Driver's School Discuss tips, techniques, and schools for enhancing the driver portion of the performance driving equation.
SCDA HPDE Schedule
Old May 10, 2011 | 05:54 PM
  #551
veggivet's Avatar
veggivet
Darn expensive vets!
Old May 10, 2011 | 06:49 PM
  #552
S-Driver's Avatar
S-Driver
Geez! Are we subsidizing [I]all[I] the Vets that do DE's?
Old May 10, 2011 | 07:22 PM
  #553
slinger688's Avatar
slinger688
On a serious note:
How much track time and how much For NASA at LRP.
Old May 10, 2011 | 07:29 PM
  #554
slinger688's Avatar
slinger688
I think they may be ranking up there with ambulance chasing lawyers and mortgage bankers!
Old May 10, 2011 | 07:36 PM
  #555
veggivet's Avatar
veggivet
NASA schedule isn't posted yet, but the cost is $280 for the full day, but you need to become a member, which adds another $45, I think. They offer a time trial at the end of the day, if you want to run in it. I'm off to chase down a dog spay or two...
Old May 10, 2011 | 08:20 PM
  #556
slinger688's Avatar
slinger688
Ok sounds possible. Will need to work on my boost leak and start up issues. Oh, I also have a coolant leak as well.
Old May 10, 2011 | 08:34 PM
  #557
slinger688's Avatar
slinger688
VV, you should consider doing the WGI longest day with us in June with patroon. Sounds like a few Minis are going.
Old May 11, 2011 | 02:35 AM
  #558
veggivet's Avatar
veggivet
I didn't know your car was still acting up. Hope things get sorted out soon. If not, you could always borrow my Justa and crawl around the track.
If I do NASA on the 6th, I can't do WGI a week later.
Old May 11, 2011 | 07:16 AM
  #559
slinger688's Avatar
slinger688
Car is starting to feel it's track age.
I need to get my point by hand and finger ready with the justa. Thanks for the offer. Let me try to get the car ready.
Old May 11, 2011 | 11:05 AM
  #560
S-Driver's Avatar
S-Driver
Think you'll have more fun at the "Longest Day"...
Old May 12, 2011 | 07:04 PM
  #561
Eddie07S's Avatar
Eddie07S
how are you coming with your brakes? I may need new rotors before too long.
Here is my idea for a brake duct. I wrote it up yesterday but forgot to post it....On the Mini the front bumper tucks in under the front and ends with the air dam. In front of the air dam is a horizontal flat section. The area below the fog lights and just ahead of the air dam should be a good high pressure area given the trapped air in this area. A hole can easily be cut with a hole saw in this flat area. This enters up and into the area behind the fog lights. A brake duct hose can be routed from there to the brakes using the typical route. The hose can be fitted/fixed to the hole in the bumper with some RTV if you can't find a fitting. You want to place the hole in front of the section of the air dam that is the longest. That will be the area with the most pressure. Hope this makes sense. If not, let me know. I have some pictures that might help. Also, if you don't like the way it works, you can glue the plug back in.
Old May 12, 2011 | 07:33 PM
  #562
slinger688's Avatar
slinger688
Look at the naca duct.
See this: http://en.m.wikipedia.org/wiki/NACA_duct
It is flush but really sucks air in. One of those space inventions.
I heard that the duct all the way to the rotor can limit the wheel turning movements. Sneed speed shop has ambit for the r53 that can be adapted to the r56. But it is amlittle pricey.
Eddie, are you burning up you brakes already?
Old May 12, 2011 | 07:44 PM
  #563
slinger688's Avatar
slinger688
Eddie , see this link for some of the front and side naca ducts for racing cars.
racerpartswholesale.com/category/Naca_Ducts2
I have always though of using them for cooling and would like to see what ideas you have. Unfortunately the smallest ones seem to be rather too large for the location you mentioned in your post. So I thought of putting a under belly pan such as the one from forge or moss mini and putting the naca ducts there instead. Something perhaps 2.5 inch ducting. What do you think?
Old May 13, 2011 | 07:22 PM
  #564
S-Driver's Avatar
S-Driver
Haven't even started yet.... I will most likely mount that second bumper skin I bought (just for this purpose) and use the traditional fog light inlet method. Let you know...
Old May 14, 2011 | 01:41 PM
  #565
Eddie07S's Avatar
Eddie07S
Say, as driver education goes...Have any of you tried trail braking into the toe at WGI?
Old May 14, 2011 | 03:33 PM
  #566
slinger688's Avatar
slinger688
You can do a little trail braking just before the uphill section but you need to be on power quite early in the turn to maintain speed.
The best spot for trailing braking is big bend at LRP. Can get the back to slide out 1 foot or so twice.
Old May 14, 2011 | 03:36 PM
  #567
slinger688's Avatar
slinger688
BTW it is easier to practice TTO first before TBO. So try that first at the downhill section at WGI after bus stop. You can really learn to feather the throttle there.
Old May 14, 2011 | 03:42 PM
  #568
veggivet's Avatar
veggivet
I've never trail braked at the toe, and nobody ever suggested it at that spot. Following the 'new' MINI line there made a huge difference in that corner, though.
Old May 14, 2011 | 05:48 PM
  #569
Eddie07S's Avatar
Eddie07S
Are you talking about the full outside line? Ya that is smooth, but my instructor had me check my speed at the trackout of that corner during my second day and I tried several different lines. With that one I only picked up 1 or 2 mph. We were not sure if this made up for the different in distance. So I stayed with the student line athough I like the smoothness of that outside line.
I asked the question because I was looking for something in between the outside and student lines that would work better for a Mini. My instructor and I didn't find anything better the last time out. I suppose everyone with a Mini has been looking for this magic line.
Say, the FSDs are working well for street and track. Nice ride on the street. On the track they are not noticable, but the car doesn't do anything that you don't want it to. At first I didn't thing they were doing anything special, but I now think that because they were not noticable they were actually working really well. As for autocross, I am still thinking about how well they did. I had other problems today (mostly wrong brake pads), but I also noticed some front end dive in the corners. Maybe I am just more observant. Overall, I would recommend them, especially for the street.
Old May 14, 2011 | 05:52 PM
  #570
veggivet's Avatar
veggivet
Yes, the outside line for me is much smoother and it feels faster, but I don't have a data tracker to back that up. Glad you are happy with the FSD's. I had some issues with the front suspension shuddering at the toe on the inside line, but that disappeared when I made the change. Slinger doesn't quite go as far to the outside as I do, but his car has more power for that uphill.
Old May 16, 2011 | 07:32 AM
  #571
Claymore's Avatar
Claymore
Caffeine Junkie
Seconded on the outside line there. It was a bit of a chore to power out of that hole at the apex, not to mention the bumping around.
Looks like I have the dreaded supercharger leak, too. I went to have an RMW tune on Saturday and Jan couldn't figure out why the car was running lean, even after I put in the 380 injectors. Turns out the gasket leak is the issue, so now I have to get that fixed before I can come out and play.
Old May 17, 2011 | 08:34 PM
  #572
S-Driver's Avatar
S-Driver
I am out for the June 23rd CART Limerock event. I need to be up in New Hampshire for the Mt Washington Hillclimb earlier than expected..
I'll try and make the September event..
Old May 18, 2011 | 05:51 AM
  #573
slinger688's Avatar
slinger688
S-driver,
I think I will not go to cart in June either. My car may need more time to prep than one week seeing the amount if work required after the last open track.
Old May 18, 2011 | 04:42 PM
  #574
S-Driver's Avatar
S-Driver
Not sure when my next event will be right now...
Will have to check all the club schedules.
Old May 22, 2011 | 08:13 PM
  #575
slinger688's Avatar
slinger688
Eddie, I just signed for open track with patroon longest day June 13. Hopefully the car will behave well.
