Drivetrain Got a dragging/slipping problem with my new performance clutch .
Old Jul 8, 2007 | 12:07 PM
fozworth's Avatar
fozworth
Ive had a new clutchmaster fx300 clutch kit fitted and have now done over 650miles to try and bed it in.The problem is ,when i pull away hard from a stand still it seems to not totaly engage like sort of drag/slip as you go from gear to gear.The same happens when i enter a motorway(freeway to you guys) and accelerate hard up through the gears ,it just seems to slip/drag slightly and not totaly give you the full power you would get if it were totaly locked on.Is there anyway this can be a release problem with the clutch slave cylender etc.I realy dont want to have to remove the gearbox again.Oh and the fidenza flywheel had a new friction plate fitted and it was cleaned first with brake cleaner.
Old Jul 8, 2007 | 03:51 PM
Longboard Mini's Avatar
Longboard Mini
I just put the same clutch in my car with the clutch master flywheel.
Did you have the problem from the start or did this happen after you broke it in??
Longboard
Old Jul 9, 2007 | 12:41 AM
fozworth's Avatar
fozworth
I noticed it after i,d done about 145 miles so told jan and he said fully baby it for at least 500 miles so i have and it still does it
Old Jul 9, 2007 | 06:34 AM
Ryephile's Avatar
Ryephile
Something is messed up. Either you screwed it up during break-in [like spraying it or riding it in traffic] or you got a defective piece. I can tell you from experience this clutch is freaking amazing, and a proverbial light switch. There is not supposed to be any hesitation or weirdness. From your other posts it sounds like you glazed it.
Old Jul 9, 2007 | 06:46 AM
Revolution Mini Works's Avatar
we have sold over 15 of these clutches already and this is the only one experiencing this problem. Then again this is the only one running a NON Clutchmaster flywheel too.
Old Jul 9, 2007 | 08:13 AM
fozworth's Avatar
fozworth
Hi all ,just want to make sure that im in no way dis-ing this product i got from Jan,I totaly trust his judgment and know he realy knows his stuff,I just havent ,what i would consider over cooked the run in period and as for the spray its not connected up on this engine and never will be.I just need help in removing the dame kit.But i cant see why my car is doing this.Is there anything else i can do?
Old Jul 9, 2007 | 10:47 AM
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
Did you stick with a factory flywheel or did you go aftermarket?
I know of a local case where an installer put a lightweight flywheel in a car and left out a spacer washer/thing. That caused the clutch to not engage properly and slip.
Old Jul 9, 2007 | 12:47 PM
fozworth's Avatar
fozworth
Used a fidanza flywheel but never had a spacer on my last clutch kit which was a Helix.Im just worried ive not done enough normal driving miles ,and that the clutch might of glazed,if that has happened what do i do to sort it?
Old Jul 9, 2007 | 04:36 PM
Paul Webster's Avatar
Paul Webster
Go up to Shakespeare County Raceway this weekend for the British Mini Club Showdown run the 1/4 as many times as you can, that should bed it in nicely
Old Jul 9, 2007 | 04:39 PM
Originally Posted by Paul Webster
Go up to Shakespeare County Raceway this weekend for the British Mini Club Showdown run the 1/4 as many times aas you can, that should bed it in nicely
Paul,
You are NOT helping matters
After talking to Jamie more I believe he has a "spacing" issue with the fidanza. If you really want to help why don't you go over to his place and drop the tranny with him...
Old Jul 10, 2007 | 12:08 AM
Paul Webster
I always give Jamie a help over the phone and he's more than welcome to come up here and put it on the ramp and compare them to ours.
Or he can still come up to Shakey at the weekend and we can have a look and a drive for a second opinion before he rips it out.
Where is the bite point on the pedal Jamie??
Old Jul 10, 2007 | 12:57 AM
fozworth's Avatar
fozworth
about half way maybe a bit higher,.
workin all weekend paul but might have to make the trip up soon if i cant sort it.
cheers mate
Old Jul 10, 2007 | 01:55 PM
fozworth's Avatar
fozworth
clutch actualy starts to bite about 1/4 the way up from the floor ,and if you pull the handbrake up and slowly release the clutch with a few revs it bites and stalls,same in reverse.so its obviously clamping pretty well.
Markbett
Jul 3, 2016 04:28 PM
Zettinger
Aug 25, 2015 04:04 PM
Aug 12, 2015 01:24 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
