Drivetrain Revolution Mini Works car breaks 251.72whp
Old Jul 16, 2007 | 03:22 PM
  #126
Johan's Avatar
Johan
nevermind...WAY off topic
Old Jul 16, 2007 | 03:30 PM
  #127
JIMINNI's Avatar
JIMINNI
Originally Posted by mozzarella
There are two posts that say two very different things, what's the truth. There are people that are or looking to spend money with you guys they ought to know what they are getting. Alot of these posts sound like there is magic involved.
Your right, but you know what, they are all GROWN men and probly dont need your help.
Old Jul 16, 2007 | 03:31 PM
  #128
mozzarella's Avatar
mozzarella
Or your's.
  #129
JIMINNI's Avatar
JIMINNI
And another thing, it seems like the same guy's that are causing drama here are doing the same thing on M7 threads.
Old Jul 16, 2007 | 03:32 PM
  #130
JIMINNI's Avatar
JIMINNI
Or your's.
I dont butt into their threads either.
Old Jul 16, 2007 | 04:00 PM
  #131
mozzarella's Avatar
mozzarella
No butt you got flames. (on your car)
Old Jul 16, 2007 | 04:14 PM
  #132
SayGoodbye's Avatar
SayGoodbye
Old Jul 16, 2007 | 04:16 PM
  #133
ChrisW's Avatar
ChrisW
Originally Posted by SayGoodbye
I'm rubber and you're glue...
On to the drag strip http://www.firebirdraceway.com/06web/streetdrags.html
Now, how to fit a helmet on my 6' 7" frame without needing to open the sunroof...
Ouch I thought I had it bad at 6'-2".
Old Jul 16, 2007 | 04:23 PM
  #134
Partsman's Avatar
Partsman
Legion_of_Doom
Seems it was still not tuned. And according to your "Guru" of tuning, this "makes all the differance".
Are you sure it wasn't tuned...?
Originally Posted by MINICORSA
my car was NOT tuned just a raised rev limit. that 4whp to me is weather change and with my stock flash my torque and hp come on a lot sooner. you guys are more then welcome to come to the dyno day at Autowave on Aug. 11 and see my car pull the 250. I have not seen one mini on the dyno that doesn't spray the intercooler for added horsepower i pulled that 250 in 100 degree weather. lets end this drama he said she said stuff.
Originally Posted by VitessePro
Hello everyone,
Well, this is a great day! Danny’s car hit 250 WHP with the Vitesse Pro tune with some additional hardware changes!...
Danny’s ecu has one of my custom programs on it and it is far from a stock program with just a raised rev limiter.
I tuned Danny’s car on a dyno roughly around two months ago with his previous setup (Other vendor ported head) and if memory serves right it did register slightly over 200whp on his first dyno run even thought his engine was not healthy. I also made further adjustments with his New setup about 1.5 – 2 weeks ago.
Danny’s flash is similar to what MarioKart runs on his car for comparison sake. Mario made just about 234 WHP with a 17% pulley @ 7600 rpms the Other tuner’s stg2 head (stock crnk shaft pulley) and Danny made 235 WHP with a 19% pulley @ 7800 rpms (I think also stock crnk shaft pulley).
The tune on Danny’s car has not been finalized. There is room for improvement.
Vitesse Pro
...How would we know anyway? The two posts above from MINICORSA and VitessePro seem to contradict each other.
So which is it?
Just explain the difference in the two posts.
Yes, please do.
Old Jul 16, 2007 | 04:25 PM
  #135
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
When my car was previously in for work and tuned/dynoed it pulled 223whp (on a Dynapack) with no spraying just fans. It's currently back in the shop for a proper clutch and we'll see how it does when that's all sorted out.
Old Jul 16, 2007 | 04:38 PM
  #136
RIPPER's Avatar
RIPPER
My runs on the tenth were in fourth gear, 95 degrees, 90% humidity with fans blowing at front of car and cold water sprayed on dfic ( between runs) and after my car sat for over an hr I pulled 205 and 170 with the same mods as longbords except he has 380cc injectors and 2 degree colder plugs. But remember that he is in cali with almost no humidity and 70 degrees. We will see what my car does the next time I get a couple of 70 degree days and low humidity.
Old Jul 16, 2007 | 04:48 PM
  #137
RIPPER's Avatar
RIPPER
I'm not rallying for or against the jesus head. I'm only giving the info based on the facts of what my car is doing. whatever my car does on the dyno when I get that 70 degree day and low humidity, Thats what I'm going to post. It doesn't matter if it makes the head look good or bad I'll post the results. I just want to get as close to the conditions as the last dyno before the jesus head so I can get a true delta
Old Jul 16, 2007 | 05:01 PM
  #138
SayGoodbye's Avatar
SayGoodbye
Old Jul 16, 2007 | 05:07 PM
  #139
MINICORSA's Avatar
MINICORSA
good point i prolly should
Old Jul 16, 2007 | 05:10 PM
  #140
MINICORSA's Avatar
MINICORSA
if your talking about my tuning issue i had thought at the time there was a tune on the car when we had the dynos done. then i figured out that it was a stock tune with a raised rev limit.
I am assuming your talking about that if not please tell me what exact posts you are reffering to thanks.
Old Jul 16, 2007 | 05:21 PM
  #141
MINICORSA's Avatar
MINICORSA
dyno
i have posted the dyno run in reply #83 showing the run with my car with a "flash" and stock from 2000-7000 does this look like a tuned car? i was under the impression that the car was tuned when we got the 232 232 and 250 numbers but it wasn't. i found out by going to the dealer and flashing the car back to stock and getting another dyno run. this clearly shows that the car wasn't tuned other that a raised rev limit. i hope i have made it clear that in no way i was dishosest about anything. and paul i will be going to the drag strip soon to see what my car does.
Old Jul 16, 2007 | 05:28 PM
  #142
Longboard Mini's Avatar
Longboard Mini
Sounds like there are a few people with power envy.
Longboard
Old Jul 16, 2007 | 05:29 PM
  #143
SayGoodbye's Avatar
SayGoodbye
Old Jul 16, 2007 | 06:04 PM
  #144
Partsman's Avatar
Partsman
Legion_of_Doom
Longboard
It's not power envy, man. I would just like to see at least ONE more car make the same power(or even close) to what you did with the RMW head, basic bolt on mods and no tune.
Old Jul 16, 2007 | 06:17 PM
  #145
batrugger's Avatar
batrugger
We haven't dyno'd my wifes car, but I can tell you hat it has a lot more power than before with RMW's head on it. I would be wiling to put her car on the same dyno Longboard used since her car has basically the same mods he had when he did his first dyno. We have been thinking about going to the strip with it in Irwindale too, Thurs nights are "Run What You Brung", but that is an 1/8 mile track. 1/4 mile tracks are a rarity here. We can't go to Autowave on the 11th though because that is the Big SoCalEuro GTG day
Old Jul 16, 2007 | 06:26 PM
  #146
Partsman's Avatar
Partsman
Legion_of_Doom
If you are ever able to get to said dyno, i'm sure there will be A LOT of people interested in the results.
Thanks for posting.
Old Jul 16, 2007 | 07:36 PM
  #147
RedSkunk's Avatar
RedSkunk
Paul – are there calculations for determining HP using 1/8th mile runs? I've only been dragging once and it was an 1/8th.. Of course I don't know my weight so it's a moot point anyways..
Old Jul 16, 2007 | 07:55 PM
  #148
Ryephile's Avatar
Ryephile
Thanks for your subjective, uninfluenced feedback! After all, how the car feels behind the wheel is the most important factor for the vast majority of us consumer/enthusiasts.
Old Jul 16, 2007 | 11:57 PM
  #149
Paul Webster's Avatar
Paul Webster
http://www.wallaceracing.com/Calculators.htm
There's a few on here once you've found out how much hp you have then use the top one its quite accurate for flywheel figures compared to our dyno.
I'm studfying that bit at the moment
Weight wise figure between 2600 -2800 with you in it, though I believe Gnaster did say heis weighed 3000, I weighed 2790 in the Megam Mini twincharged with glass roof.
Old Jul 17, 2007 | 07:05 AM
  #150
obehave's Avatar
obehave
Confucius say.
When flinging poo
Stand not in front of the fan
Unless eating your own poo
You are liking
