Drivetrain Tensioner Pulley
Old May 7, 2007 | 09:27 AM
MCSJCW's Avatar
MCSJCW
Tensioner Pulley
Hello
Anyone knows the difference of GTT TENSIONER PULLEY and the OEM TENSIONER PULLEY?
Best Regards
Old May 8, 2007 | 02:22 PM
SumWon's Avatar
SumWon
Besides quality?
Old May 8, 2007 | 05:14 PM
Guest's Avatar
Guest
It may have a stop built into it so it doesn't destroy the crank pulley if you break a belt .
Old May 8, 2007 | 05:45 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Would the OEM tensioner destroy the harmonic balancer if the belt broke? I have the stock balancer and a 15% s/c pulley. I am interested in a replacement tensioner because one of the pulleys on it has developed a noise after I had a small piece of gravel in the track of the a/c compresser that began to eat the belt. Belt flakes got everywhere, and wrecked it guess.
Old May 8, 2007 | 06:02 PM
Guest's Avatar
Guest
It's been known to damage the OEM crank pulley when it breaks yes
Old May 9, 2007 | 07:09 AM
MCSJCW's Avatar
MCSJCW
Hello
Thanks for the reply´s...
The GTT have better quality than the OEM? Is a good change?
Best Regards
Old May 9, 2007 | 01:45 PM
SumWon's Avatar
SumWon
Originally Posted by MCSJCW
Hello
Best Regards
Yes, the GTT is a much higher quality product than the OEM both in material and craftsmanship. The question becomes is it worth the cost? That is a tough call. If you have a failing bearing on the original and need to replace it, OEM will require you to replace the whole tensioning mechanism, not just the pulley. So do you spend the money on a complete mechanism or just a pulley? I say if you have a failing bearing that is a good indication that maybe you should go for just the pulley. I replaced both my tensioner and idler pullies with the GTT tuning products as well as installed the tensioner limit stop. I did the replacement as a preventive maintenance measure while I was replacing my crank pulley. I have been VERY pleased with the products and the limit stop has saved me from having a tensioner crash once already when my drive belt failed. Hope that helps.
Old May 10, 2007 | 02:58 AM
MCSJCW's Avatar
MCSJCW
Hello
Thanks SumWon.
My problem is a noise in the drive belt. I think that with tensioner and with twin bearing idler pulley it is better. You agree?
Best Regards
Old May 10, 2007 | 06:15 AM
SumWon's Avatar
SumWon
Hello
Thanks SumWon.
Best Regards
Yes, I agree the GTT tensioner and idler pullies are better than OEM.
Old May 10, 2007 | 07:30 AM
MCSJCW's Avatar
MCSJCW
Hello
Thanks one more time, i go to order it
Best Regards
vulkandino
Oct 31, 2015 08:29 PM
pahg
Oct 5, 2015 11:50 AM
Debi's Coop S
Oct 3, 2015 08:19 AM
fkrowland
Sep 30, 2015 10:30 AM
daviday
Sep 25, 2015 01:31 AM
