Drivetrain b&m short shifter
Old Jan 30, 2008 | 11:09 AM
freeskier's Avatar
freeskier
b&m short shifter
im in the market for a short throw shifter and found the B&M model on ebay for a reasonable price. does th B&M reduce the length of the throws enough to warrennt the purchase? is the shifter stick adjustable? thanks
Old Jan 30, 2008 | 12:10 PM
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
I have a B&M on my 03 MCS. The change in the throw length is significant. Last time I drove an 04 with a stock shifter, it took some getting used to.
B&M shifters are not adjustable.
Old Jan 30, 2008 | 01:04 PM
SumWon's Avatar
SumWon
I have had mine in for several years and love it.
Old Jan 30, 2008 | 01:54 PM
002's Avatar
002
I have the 03 version and there is definitely a difference. Just right in my opinion. I recently replaced my 03 shifter with an 05 after I realized that mini sold me the wrong shift cables. I was holding onto them for some time before the install so it was too late to return them. It was cheaper to replace the shifter than get another set of cables. So now I am back to stock.
So after having it and going back to stock, I can say that the B&M is much more pleasurable/sporty to drive with little to no increased shifting effort.
If you have the earlier shift box and want mine, you can have it for a reasonable price. I was about to post it on ebay to get cash towards a new one anyhow.
Old Jan 30, 2008 | 02:04 PM
pepegrande008's Avatar
pepegrande008
Just got mine installed a week ago. Love it and i bought mine off ebay from some company in Florida that had an overstock problem. Cant remember the name though. Anyways i love mine.
Old Jan 30, 2008 | 03:12 PM
pepegrande008
here is the ebay link
http://cgi.ebay.com/ebaymotors/B-M-S...spagenameZWDVW
Old Jan 30, 2008 | 06:04 PM
freeskier's Avatar
freeskier
ok sounds like a great mod for the $$ and as soon as i gt a little more cash i will be installing it. any experience with the install?
Old Jan 30, 2008 | 08:49 PM
heyitzsushiboi's Avatar
heyitzsushiboi
is there a difference between the $40 b&m shifters and the $140 b&m shifters? ebay has them for ridiculously low prices as opposed to the reputable vendors... porque?
Old Jan 31, 2008 | 02:36 AM
ChiliRedS's Avatar
ChiliRedS
I picked mine up off of ebay for $50 and it was the real deal still sealed in the original packaging. I love it.
Old Jan 31, 2008 | 09:14 AM
pepegrande008
the install is alot harder than what the instructions imply. I would suggest professional installation.
Old Jan 31, 2008 | 10:26 AM
GT_GREG's Avatar
GT_GREG
ohhhh its not that hard!
just take some time thats all...
Old Jan 31, 2008 | 11:40 AM
pepegrande008
well mine was difficult, i hav a 1st gen 02 s and it didnt quite fit like it was supposed too. also, it seems like that if i had used the aluminum mounts for the shift box, that the plastic of the box would crack. So i didnt replace them if anyone wants to take them off my hands. Just seems pointless b/c the hardmounts would allow you to shift harder, but i think that will break my shift box
Old Feb 1, 2008 | 09:03 AM
SumWon's Avatar
SumWon
The install can be tricky, I have done three of them, but it is doable. I personally think the hardest part is getting the shifter cables disconnected from the original shifter. I did one install on floor jacks and two on lifts. Lifts make life MUCH easier. If you have had your MINI in the salt, be prepared to have issues with the exhaust and other parts from corrosion. Soak things with PB Blaster or the like and let it sit for a bit. Take your time and it can be done.
Old Feb 12, 2008 | 05:29 PM
//MZero's Avatar
//MZero
quick question, this one:
http://cgi.ebay.com/ebaymotors/B-M-4...spagenameZWDVW
will that work with my 05? It states 02-03, but I don't see any for sale for the 05's?
Old Feb 12, 2008 | 05:33 PM
//MZero's Avatar
//MZero
Nevermind, I went to B&M's site and can cleary see that 04+ is different
Old Feb 12, 2008 | 05:56 PM
ixotuckeroxi's Avatar
ixotuckeroxi
question should be, why are the 02-04 versions so cheap and the 05+ so expensive. they are 3-5x's the amount..
Old Feb 12, 2008 | 06:30 PM
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
The 05+ model incorporates a metal shift housing cover that the previous generation did not. In changing the housing cover they also included bushings that are substantially longer than the ones included in the previous model. They are longer to provide the proper spacing for the end of the shaft that connects to the shift cables.
A quick check on the google product search shows that both models are going for approximately the same price.
Old Feb 12, 2008 | 06:32 PM
//MZero's Avatar
//MZero
The new versions just run at the normal price. And after doing some searching...they also appearently have problems if you get any sort of resonated exhaust.
I guess I wont be getting B&M, I may look into Craven Speed instead.
Old Apr 9, 2008 | 07:49 PM
discodan's Avatar
discodan
how much shorter is the shift **** height after install? about to get this installed and want to get a new shift boot to complement it from Redline Goods. i see they now offer shorter boots to go with short shifters. so was just wondering how much shorter i should order it. thanks in advance.
Old Apr 9, 2008 | 08:23 PM
Fatherdeth's Avatar
Fatherdeth
It's really close to stock height. With the right ****, it could appear shorter.
Old Apr 10, 2008 | 10:29 AM
Rich.Wolfson's Avatar
Rich.Wolfson
A bit over an inch. I am interested in your opinion after the install as I have one in the box ready to go but am hesitating as I don't want to have to take it out if I don't like it.
Rich
Old Apr 11, 2008 | 06:11 AM
THE ITCH's Avatar
THE ITCH
For those of you who are interested in the shift height of the B&M shifters their is a difference in model years. I am not exactly sure when the change happen but I suspect it was in the '05 and newer. The newer generation is the same height as stock and the older generation is shorter.
Steve
Old Apr 11, 2008 | 07:23 AM
SumWon's Avatar
SumWon
The change happened during the '04 production model. I helped install an '04 and it required the '05 shifter. If you contact B&M or any of the resellers they should be able to verify for you based on your build date.
02miniSguy
Nov 17, 2015 10:29 PM
vetsvette
Oct 1, 2015 12:59 PM
ToroPerro
Oct 1, 2015 12:54 PM
MINI Stupor
Oct 1, 2015 11:36 AM
Samhillrocks
Sep 29, 2015 12:55 PM
