Drivetrain Blew motor up!!! AGAIN!!!
Old Jan 24, 2008 | 03:02 PM
  #101
humcmcel's Avatar
humcmcel
Originally Posted by MarioKart
...merging on to the 101 freeway in 2nd gear at 7100rpm and then it locked out and the belt moved over a 1/4 inch...
I'm bummed
Bummed over a blown engine I understand, but getting to 7100 RPM on a street car that redlines at 6700 rpms I'm having a little trouble with. Without some substantial mods these engines aren't designed for that high a rotation and though they can take it from time to time, I haven't seen one that does much but spin over 5500 rpms. Aim for the torque peak and shift. Leave the higher rpms for the motorcycles.
Old Jan 24, 2008 | 03:14 PM
  #102
minimusprime's Avatar
minimusprime
lol at this post.
Old Jan 24, 2008 | 03:22 PM
  #103
verveAbsolut's Avatar
verveAbsolut
Evidently you're not familiar with transmissions and gearing advantages. By and large I would agree with your statements for street use though.
- Matt
Old Jan 24, 2008 | 03:23 PM
  #104
bluesmini's Avatar
bluesmini
I agree herbie, I know of a racer that made and intake that is actually is divided. That air coming from one end isn't a good design. It works well. she went from twin charging to just turbo. Something silly like 40psi for a while. kept lifting the head off the block. I think that car is for sale now. she went for an open wheels Mazda racer. I also have one of her old sets of wheels, header and exhaust.
Old Jan 24, 2008 | 04:31 PM
  #105
PGT's Avatar
PGT
Originally Posted by minimusprime
lol at this post.
ZOMG! What has Honda done, making us think we should actually allow 9k redlines on the street
Old Jan 24, 2008 | 04:42 PM
  #106
Tüls's Avatar
Tüls
Turbius Maximus
what's wrong with 9k on the street?
Old Jan 24, 2008 | 04:50 PM
  #107
Tüls's Avatar
Tüls
Turbius Maximus
lol at this post.
I never shift before 7... ussually 7500... and when I am in it to win it 8k... i did hit 9400 once.... buuuut I try not to do that too often... as I am still using a stock head and valve train... sounded great though...
who says these engines aren't designed for that? Just because the manufacturer doesnt do that doesnt mean they cant. Their guidelines for what they are trying to archive is totally different.
actually never mind... no one rev yer mini past stock! it's daaaangerous!
Old Jan 24, 2008 | 05:09 PM
  #108
PGT's Avatar
PGT
once again sir, I say to you....UNPOSSIBLE!!
Old Jan 24, 2008 | 09:27 PM
  #109
UKCoopeR's Avatar
UKCoopeR
me = jealous, i have your car as my desktop background, hope that is okay
Old Jan 24, 2008 | 09:33 PM
  #110
verveAbsolut
Jesus christ...9400.
I love it.
I've always been a fan of oversquared, big-bore tiny-stroke setups.
- Matt
Old Jan 25, 2008 | 09:13 AM
  #111
Tüls's Avatar
Tüls
Turbius Maximus
of course that's ok.... it's an honor
Originally Posted by verveAbsolut
9400.
I love it.
- Matt
yeah me too!
Old Jan 25, 2008 | 10:37 AM
  #112
nabeshin's Avatar
nabeshin
Functioning Lunatic
Any new updates, mario?
tüls, next time you hit 9400 rpm, get a sound recording for us.
Old Jan 25, 2008 | 02:27 PM
  #113
humcmcel's Avatar
humcmcel
- Matt
Maybe I need to be enlightened, but any engine has a finite power band. When you exceed those limits (especially the red line) on a regular basis, you can expect it to fail prematurely regardless of what gearing you use to get the power to the road. Those who wish to run above those limits will keep parts suppliers and repair shops very happy.
Old Jan 25, 2008 | 03:53 PM
  #114
MarioKart's Avatar
MarioKart
Vendor
I spoke to Danny today and all the parts are being looked at. I told him I just want a new crank with bearings. To me its not worth saving $200 for a rebuilt crank with over sized bearings. I will be getting new gaskets, oil pump and some small other stuff but it shouldn't be too bad. It might be time to trade in my bad luck black Mini.
Old Jan 25, 2008 | 04:59 PM
  #115
verveAbsolut
First, you said 5500 RPM. This is not even approaching the limits...you're only at ~80% output.
Second, and almost without exception, you want to stay in a lower gear as long as possible. To use arbitrary numbers as an example, say you have an engine that puts out 150lb/ft at 4000RPM (peak torque), and 100lb/ft at 6000RPM (redline), and have a transmission with 4:1 1st gear, and 2.5:1 second gear (excluding final drive).
In 1st gear:
- @ 4000RPM : 600lb/ft
- @ 6000RPM : 400lb/ft
In 2nd gear:
- @ 4000RPM : 375lb/ft
- @ 6000RPM : 250lb/ft
That's all at the wheels. As you can see, it makes sense to use your first gear for as long as possible, even though you're past your "power curve." This is true for nearly every car on the road...no car I am familiar with has such a steep dropoff that it would make acceleration sense to switch to the next gear...most cars plateau or only slightly dip. F1 cars have incredibly low torque figures, but they rev so high and have a transmission that can take advantage of it (if I recall correctly, they only have around 200 lb/ft at the crank).
Also, this is a very simple way of looking at it. I'll have to see if I can dig up this great website that does a much better job of explaining it and putting it all into context...gear ratios, horsepower, torque, etc.
- Matt
- Edit -
Think this was the website: http://www.allpar.com/eek/hp-vs-torque.html
To use engine torque to understand how your car performs, you MUST include the effects of the transmission.
Old Jan 25, 2008 | 05:20 PM
  #116
Longboard Mini's Avatar
Longboard Mini
How about over 200ft/lb at 6800 .
Shift at 5500 .
Longboard
Old Jan 25, 2008 | 05:35 PM
  #117
Dr Obnxs's Avatar
Dr Obnxs
Couple points...
wear goes about with the square of the speed. But don't fool yourself into thinking that parts don't wear if you drive gently. they do, just less quickly.
Second, the stuff about when to shift is good for full throttle acceleration, and what you're looking for is called a thrust curve. This one is for the 02 MC 5 speed.
It just depends on the torque curve for the engine and the gear ratios (and something called the effective mass) to plot the crossover points. For the 5 speed MC, you DO run to red-line in first, for the 6 speed MCS, you don't.
Matt
Old Jan 25, 2008 | 05:50 PM
  #118
UKCoopeR's Avatar
UKCoopeR
that is a really interesting graph, esp for an r50 owner like me, where did you get that info from?
Old Jan 25, 2008 | 05:56 PM
  #119
Longboard Mini
Thats what makes him the Dr.
Longboard
Old Jan 25, 2008 | 05:59 PM
  #120
verveAbsolut
Tell me Dr, what are the shift points for the S? This is a case of me not doing all of MY research I guess...looking the at the plots for power and torque for my engine with the 15% (and with an 02-04 gearbox), I was under the assumption that shifting late was best.
Looking to know more from a true engineer. =) I eat my words when I'm wrong...usually it tastes like poo.
- Matt
Old Jan 25, 2008 | 07:14 PM
  #121
Dr Obnxs's Avatar
Dr Obnxs
I made a rought graph of the factory engine torque curve
got the gear ratios, and estimated the effective mass (That's how the rotating parts effect the total work needed to get them spinning as a function of gear) and put it into excel.
For 07 MCS, no overboost
1-2 shift 6200 RPM
2-3 shift 6600 RPM
3-4 shift 6400 RPM
4-5 shift 6100 RPM
5-6 shift 6000 RPM
For 02 MCS
1-2 shift 6300 RPM
2-3 shift 6400 RPM
3-4 shift 6400 RPM
4-5 shift 6600 RPM
5-6 shift 6900 RPM
The 4-5 and 5-6 shifts are pretty academic (both over 100 MPH), but that's what the math gives.
Matt
ps, working it out for different torque curves is pretty easy, but I'll leave that as an exersize for the student! Can't make it all too easy!
Matt
Old Jan 25, 2008 | 08:02 PM
  #122
verveAbsolut
I thought this was America: it should be on a silver platter for me already, spoon in my mouth.
Thanks for the listing. Not too far off from redline though.
- Matt
Old Jan 26, 2008 | 09:31 AM
  #123
humcmcel's Avatar
humcmcel
I hope you guys really like your mechanics. I sounds to me like you'll get to spend plenty of time with them. I just looked at the sales brochure for my car and the specs page states the torque peaks on the MC @ 4500rpm and the MCS @ 4000 rpm (this would explain the need for the 6 spd gearbox in the MCS). Horse power peaks @ 6000 rpms for both. The dyno charts I've seen for modded cars go slightly higher, but I have always found that the torque peak was far more useful than the horsepower peak for forward momentum on any car. By the sound of it I still be enjoying my car long after yours becomes a memory.
Old Jan 26, 2008 | 10:02 AM
  #124
ScottinBend's Avatar
ScottinBend
I am not sure what you mean.......
Old Jan 26, 2008 | 10:03 AM
  #125
jhiggs26's Avatar
jhiggs26
1-2 shift 6200 RPM
2-3 shift 6600 RPM
3-4 shift 6400 RPM
4-5 shift 6100 RPM
5-6 shift 6000 RPM
For 02 MCS
1-2 shift 6300 RPM
2-3 shift 6400 RPM
3-4 shift 6400 RPM
4-5 shift 6600 RPM
5-6 shift 6900 RPM
Matt
Matt
It makes sense that upshifting after a lower gears intersection point on the thrust plot would equal a slower rate of acceleration, as would upshifting early. Full throttle acceleration from a stand still is an art. I'm no artist. That's why I'm leaning heavily towards a LSD for autocross season!
What about our MINI's shape/air drag Matt? Would that move upshifting above 2nd gear different from the curve, excluding 5-6 shift? Ahh I guess it doesn't matter as all of our MCSs are different(motor, SC pulley size, intake, exhaust, trans, tires, condition of components, etc) and will have different curves anyhow......
Jeremy
