Drivetrain Fidanza flywheel and OEM clutch
Old Dec 19, 2007 | 08:40 PM
richplay69's Avatar
richplay69
Within the next week I will be having my 03 MCS's slipping clutch replaced with and OEM clutch. But I've come across a great deal on a light weight Fidanza flywheel... so I figured I may as well do that too while they are in there. My question is whether or not I will have any issues with this setup. I heard I would have alot of chatter noise. Any input would be greatly appreciated, Thanks!
Rich
Old Dec 19, 2007 | 10:04 PM
Grassroots Garage's Avatar
Grassroots Garage
Here is the issue... The stock flywheel is a dual mass, in other words, two pieces. There are springs inside to dampen the transfer of power from the crank side to the clutch side. The OE clutch disc is solid, it does not have the damper springs that a "normal" clutch has. OE disc + solid flywheel = no dampening of the clutch. This will cause "honking" noises when engaging the clutch. I highly recommend the lightweight flywheel, but only when used with a "sprung" clutch disc.
Old Dec 20, 2007 | 12:43 AM
Fisher's Avatar
Fisher
I have this combination (OK on the OEM clutch I put the carbon mass) and it works just great.
I am very satisfied. It's a little noise downthere but MINI isn't some MB S class soo it's OK for me.
If you let off fast the clutch pedal there is a little jerk. But I most cases you don't feel this.
The old (original) MINI does not have a spring hub from factory.
Go for it. You will be happy.
Bye
Old Dec 20, 2007 | 06:59 AM
richplay69's Avatar
richplay69
Alright, well I think I'm going to go with an aftermarket sprung hub clutch. I found one for only $70 more than the OEM. Thanks.
Old Apr 16, 2009 | 06:03 PM
seigmann's Avatar
seigmann
I tried fitting the Fidanza flywheel with the stock Cooper S clutch and it didn't work
Old Apr 16, 2009 | 07:18 PM
yellowbritishrocket's Avatar
yellowbritishrocket
been tossing the idea of a new clutch/flywheel for awhile but while its apart i think ill throw in a LSD too
Old Apr 16, 2009 | 07:43 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I would kill for a lightened flywheel and stiff clutch. >_<
Old Apr 16, 2009 | 08:18 PM
MrCooperS's Avatar
MrCooperS
Moderator
I have a kit sitting in my room waiting to get into my car...
Old Apr 16, 2009 | 10:03 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Anybody you want offed?
Old Apr 20, 2009 | 07:11 AM
MaitlandImports's Avatar
MaitlandImports
Rich
Used to have this setup on ours..... Chattered so bad some people refused to drive the car. Swapped to a Giken... no noise at all.
andrewjg1994
Jan 29, 2021 07:45 PM
Branto
Aug 11, 2017 05:32 PM
blackie
Oct 2, 2015 07:41 PM
Camaro108
Aug 25, 2015 02:44 PM
FLYM1N1
Aug 16, 2015 01:15 PM
