Drivetrain Revolution Mini Works Camshaft..... taking orders
Old May 13, 2008 | 09:02 PM
  #26
Revolution Mini Works's Avatar
Originally Posted by Fracky
First off, let me say that the cam + injectors was one of major noticeable performance upgrades I've done. I do have a "flicker" of lope, but nothing that bothers me. I did notice a bit of negative mpg, but that's mostly due to me putting my foot in it & laughing at the wicked acceleration. My tune put me back at net zero on the mpg issue. I would love to have thrown a head on the car while I was at it, but my car's taking the "show car" + "Sunday drive" route & won't see the track, so my money's going elsewhere on the car.
it was the cam... you could have gotten the same a/fs with stock injectors as what your tune showed
Old May 13, 2008 | 09:32 PM
  #27
CFMINI's Avatar
CFMINI
Jan -
How will this new cam work on my car that has your head and a Schrick cam now?
Old May 13, 2008 | 09:33 PM
  #28
Guest's Avatar
Guest
Originally Posted by CFMINI
Jan -
Danny gained torque across the rev-range by swapping out his Schrick for an RMW.
Old May 13, 2008 | 09:36 PM
  #29
Jan -
Craig,
it will increase the low end torque where you need it most
will probably need a tweak on the tune though
so how do you like the car?
Old May 13, 2008 | 09:45 PM
  #30
CFMINI's Avatar
CFMINI
Jan -
I really like the "ex" Spider X car so far. So next we will do the 440cc injectors, your new cam, and a new tune? A fatter torque curve is always good. Can you (or Danny) get this done before my track day on June 1st at Big Willow with BMWCCA?
Old May 13, 2008 | 09:49 PM
  #31
mini_racer's Avatar
mini_racer
Originally Posted by Revolution Mini Works
https://www.northamericanmotoring.co...d.php?t=130846
here is some reading for you, gives you an idea of what it does
Nice read, thanks.
OK, 83whp was an impressive gain even for those listed mods, so the combo sum is greater than the individual components, awesome.
Old May 13, 2008 | 09:50 PM
  #32
Jan -
Yes,
I have more cams being shipped that should be here later next week. Give me a call tomorrow to talk about a few things that might help out with your track day. I have injectors in stock
Old May 13, 2008 | 09:54 PM
  #33
Originally Posted by mini_racer
Nice read, thanks.
thats what properly designed parts working together can do
this is exactly why we run a full system approach. The cars that do the best are the ones who have the least mods on them when we start
we have found that many of the parts made just make the car run worse than one that has few parts on it. Look at the dyno days I have done, the proof is in the pudding. These are watched by groups of people seeing exactly what works and doesn't.
I find these to be educational experiences for those wanting to mod their cars. When people ride in one of our cars they can see how the car is supposed to feel
Old May 13, 2008 | 10:00 PM
  #34
Guest's Avatar
Guest
Jan -
The 440's and cam only take a few hours to put on. Shouldn't be an issue. Give Danny a call and check his availability.
I'll be at the track on the 30th and the 1st. See you there Craig!
  #35
mini_racer's Avatar
mini_racer
Jan;
Concerning injectors, should one upgrade to some other size if only a cam and pulley upgrade for example, and then only get 440s if Cam, head, pulley, and exhaust ?
Or is it better to just get 440 regardless of the upgrades, and then forget about it?
Old May 13, 2008 | 10:01 PM
  #36
Jan;
if you do everything but the head, then stick with 380cc as you will get a better tune
440cc are when you are really needing the injector up top to keep it cool
Old May 13, 2008 | 10:10 PM
  #37
Luys's Avatar
Luys
Jan;
What is exactly RMW Adjustable Cam Gear ?
Thanks.
Old May 13, 2008 | 10:11 PM
  #38
Originally Posted by Luys
Jan;
Thanks.
it's exactly what it says.... its adjustable so you can change the cam timing
Old May 13, 2008 | 10:16 PM
  #39
Luys's Avatar
Luys
Is it important to install it in my car JCW ?
Old May 13, 2008 | 10:19 PM
  #40
Is it important too install it on my with the car ?
depends upon what you are trying to do with your car
you should check your cam when you install it to make sure it is degreed in
properly
is it necessary in your application? probably not
racers do this for every last possible hp out of their car
Old May 14, 2008 | 05:48 AM
  #41
Maxicooper's Avatar
Maxicooper
Adj. cam gear seems to have more benefit (obviously, more difficult to tune) on DOHC engine. Adjusting the cam gear will change/improve the character of the torque curve to suit your need.
On SOHC, most benefit is to be able to move the useable torque curve up or down the rev band, make most benefit of the powerband to fit your need.
Actually, We can do more with the ACG than the above (more complicate as well), just give you the rough idea.
Just my 2 cents.
Old May 18, 2008 | 08:39 AM
  #42
Luys's Avatar
Luys
PM sent
Old May 18, 2008 | 09:16 AM
  #43
justintime's Avatar
justintime
what will this cam do for a justacooper
Old May 18, 2008 | 09:21 AM
  #44
the cam in our cars are the same (stock cam)
this was designed by BMW to save money so they are a compromise cam
I doubt our cam will work well on a NA car. We are building a 1.8L stroker 13:1 racing cooper engine and it will have its own cam and custom exhaust manifold
Old May 18, 2008 | 09:38 AM
  #45
justintime's Avatar
justintime
ooo, that sounds tasty you should -cough- make itbs for the cooper -cough-
Old May 18, 2008 | 10:31 PM
  #46
AliceCooperWA's Avatar
AliceCooperWA
Out of curiosity, why not adapt the 2.0 to NA? Is there a reason you are going with the 1.8 stroker instead of the 2.0 stroker?
Old May 18, 2008 | 11:24 PM
  #47
Guest's Avatar
Guest
Cost more than likely...
Old May 19, 2008 | 06:52 AM
  #48
Class sizing, you have to run a restricter plate if you are over 1800cc
Old May 19, 2008 | 07:57 AM
  #49
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Man that sucks
Old May 19, 2008 | 12:20 PM
  #50
RedSkunk's Avatar
RedSkunk
What will the stroker kit be, 2.0? Classing on the street being much more lenient...
