Drivetrain Noob Brake Question
Old Feb 23, 2008 | 04:53 PM
PlayPlay's Avatar
PlayPlay
Noob Brake Question
Hello NAMMers...I am planning on upgrading my rotors, brake lines, and brake fluid sometime in the next few months. I am just lacking any kind of knowledge regarding brakes, so I have a few basic questions:
1) If I keep my JCW brake kit, do I have to continue to use rotors the same size as my current ones? Or can they be larger in diameter?
2) If I keep my JCW brake it, can anyone recommend a top of the line rotor to get? If not, I will just get the JCW slotted/drilled rotors. I do prefer a little bling and do not do enough stressful braking to avoid getting drilled rotors.
3) How come Mini doesn't make drilled and slotted JCW rotors for the back? Any other manufacturers do that? Or is it not worth it?
4) If I did not change the rotors, but just changed the brakelines to stainless steel (more for show) and switched to ATE Super Blue Racing fluid, what differences would I notice if anything?
5) How many hours would changing out rotors, brake lines, and fluid take at a shop?
Thanks!
Old Feb 23, 2008 | 05:01 PM
littlehandegan's Avatar
littlehandegan
Coordinator :: Low Country MINIs
Thanks!
Why dont you like the brake setup you have now? Also do you track alot? If not i would think the current setup you have is good for bling and good stopping. With the money you save think about the stuff you ould get to make if go faster or handle better
Jack
Old Feb 23, 2008 | 05:21 PM
PGT's Avatar
PGT
change the brakelines for show? can you even see them?
we put Stoptechs on in 2 hours, including bleeding. There's no reason a shop should charge you more than two hours for pads, rotors lines and bleeding the system.
Unless you are tracking the car, none of the things you mention matter.
as for options for the JCW kit, there aren't many. Ken @ K&S is the man to talk to (brakeguru on NAM). He was working on some Hawk pads for the JCW kit....HP+. Great bite but at the expense of dust. Also.....TCE....both Todd or Ken know their ****
there's no benefit to drilled rotors except looks. the 'upgrade' is to a 2pc rotor which is a) lighter and b) able to handle more heat (track work etc). dba is a good choice here, but no JCW fitment that I'm aware of yet. Be prepared to pay...$800+ for 2pc rotor pairs.
Old Feb 23, 2008 | 05:24 PM
PlayPlay's Avatar
PlayPlay
Jack
Well, the JCW brakes are okay, and I don't think I'll ever do a real BBK like Brembo or Stoptech, etc. I mainly just like the look of the drilled and slotted rotors behind my rims. Since I will be removing everything to do the rotors, I might as well do the fluid and the lines.
I've already blown alot of money, on suspension and ECU so, brakes are the next thing. Maybe in the long term I will do more with exhaust, but not right now.
Old Feb 23, 2008 | 05:26 PM
PGT's Avatar
PGT
Well, the JCW brakes are okay. I mainly just like the look of the drilled and slotted rotors. Since I will be removing everything to do the rotors, I might as well do the fluid and the lines.
swapping rotors is a 15 minute affair....the lines and fluid aren't involved
I have more power than you and the JCW brakes suit me just fine. Don't fix what ain't broke!!
Old Feb 23, 2008 | 08:21 PM
reboopie's Avatar
reboopie
i have the r56 witch has the old jcw brakes on it. i find that they worked ok but when i put carbotech pads (auto x compound) on them it real made them work lods better. as for the the lines/fluid it does not take long it should not take over an hour for a shade tree guy.
Old Feb 23, 2008 | 08:40 PM
PGT's Avatar
PGT
the R56 uses different pads than the JCW kit for the R53
Old Feb 24, 2008 | 01:01 AM
Luys's Avatar
Luys
Thanks!
1) You can change the JCW rotor by JCW drilled and slotted (it's my plan) from http://www.trademotion.com/partlocator/index.cfm?action=accessoryPart5&siteid=214217&cata logid=3751&categoryID=75816 .
2) There is Brembo JCW rotor (but it's hard to find).
3) For the back rotor brake it dosen't worth.
Old Feb 24, 2008 | 08:06 AM
reboopie's Avatar
reboopie
um the point is, is that jcw brakes are a good set and instaling a set of carbotech would make them far better to point that he wold not need to go to the trouble of new rotors.
Old Feb 24, 2008 | 03:35 PM
PlayPlay's Avatar
PlayPlay
thanks for the input guys....the time info is good to know so I don't get raped by any installers. (no pot-stirring comments here PGT LOL!)
Um....PGT, have you changed anything else with your JCW brakes? Just fluids perhaps? I'll prol just shell out the couple hundred bucks just to get the rotor bling even though I might only track/auto-x it a few times a year.
Anybody know how much the Brembo rotors fit for JCW cost?
Oh and thanks for the info on the Carbotech...know of a good place to get those?
Old Feb 24, 2008 | 03:52 PM
daemon2's Avatar
daemon2
Check with Todd at TCE brakes, he may be able to hook you up, front and rear at a good price.
Old Feb 24, 2008 | 04:49 PM
reboopie's Avatar
reboopie
Old Feb 24, 2008 | 04:57 PM
reboopie's Avatar
reboopie
call them and talk to jeanne puskar she can help you with what you need, phone number is 877-899-5024 web is ctbrakes.com. tell them you learned about them on nam.
i would recommend the auto x pad because they work well for street as well as the auto x/track day
W0TM8
Dec 19, 2019 07:50 AM
STR3T
May 23, 2016 03:27 AM
thebordella
Aug 31, 2015 01:37 PM
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
nomar116
Aug 10, 2015 11:24 PM
