Drivetrain Revolution Mini Works Camshaft..... taking orders
Old May 20, 2008 | 07:00 AM
  #51
AliceCooperWA's Avatar
AliceCooperWA
Originally Posted by Revolution Mini Works
Class sizing, you have to run a restricter plate if you are over 1800cc
That just makes me want to slap someone...why wouldn't it just put you in a different class like other mods?
Well now that you have let the cat out of the bag, we can start hounding you for info
I'm guessing you are still developing, so there are no actual numbers, but what kind of peak hp and tq for NA are we talking? just a little hint please.
What would be the approximate difference in hp/tq in NA between the 1.8 and the 2.0. If I had the option of getting 200whp NA with a drop in motor, I might have to start pimping out my cats.
Old May 20, 2008 | 07:59 AM
  #52
MINIFVR's Avatar
MINIFVR
Originally Posted by mini_racer
Jan;
Concerning injectors, should one upgrade to some other size if only a cam and pulley upgrade for example, and then only get 440s if Cam, head, pulley, and exhaust ?
Or is it better to just get 440 regardless of the upgrades, and then forget about it?
This is what I am planning to do a year or two down the road. Let me know how it turns out! (the cam/pulley/injector combo)
Old May 20, 2008 | 08:52 AM
  #53
Revolution Mini Works's Avatar
we don't know yet, but you will find out in the near future
Old May 20, 2008 | 12:35 PM
  #54
AliceCooperWA
Damn you...I want instant gratification
Old May 20, 2008 | 05:51 PM
  #55
minimarks's Avatar
minimarks
How would the cam do with the JCW flash until I could get to a Jan tune?
Old May 20, 2008 | 06:38 PM
  #56
mistro's Avatar
mistro
could someone discribe what lope is and what it feels like?
Old May 20, 2008 | 06:44 PM
  #57
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
Just rough choky idle, i love the sound sometimes.
http://www.youtube.com/watch?v=0IRLVR9lMmA
Old May 20, 2008 | 08:32 PM
  #58
El_Griton's Avatar
El_Griton
oh that video makes me miss my 5.0.
Old May 20, 2008 | 09:45 PM
  #59
Guest's Avatar
Guest
That's a bit extreme. It's nowhere near that crazy in the MINI. Sounds stock with the occasional idle search (blipping up and down 120-150 rpm's). The RMW cam is barely noticeable (occasional 40-60 rpm dips).
Old May 21, 2008 | 12:10 AM
  #60
El_Griton's Avatar
El_Griton
I pm'ed about your CAM. Hope you can shed some light on my misfortune.......
Old May 21, 2008 | 06:28 AM
  #61
PM done
Old Jun 6, 2008 | 07:36 PM
  #62
El_Griton's Avatar
El_Griton
PM done
Pm'ed again! time to make some real power!
Old Jun 6, 2008 | 08:35 PM
  #63
you have mail
Old Jun 6, 2008 | 09:29 PM
  #64
El_Griton's Avatar
El_Griton
its like getting a baby, only it doesnt sh** all over the place! NICE!
Old Jun 6, 2008 | 10:17 PM
  #65
dirty diapers are a drag
Old Jul 3, 2008 | 04:52 AM
  #66
Raiyu's Avatar
Raiyu
Is it extremely unsafe to run the cam/pulley/header without a tune to drive to be tuned? I am in PA and heard there is a tune in Mass(270m away) think I will do any damage if I drive up there?
Old Jul 3, 2008 | 05:55 AM
  #67
BlimeyCabrio's Avatar
BlimeyCabrio
Does anyone have before/after dyno charts for the cam only (or maybe cam+injectors)? I'd love to see:
Stock cam dyno
RMW cam dyno pre-tune
RMW cam dyno post-tune
Just to get a better understanding of what the torque curve change really looks like for this setup, without the head...
Old Jul 3, 2008 | 06:03 AM
  #68
searocko's Avatar
searocko
No issues here. I had the cam and header on for about a week and 200 miles before the tune without any issues. I also had 380cc injectors and 15% pulley.
You will definitely feel the difference once Jan ties it all together with the tune!
Old Jul 3, 2008 | 06:45 AM
  #69
it will run fine on the stock map
Old Jul 3, 2008 | 06:51 AM
  #70
Stock cam dyno
here you go........
here is a dyno of 2 GPs
1 with header/cam and the other bone stock but tuned to the gills
Old Jul 3, 2008 | 07:01 AM
  #71
BlimeyCabrio
that ~5-15lb/ft of torque is luscious...
But I gotta think the header had a lot to do with that?
Of course, I'm just fartin into the wind.... because if everything pans out I'm gonna have the cam and tune in two weeks anyway, and then I'll know.
I'm hoping to have some interesting new dyno plots when all is done:
1) Baseline: 15%, Intake, one-ball (welded), MTH tune
2) Above, plus RMW cam and 380's, with same tune
3) Same as (2), with Jan-tune.
So should be able to answer the question "what does an RMW cam, JCW injectors and RMW tune yield over the MTH tune on a 15% car?". It's an auto... so not going to be setting any HP records, and don't really care about that... torque is king for me...
Old Jul 3, 2008 | 07:01 PM
  #72
El_Griton's Avatar
El_Griton
to tell you the truth, I really dont even see that.........I was very surprised to see an almost stock idle after the cam. I guess I'll just have to wait till the tune for some #'s but I think they will be good.
Old Jul 18, 2008 | 02:39 PM
  #73
PlayPlay's Avatar
PlayPlay
I have 2006 MCS with factory JCW....So, if i just get a cam and stick with JCW pulley, JCW header, JCW exhaust, what kind of WHP gain would I be able to achieve with RMW tune?
What if I then added just the RMW header but kept the rest of the exhaust as OEM JCW?
Thanks for any input...
Old Aug 21, 2008 | 07:22 PM
  #74
oxtox's Avatar
oxtox
it was the cam... you could have gotten the same a/fs with stock injectors as what your tune showed
if you do everything but the head, then stick with 380cc as you will get a better tune
440cc are when you are really needing the injector up top to keep it cool
i have the cam with jcw cai, 15% pulley and milltek exhaust, and stock injectors. do i need to curb rpm's/stay away from rev limiter at the track untill i get 380cc injectors and tune? knowing that i should be shifting before 6000 would be helpful
Old Aug 21, 2008 | 08:43 PM
  #75
you will be fine as long as your injectors are clean with the stock tune
