Drivetrain Belt Size
Old Feb 23, 2008 | 03:23 PM
resipsamcs's Avatar
resipsamcs
Belt Size
Looking for opinions, perhaps even consensus, on the current wisdom concerning the appropriate belt size to run on my set-up: Alta 15% reduction sc pulley combined with Alta 2% oversize crank pulley. I currently run stock belt size.
Any feedback will be appreciated. Looking for quick, up to date information, I have already searched and read what is out there, and I am a bit confused as to whether stock length or the shorter NAPA belt would be best.
Len
Old Feb 23, 2008 | 05:05 PM
verveAbsolut's Avatar
verveAbsolut
Len
How much extra circumference (over the stock pulley) is there on your 2%? Take that number and multiply it by the percentage that the belt wraps around said pulley. Now add that to roughly -.8in. With that figure in hand, the belt you are searching for should be that much reduced from the stock belt size.
- Matt
Old Feb 23, 2008 | 06:22 PM
Modshack's Avatar
Modshack
Here ya go..
Old Feb 24, 2008 | 02:25 PM
Big-Daddy-Blue's Avatar
Big-Daddy-Blue
Originally Posted by Modshack
Here ya go..
I have posted this chart before and was told that the chart has been proven that some of those sizes oare wrong.
But I am running the 060535 for my 19% pulley.
Old Feb 24, 2008 | 02:38 PM
Modshack's Avatar
Modshack
I guess someone should tell Alta then since that's where this is coming from...
http://www.altaminiperformance.com/p...Pulleys-15-19-
Old Feb 24, 2008 | 02:41 PM
verveAbsolut
You may have been told some of the sizes are wrong only in regards to the recommendation of the stock belt size for the first 15% reduction pulley...it has been shown to not be tight enough.
I do not know about the relation in regards to an altered crank pulley size as well.
- Matt
Old Feb 25, 2008 | 01:27 PM
apexer's Avatar
apexer
I have the same set-up and I'm using the stock JCW belt which is a tad smaller than the stock S belt.
elverado
Jan 18, 2022 02:51 AM
got_mini?
Oct 18, 2015 08:39 AM
lotiman
Sep 16, 2015 06:47 PM
hong
Sep 13, 2015 06:41 PM
Emnotek
Sep 11, 2015 04:16 PM
