Drivetrain Intercoolers
Old Jul 6, 2007 | 03:33 PM
  #26
herbie hind's Avatar
herbie hind
hell i'm gonna drop 75 lbs. and whip all your asses !!!
Old Jul 6, 2007 | 03:37 PM
  #27
isellem's Avatar
isellem
bring it on!!! LOL
Old Jul 6, 2007 | 03:41 PM
  #28
ChrisW's Avatar
ChrisW
Originally Posted by maxmini
The weight is a issue and is at least 10 to 15 lbs . The water alone is close to eight per gallon. If you do not have at LEAST a gallon in the loop you will attain heat soak way to fast. Add in the completely enclosed IC ,hoses, clamps additional radiator etc and you only get 5 to 7? Must be that new math .
Randy
M7 Tuning
10 to 15 LBS isn't going to mean anything. For every 100 LBS you lose or Gain you lose or gain 1 tenth of a sec in overall speed. So if your car can run 14.00 in the 1/4. You'll run 14.015 with the extral weight. I'm pretty sure the 29hp that MarioKart lost due to heat soake will make up for the time difference.
Chris
Old Jul 6, 2007 | 03:45 PM
  #29
isellem's Avatar
isellem
the 22hp that we gained to the wheels was also a nice addition...
also, what if that 15lbs (which it isn't) is over the front tires... which aids in traction... then perhaps your 1/4 mile time might differ by .0149 or .01499 traction is important too!
  #30
Longboard Mini's Avatar
Longboard Mini
Originally Posted by MarioKart
My Air/water is being made right now and should be in my hands next week, once the powedercoating is done. I'm have only heard great things from the owners and from my test drive, even the hot side was cool to the touch. I know heat is a huge hp killer on our cars. My Mini dyno'd at 234whp with a air/air, the second run was 205whp and the third was 185whp. The Air/water wont make me hp but it will help me keep what I got.
They are not cheap but I'm running out of options to make HP, I need to save a lot more penny's to get my turbo only kit.
mario
What intercooler did you end up with?
Longboard
Old Jul 6, 2007 | 03:47 PM
  #31
ChrisW's Avatar
ChrisW
Glad to see we are on the same page.
Old Jul 6, 2007 | 03:48 PM
  #32
Longboard Mini
bring it on!!! LOL
I'm 6'1" and 225 Lbs of pure speed. I'm like a cat. Ok a fat cat.
I use the extra weight in the turns .
Longboard
Old Jul 6, 2007 | 03:52 PM
  #33
ChrisW's Avatar
ChrisW
This is the other thing I've thought about getting. I know its not good for road racing but It would be great on the strip or autoX between runs or Dyno pulls.
Old Jul 6, 2007 | 03:54 PM
  #34
isellem's Avatar
isellem
man up and just use nitrous! its totally safe! it really is!
Old Jul 6, 2007 | 04:02 PM
  #35
ChrisW's Avatar
ChrisW
I've ran NOS on afew cars. I just don't know how I feel about running it on the MINI with those narrow *** tires on it.
Old Jul 6, 2007 | 04:13 PM
  #36
isellem's Avatar
isellem
just spray it on the intercooler!!!!!!! it works sooooooooo well!
Old Jul 6, 2007 | 04:20 PM
  #37
SharoSC02's Avatar
SharoSC02
Originally Posted by Longboard Mini
How much do you think this weighs? Water and Air 2 Air
That's a nice set up. The top mount looks almost identical to the GRS a2a unit I have accept for the 2 flanges (air divertor) on top.
Old Jul 6, 2007 | 04:48 PM
  #38
lhoboy's Avatar
lhoboy
Originally Posted by SpiderX
There is no moving air on a dyno and the W2A is far superior at the dyno....
Most dynos I've worked with, we always placed a huge fan in front of the car. Otherwise the car won't handle more than a run or two, before it overheats
Old Jul 6, 2007 | 04:52 PM
  #39
MarioKart's Avatar
MarioKart
Vendor
Longboard
I ordered the Mini Madness A/W. Who makes the one you posted a pic of? How much?
M
Old Jul 6, 2007 | 04:54 PM
  #40
isellem's Avatar
isellem
M
NICE!
thats the one i used... the only thing that i would change other than a cap to the overflow tank is... change the mounting of the water pump. it tells you to attach it to the splash shield... i wasn't down with that... especially with all of the blown out (tire gators) tires on the freeways here in AZ. I mounted mine her the driver side headlight. it made the wiring a breeze.
Old Jul 6, 2007 | 04:59 PM
  #41
MarioKart's Avatar
MarioKart
Vendor
NICE!
I was wondering about that myself, I didn't like how the mounting was on the bottom of the car. Do you have pic you can show me? How many gallons of water does yours hold?
Old Jul 6, 2007 | 05:33 PM
  #42
Longboard Mini
M
It's from Pace in the UK. It's the only air and water combo on the market. The claimed HP is very nice if true. I checked it out. The cost was $2000.00 + shipping.
Longboard
Old Jul 6, 2007 | 06:09 PM
  #43
SharoSC02's Avatar
SharoSC02
Longboard
That's a similar sytem I was planning on getting but the $2k was just too much to bare.
Old Jul 6, 2007 | 11:07 PM
  #44
JPMM's Avatar
JPMM
Put the -220 degrees inside !!!
I think putting it in is safe with the systems now available. You would find your intercooler, if NOS was sprayed inside at the outlet of the supercharger,(only @ WOT) to be colder than ambient.
Old Jul 7, 2007 | 05:15 AM
  #45
stevecars60's Avatar
stevecars60
Yup.... + the added kick...
Ok we have 2 cars, 1 with an A2A, the other with a W2A. They both are on the cross Bronx expressway at 4:30pm on a Friday afternoonin late July.
The A2A car will heat soak in just a few minutes. The amount of energy needed to heat soak, even the biggest A2A, top mount IC is minimal compaired to a W2A.
The W2A car will take much longer to heat soak & what temp is considered heat soak. IAT, with a W2A, may never reach the the same IAT as A2A at high ambient or as low at low ambient. But.......
Bottom line, the W2A will diliver a lower average IAT. The argument has been made that the efficency of the W2A is not as high as A2A, true. 1 is an active system the other passive, passive wins no mater what the numbers. Passive looses in terms of absolute numbers, high or low. When the sun's not out the coal plant is making juce not your collector pannel on the roof.
So if you are on the Cross Bronx expressway at 4:30pm on a Friday afternoon in late July, you'll need to decide if you need the extra power & the added cost of a W2A, so if, this is a big if, the opertunity presents itself to accelerate to more than 8mph, you got the horses to do it. On the other hand, if I lived in the southwest, my son lives in Tucson, W2A would, most diffinately, be the best W2A I could afford.
Old Jul 7, 2007 | 05:31 AM
  #46
SpiderX's Avatar
SpiderX
The fans can not replicate highway speeds and air flow....
I spoke with GRS and for the track he does not recommend his W2A for the reasons previously mentioned.... Typically when I'm in traffic creeping along the extra whp makes no difference.... I also am not sure about the extra plumbing.... there is something pulling me toward W2A but there may be some improvements made in the current A2A units.....
I am glad this thread is running as I hope to learn a lot
(Where is DR O.?)
Old Jul 7, 2007 | 06:29 AM
  #47
lhoboy's Avatar
lhoboy
Agreed: It's hard to find a dyno mounted to the inside of a 100 mph wind tunnel.
Old Jul 7, 2007 | 07:17 AM
  #48
Johan's Avatar
Johan
Originally Posted by RECOOP
You are trying to compare apples to rhubarb. Track driving/racing with sustained speeds and very high revs, as in F1 and IRL, is quite different from the type of driving that most of us do.
If your car is going to be a dedicated race car or on the track a lot, then, IMO, you might lean towards one of the better air-to-air intercoolers. However, a good water-to-air intercooler, e.g., the Gintani system, the Madness unit or others, might be a good choice for spirited city/highway/canyon driving. With that said, the water-to-air intercoolers have been used quite successfully in MINI's on the track.
You need to decide the kind of driving you'll be doing, your budget and aesthetic views. After that, pick an IC that best suits your requirements. If you're like a lot of the people on this forum, most of the aftermarket products should be o.k. Again, IMO, the stock intercooler, perhaps with better connecting boots, is a more-than-adequate unit for the majority of our driving needs.
Good luck...
One thing to keep in mind when considering a water-to-air intercooler, such as the Gintani system, is the net gain in weight. It should be noted that the stock intercooler, plenums, boots and intake manifold are removed when the Gintani system is used. In my car the net gain, including 1.5 gallons of cooling water, was about 20 pounds. IMO, when calculating power-to-weight ratios, the small additional weight is truly trivial.
Cheers...
+1 Great thread, I'll comment more later! -- Johan
Old Jul 7, 2007 | 10:22 AM
  #49
UKXPAT's Avatar
UKXPAT
Great info guys, looks like I started something here. It still seems pretty open and personal, the route to take. I forgot to add that I am in Dallas, TX, so that may swing it one way perhaps. Don't do a lot of track work, just play on the roads some.
Anybody tried the new M7 with the gel heat blanket?
Old Jul 7, 2007 | 12:10 PM
  #50
JIMINNI's Avatar
JIMINNI
Longboard
Sounds like a deal when compared to the Gintani, which I belive is $3500.00 + shipping.
