Drivetrain DDMWorks Race Exhaust System R56
The DDMWorks Race Exhaust is a true bolt on exhaust, made from high quality materials with great looks and function. The exhaust mounts to your MINI using all of the factory mounting points under the car and does not require you to cut or weld your stock factory exhaust, allowing you to return to stock anytime, if needed. The key to making the system a true bolt on is the special front transition piece that we designed, that adapts from the stock turbo downpipe to the 3” Race Exhaust insuring an easy installation. We could have chosen to go with less expensive and lower quality 409 stainless steel for the system to save some cost on the system, but instead we chose only the best materials to manufacture the system out of and that meant a full 304 stainless steel system ensuring an exhaust that will last you a lifetime. At the back of the system is the fully polished exhaust canister itself, which is finished off with two 3.5" hand built dual wall stainless tips built by craftsmen who have been building exhausts for years.
Removing the factory exhaust and replacing it with the DDMWorks Race Exhaust, provides you with faster turbo spool and a big power increase of 15 Horsepower and 15 ft/lbs of torque measured at the wheels on your R56. Although this system is not for the faint of heart, as the straight through system provides a deeper exhaust note and also an increase in volume, it is something that can be easily used on a street car. Another benefit of the Race exhaust is the removal of the restrictive secondary catalytic converter found in the stock system. Removing this secondary cat allows a much higher flowing system providing more power for your MINI at the wheels. For those that may want to have the secondary cat, we can do that also, and offer a high flow secondary catalytic converter as an option.
This is the same exhaust we have been using on our own street driven MINI for thousands of miles, and is exhaust is for you if you are looking for the best performing aftermarket exhaust for the R56 available!
Price $849
Link - http://ddmworks.com/MiniStore/MINI_S...6_exhaust.html
Video clips of the exhaust are on that page or can be seen on our youtube page - http://youtube.com/user/ddmworks
Price $849
Can you recompress those videos using the WMA Lossless compression on the audio?
Shouldn't drastically increase the size of the video itself and would be great to hear without all the compression artifacts that are in those videos.
Also... I'm a bit of a novice.
Since you remove the rear converter in the exhaust, would that prevent me from passing a "normal" emissions inspection (ie... not as strict as California).
I don't know what kind of threshold you have to be within or any other details that would cause you to fail an inspection.
Question from the non-mechanic in the peanut gallery:
"Race" exhaust = "will not pass emissions" in most states?
Or will it, despite eliminating the second cat?
It's a nice looking bit of kit.
EDIT: Helps if I read the thread first...beat me to it...
yeah, well, at least it's usually once a year for the inspection and since the exhaust doesn't require cutting of the OEM, I suppose you could always disassemble/reassemble for inspections, although it would be nice to not have to do that.
Dave, does anyone local (Greenville area) have one installed? I'd love to take a listen in person. I had the Magnaflow on my '03 MCS and according to my wife it was Too Loud. I don't know about that, but it did have an awful drone at highway speeds. Would I have the same problem with this exhaust?
BTW, I was in the Foothills Miata Club (Mike) with the '04 Ti MSpeed. Enjoyed the MS, but missed the MINI
Jan 4, 2019 12:51 PM
Aug 12, 2015 01:24 PM
Aug 11, 2015 11:58 AM
Aug 10, 2015 02:03 PM
Aug 10, 2015 01:59 PM
