Drivetrain How do I test the newly installed JCW Intake
Old Jan 6, 2008 | 09:09 AM
dstrass's Avatar
dstrass
Hi all,
Just finished installing the JCW Intake and was wondering if the flap realy opens. I have tested it in neutral running the engine at 4500 RPM but it did not open.
Any idea how to verify that my install is correct?
Also, there is a vaccume line coming out of the flap valve (#17 in the diagarm, not the one that hookes up to the BPV via the Y #16) but the instruction did not say where to hook it up.
Thanks a bunch.
Attached Thumbnails How do I test the newly installed JCW Intake-jcw-intake-parts.jpg
Old Jan 6, 2008 | 09:16 AM
roaduscarnivorous's Avatar
roaduscarnivorous
you need to get it programmed, tho i think the flap might work even w/o programming...
Old Jan 6, 2008 | 09:48 AM
forced air man's Avatar
forced air man
JCW Air Box
U will need the DME programmed by Mini in order for the flap to function properly. After all programming is done, flap is activated after 3,500 rpms under load.
Old Jan 6, 2008 | 09:56 AM
minimarks's Avatar
minimarks
Flap opens at 4500 RPM, does not need programing. You need all lines hooked up, don't know how to explain the line out the front well except that it goes to the vacuum line below the IC on the right side. You will hear the sound change at 4500 RPMs if it is working...
Old Jan 6, 2008 | 10:14 AM
forced air man
JCW Air Box
Thanks for the clarification.
Old Jan 6, 2008 | 05:22 PM
dstrass's Avatar
dstrass
Figured up the mystery
My JCW intake is broken. the loos line suppose to go to the vacume valve but the valve diafram nipple is broken (#10 in the diagram in my first post). The thing is that I got the intake from OUT Motoring a while ago and I couldn't send it back.
Anywhere I can get this part? It shows as part # 13717558384?
Thanks again.
Old Jan 6, 2008 | 05:55 PM
wscruiser's Avatar
wscruiser
Thanks again.
There have been several members who have "de-flapped" their JCW intake. Maybe one of them may still have the old parts laying around.
It may not hurt to start a new thread, something like "looking for JCW intake parts".
Old Jan 6, 2008 | 08:09 PM
dstrass's Avatar
dstrass
Good idea thanks.
Old Jan 6, 2008 | 08:46 PM
minimarks's Avatar
minimarks
I'd still give Outmotoring a call, they have always been very helpful with me....
Old Mar 24, 2008 | 06:51 AM
MCSJCW's Avatar
MCSJCW
Hello
The Vacuum Pipe #16 from diagram in my car are disconnected
There is any problem with that?
The Engine light turned on with the error P1229. It may be related to the disconnected Vacuum Pipe or is another problem?
Best Regards and Thanks
Old Mar 24, 2008 | 07:29 AM
Bahamabart's Avatar
Bahamabart
absolutley
Jan 4, 2019 12:51 PM
silence2-38554
98
Sep 21, 2016 02:52 PM
Aug 12, 2015 01:24 PM
Aug 11, 2015 11:58 AM
