt,
Would you suggest running a series of short controlled runs instead of one large drive with varied conditions?
For instance gathering data from the following test beds individually or all in the same run:
Freeway onramp with the hammer down
Freeway cruising
Spirited canyon run
Suburb driving
I do plan on heat soaking the IC's at the same point to see how they recover.
Of course testing on the street and on the same day is going to provide challenges
-Traffic
-Lights
-Ambient temp variance
-Speed limits
...etc
Oh and I agree with everyone including you when you say that an I.C. should be further down on the list of Mods to buy.
I should be receiving the testing kit that Peter sent me today. I'll try to familiarize myself with it this week
Old Jun 17, 2008 | 09:15 AM
  #403
Guest's Avatar
Guest
Originally Posted by Intense
So Matt,
Freeway cruising
Spirited canyon run
Suburb driving
-Traffic
-Lights
-Speed limits
...etc
Pretty cool of you to test this stuff out Intense.
Old Jun 17, 2008 | 09:17 AM
  #404
JIMINNI's Avatar
JIMINNI
Welcome back rustyboy,....... no really . You do have much information to share.
Old Jun 17, 2008 | 09:22 AM
  #405
Bahamabart's Avatar
Bahamabart
So Matt,
Freeway cruising
Spirited canyon run
Suburb driving
-Traffic
-Lights
-Speed limits
...etc
While I'm the least expert here, when I did testing for DocO - I went out early one Sunday onto the turnpike - ran the car in 3rd gear 3000 rpms - waited for numbers to stabilize and recorded. Bumped up to 3rd / 4000 rpms repeat, 3rd /5000 repeated and so on in 4th gear, 5th and 6th. No clue what equipment you will be using but in my case I had my son as co-pilot recording the two thermometers and pressure gauge.
Old Jun 17, 2008 | 09:25 AM
  #406
goaljnky's Avatar
goaljnky
How old is your kid? What qualifications does he hold to participate in tests of this kind? Did he use a pen or a pencil to record the data?
Old Jun 17, 2008 | 09:44 AM
  #407
Intense's Avatar
Intense
Thanks, and just so you know. I don't have any hard feelings toward you. Your a smart guy, use it for good man
Funny how this testing turned into as big a thing as it did. I just wanted to try getting some real world numbers to help out and its like the fires of hell erupted
Old Jun 17, 2008 | 09:48 AM
  #408
Intense's Avatar
Intense
So you repeated this with the intercoolers you were testing. This provided numbers on temps and pressures in a repeatable fashion. Ok, I'll implement as much repeatable testing for each intercooler that I can.
I wanted to try and do this going all the way thru the gears and RPM ranges as well on each intercooler. ....well, at least thru third then back off
Old Jun 17, 2008 | 09:53 AM
  #409
Guest's Avatar
Guest
Old Jun 17, 2008 | 09:55 AM
  #410
Guest's Avatar
Guest
I won't be sharing any information. I'm here purely to lurk.
I've ruffled quite a few feathers (Apparently people dislike me so much that they've gone to the lengths of posting my information on various sites to try to make me look bad), and have nothing to gain or offer by being actively involved on NAM anymore.
Good luck to all!
Old Jun 17, 2008 | 11:01 AM
  #411
Revolution Mini Works's Avatar
its pretty sad what someone did to Rustyboy on those websites
its just a matter of time till we track you down and deal with you
I hope you had your fun while it lasts
Old Jun 17, 2008 | 11:29 AM
  #412
goaljnky's Avatar
goaljnky
No man, no. Leave it alone. It showed class.
Old Jun 17, 2008 | 11:33 AM
  #413
trackster's Avatar
trackster
So he's back for ten min and already you two take the thread off topic. There was some good progress being made here. Let's stay on topic PLEASE
Old Jun 17, 2008 | 11:43 AM
  #414
goaljnky's Avatar
goaljnky
I am sorry. Could you please summarize the progress so far?
Old Jun 17, 2008 | 11:45 AM
  #415
Intense's Avatar
Intense
Sorry to hear that someone felt it necessary to slander Nick across multiple sites
Not like he is a terrorist.... sheesh people
Old Jun 17, 2008 | 12:53 PM
  #416
Intense's Avatar
Intense
All the gear that Peter at M7 sent me just arrived!
I'll be talking with M7 a little later today to familiarize myself with how everything works
Old Jun 17, 2008 | 01:04 PM
  #417
ClintTheMiniOwner's Avatar
ClintTheMiniOwner
Intense, that would be cool if you made some sort of youtube video out of this somehow.
It would be cool just to hear it and check out your car as well.
Old Jun 17, 2008 | 01:18 PM
  #418
Intense's Avatar
Intense
Funny you posted this! I was just talking to my friend about how we are going to set up a couple cameras in my car.
....nothing like showing the community how big O noobs we are in real life eh?
For real tho, were going to try to video what we can.
Old Jun 17, 2008 | 01:34 PM
  #419
Guest's Avatar
Guest
Slander would be an understatement.
It's certainly creative though. Managed to track the IP and domain routing of the e-mail sent to Jan and myself, as well as a few website posts (I actually know the city of origin). Working the appropriate channels.
Post some pics of the setup when you get a chance Intense!
Old Jun 22, 2008 | 10:22 PM
  #420
ClintTheMiniOwner
I noticed my intercooler was cold as ice on the dyno this weekend during the tune. We used a squirl cage fan and sprayed water around the IC before the dyno pulls. (standard procedure) On the drive home it sure felt like the DFIC was working better than ever on the street. It got alot of attention in the parking lot too
Old Jun 23, 2008 | 07:19 AM
  #421
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Sounds like a great argument for the use of an IC Sprayer, like that which comes with all of the ALTA TMIC upgrades and the OEM TMIC ALTA Diverter!
Old Jun 23, 2008 | 09:46 AM
  #422
Intense's Avatar
Intense
Here's an update for you. I wasn't able to get the testing done this weekend like I hoped.
I helped a club member install coilovers, sway bar, control arms, 17% pully, and a short shifter all with a cold.
Felt like crap Sun. went to the doc today and found out I have a cold and a ear infection to go with it. Anyway, the equipment M7 sent me appears to be temp reading equipment. I'm going to call Nardo and see if it reads pressures as well.
Anyway, I hope to get it done next weekend.
What were your final numbers Clint?
EDIT: Nevermind! I see them in your sig. excellent numbers =)
Old Jun 23, 2008 | 10:56 AM
  #423
Intense's Avatar
Intense
Adam,
I have a question for you. I have noticed a issue with both of your intercoolers the top mount and the flow thru. They both sit directly on top of the of the stock intercooler mount points on the intake manifold. Have you seen any failure from this? Have you had any actually wear thru? The one I had, and others I've seen actually have quite a bit of wear from engine vibration.
I am also very interested in adding a sprayer on my M7 DFIC. Does your sprayer use an existing washer pump and tank on the car? I have a convertible so I am looking for something that can be run independent of the rear wiper set up.
Rob
Old Jun 23, 2008 | 02:46 PM
  #424
Guest's Avatar
Guest
Adam,
Rob
I'm pretty sure their sprayer system does use the OEM tank, but I'm not sure if it will fit correctly on the M7 IC.
Old Jun 23, 2008 | 02:53 PM
  #425
Intense's Avatar
Intense
What I'm looking for is a independent pump that I could switch on and off manually. Might need to do some "hardware store" modifications eh? I just thought some of the Alta parts might work like the sprayer nozzle etc.
I'm also curious to know if they sell independent pumps, hoses nozzles etc.
