Drivetrain Blew motor up!!! AGAIN!!!
Old Jan 26, 2008 | 10:25 AM
  #126
minimusprime's Avatar
minimusprime
Originally Posted by humcmcel
I hope you guys really like your mechanics. I sounds to me like you'll get to spend plenty of time with them. I just looked at the sales brochure for my car and the specs page states the torque peaks on the MC @ 4500rpm and the MCS @ 4000 rpm (this would explain the need for the 6 spd gearbox in the MCS). Horse power peaks @ 6000 rpms for both. The dyno charts I've seen for modded cars go slightly higher, but I have always found that the torque peak was far more useful than the horsepower peak for forward momentum on any car. By the sound of it I still be enjoying my car long after yours becomes a memory.
maybe you'd be better off surfing the club forums then instead of the drivetrain modifications threads.
Old Jan 26, 2008 | 11:23 AM
  #127
verveAbsolut's Avatar
verveAbsolut
Didn't we just show/prove to you that transmission effects have to be taken into account when determining acceleration? Engine peaks and graphs are meaningless unless put into context with the transmission. Maybe you missed those big points above...did you not read the statements and links posted?
Additionally, the redline (or around it) is there for a reason: everything under it is smooth sailing. The company engineers know what they are doing by setting tolerances and limits. They say it can run at ~6800RPM and under no problem...the redline would be lower if they meant otherwise.
And people like Tuls and many others have proven our cars are overbuilt with their high-RPM excursions.
- Mat
Old Jan 26, 2008 | 12:35 PM
  #128
Dr Obnxs's Avatar
Dr Obnxs
For the shift points,
drag drops out, the speed of the car is the same before and after the shift point. IT just lowers the whole thrust curve vs speed. To find top speed, you can actually plot the thrust curve and aero drag, and when the cross, the car won't go any faster.
You can choose to do the thrust curve with or without drag, it won't change the shiftpoints.
Showing why is an excursize left to the students!
Matt
And humcmcel, it's all about what floats your boat. If you want to have a car that lasts forever, baby it and all the rest of the stuff. If you want to race around a track and get as low a lap time as you can, the car won't be hitting 200k miles, that's for sure. But I, like others, don't really understand what your point is. Are you advocating we all treat cars like you do? We all drive like you do? and we all get our satisfaction from cars like you do? If so that's pretty arrogent. If not, then the point that modding for more power and driving at higher average revs or whatever leads to a shorter car life is what I'd call freakin obvious. But don't you at least allow us the right to choose how to use our cars as we see fit?
Old Jan 26, 2008 | 03:54 PM
  #129
herbie hind's Avatar
herbie hind
Matt
very eloquent here,here .!!!
Old Jan 26, 2008 | 04:12 PM
  #130
PGT's Avatar
PGT
NAM is a perfect place for you. Be sure to let us know when you get that chrome cupholder surround and those cool pullstraps for your backseats. Me and minimusprime and the rest of the crew will be out shredding backroads, ripping off shifts well into 7k territory. Some of us have mods that enable this behavior. Quit your BS proselytizing. Please.
Old Jan 26, 2008 | 04:33 PM
  #131
humcmcel's Avatar
humcmcel
It is about what floats your boat. Modding these cars is a given and should only be limited by the depth of your wallet. If your thing is about finding the limits of the car so be it, just don't be suprised when you find it... apparently 7200 rpms was the limit on the engine that started this thread.
Old Jan 26, 2008 | 04:35 PM
  #132
PGT's Avatar
PGT
reading > humcmcel
Old Jan 26, 2008 | 05:07 PM
  #133
jhiggs26's Avatar
jhiggs26
Let's all ease back and send good thoughts to Mario and his rebuild.
Some push hard and others short shift. Maybe we should take a look at a torn down babied/short shifted motors/boxes(gobs of carbon build-up in combustion chambers???) and compare it to Longboards or SpiderXs or Tuls. Then we'll all see the difference!
Jeremy
Old Jan 26, 2008 | 05:46 PM
  #134
Mini Fireman's Avatar
Mini Fireman
Maybe you missed the point that the cause appears to be an oil pump or pickup problem? Something like that could cause failure at virtually any RPM. Perhaps you advocate we don't drive our cars at all. Then nothing can fail.
Old Jan 26, 2008 | 05:58 PM
  #135
jhiggs26's Avatar
jhiggs26
Yep Mini Fireman that could be the cause. That's why on modded old minis us guys/gals put in a central oil pick-up pipe. Otherwise those long right hand sweepers can lead to oil pump starvation.
Jeremy
Old Jan 26, 2008 | 06:17 PM
  #136
Longboard Mini's Avatar
Longboard Mini
Here is my old chart (stock vs mod) with the M45 SC. You can see that once modded the TQ peaks around 4000 then go's nice and flat till around 6400. Great for spinning it high.
Now with the Rotrex the TQ peaks at around 6800. The difference with the Rotrex is that it never goes flat. The TQ curve claims like a HP curve which is very addictive to drive. Now even better to spin high. Funner as well.
Either way the TQ is what gets you going and the HP is what keeps you going.
Oh ya, I really like my mechanic (Hi Danny) and if it breaks it breaks. The amount of cars spinning way past 7k is growing weekly yet cars aren't breaking. If you are looking to drive your mini to 200k then don't mod it. Pushing the limits means from time to time someone will break. So what, just fix it and make it faster .
Longboard
Old Jan 26, 2008 | 08:13 PM
  #137
crazyaboutmini's Avatar
crazyaboutmini
uh... drool.... so the lesson is- if you fall, stand right back up and keep on going. fall again, then stand back up and get a walking stick with a rotex sc.
Old Jan 27, 2008 | 07:32 AM
  #138
Dr Obnxs's Avatar
Dr Obnxs
This may be a surprise
But many here have built and broken many a car before this one. Pay to play, pretty much just like everything else in life.
Matt
Old Jan 27, 2008 | 08:52 AM
  #139
Tüls's Avatar
Tüls
Turbius Maximus
Hey guys... am I lost... I thought this was the Cooper S modifications section of the forum... no?
wierd...
oh and I am pretty sure GP raises the Rev limiter... like 7100... IT'S MADNESS!
Old Jan 27, 2008 | 11:49 AM
  #140
MINIMM's Avatar
MINIMM
Have a boring ride or an exciting one.
I know which one I'll chose and I believe there are many here who feel the same way.
Old Jan 27, 2008 | 12:40 PM
  #141
Beecher's Avatar
Beecher
i have no idea where my redline is in my 06 cooper, but i certainly know that the rev limit is at 7400. And i see it quite a bit, on and off the street ( i have a habbit of getting on the highway in second hear, hahah)
Old Jan 27, 2008 | 01:50 PM
  #142
SharoSC02's Avatar
SharoSC02
Originally Posted by Tüls
of course that's ok.... it's an honor
yeah me too!
me 3
Old Jan 27, 2008 | 02:31 PM
  #143
SharoSC02's Avatar
SharoSC02
I'm on the exciting side of that.
Minis weren't built to be driven under 6500 rpms and be boring. If you want a car that you want to drive pretty and nice, get a SUV or a Toyota Corolla.
I hate it when people go out and buy Ferraris and Porsches and drive them like SUV and or a station wagon. These cars are built to drive hard and fast, if you don' believe me, take a trip to Italy or Germany. Mini is just the small version of those other faster and bigger cars.
Dr.O,,,,, please ignor my ignorance with this question, but by the shifting chart you provided earlier, should I or anyone else reading it come to a conclusion that shifting above those rpms don't necessarily give you more power/make your go faster? Which then one should ask the question of why would anyone raise the red line rev limiter to over 7k then?
Old Jan 27, 2008 | 02:51 PM
  #144
Beecher's Avatar
Beecher
most guys raising their rev limit has more power and torque than the stock engine, which means their shift points are different. The higher you rev an engine, the more power it makes. If it can of course, revving a stock doesnt make more power, but with the right mods, its certainly does.
Old Jan 27, 2008 | 03:03 PM
  #145
veggivet's Avatar
veggivet
[QUOTE=Tüls;2004700]Hey guys... am I lost... I thought this was the Cooper S modifications section of the forum... no?
wierd...
I guess you could consider a blown engine a 'modification' as it changes the way the car performs pretty dramatically.
Old Jan 27, 2008 | 03:18 PM
  #146
Tüls's Avatar
Tüls
Turbius Maximus
lol nice
I was actually making a joke based apon some of the subject matter being discussed
Old Jan 28, 2008 | 06:37 AM
  #147
Dr Obnxs's Avatar
Dr Obnxs
Thrust charts...
Show what gear give max acceleration for any given speed. But more goes into it. When you change gears, you have a bit of time when you're not under power, so it takes some time to catch up and get real benefit. So if you're close to an event, the finish line, a turn, a brake event, you ride through the shift point, give up a bit of thrust, but stay under power. It is what it is, a plot of wheel torque vs speed for all gears.
Matt
Old Jan 28, 2008 | 08:02 AM
  #148
Claymore's Avatar
Claymore
Caffeine Junkie
Being a vintage Vespa enthusiast, I learned the hard way that any time you start messing around with modifications to the factory setup, you take your chances. Sometimes they work well, sometimes they turn into a black hole.
It's not usually any one modification that does you in, but rather a combination of modifications that ultimately add up to a blown engine. The MINI was designed to a price-point, no doubt, but they simply were not intended to pump 200+ HP out of a 1.6 liter engine.
Old Jan 28, 2008 | 08:12 AM
  #149
eager2own's Avatar
eager2own
After I post on the Drivetrain modifications forum that mods in general are a bad idea, I'm going to go to the R52 forum and tell them that cabrios are bad ideas, and then I'm gonna go to the 2nd Gen forum and explain why the R56 is an insult to MINIs, and then I might go to regional forums and tell people in the South East - Florida forum that their state is prone to hurricanes.
Old Jan 28, 2008 | 08:16 AM
  #150
ScottinBend's Avatar
ScottinBend
But all of that is true.....................
