Driver's School Discuss tips, techniques, and schools for enhancing the driver portion of the performance driving equation.
SCDA HPDE Schedule
Old Mar 18, 2011 | 07:44 AM
  #426
slinger688's Avatar
slinger688
Originally Posted by orangecrush
What coilovers are you running?
I will watch, things are unusually busy this year for me but I will be back out at the track.
Mark
Crap coils: Eibach multi-pro r1. Worse thing I ever bought for the mini by far. Even worse than those Alta parts I had which they have since discontinued.
Great coils: AST 5100 single adjustable with 450 in/lb front and back in race configuration.
Will write a review after a few track days and if I have the time.
Old Mar 21, 2011 | 04:38 PM
  #427
Eddie07S's Avatar
Eddie07S
Say, how do you guys handle the Trackmaster tech inspections? I don't have a problem with having a shop check the car, but the brake pads all have to be at 90%. At $200 a pop for Carbos on the front, that could get expensive. Right now it doesn't matter as I need new fronts anyway but I had to by backs also just so there would be no question. The backs should last at least 10 years with the way they wear but one year puts them beyond 90%.
Old Mar 21, 2011 | 04:59 PM
  #428
orangecrush's Avatar
orangecrush
I go to a local shop that I trust. They’re realistic about how much break wear you are allowed to have.
If I remember correctly, most tracks require the minimum pad thickness for driver’s education events 5.5 to 6mm. (90% doesn’t make sense unless they assume that all brake pad manufacturers start with the same thickness.... anotherwards, what is 90% on a porsche may not be 90% on a mini)
Mark
Old Mar 21, 2011 | 05:44 PM
  #429
Eddie07S's Avatar
Eddie07S
Mark
Ok, my bad...I went and rechecked the form and it says 75% to 100% of the original pad thickness
...https://www.trackmasters.com/2011doc...Inspection.pdf
I guess they must think that if a Mini uses a thinner pad than a porsche, then it must not wear as quickly. But at least this makes more sense than what I thought originally. I'll use the rear pads eventually
Old Mar 21, 2011 | 06:18 PM
  #430
S-Driver's Avatar
S-Driver
TM's does not do an actual tech inspection, it's on you. Just bring the form filled out.... Do it yourself or have a shop do it. I had a shop do it the first couple times I went and thereafter I did the checks myself. You start doing these events enough you'll know what to look for.
Old Mar 21, 2011 | 07:09 PM
  #431
slinger688's Avatar
slinger688
Hey guys,
I will be fixing my CVs next week so I think it would be possible to sign up for TM. My friend from work is also going with his bimmer.
So TM also does "big boy" techs.
Old Mar 21, 2011 | 07:12 PM
  #432
slinger688's Avatar
slinger688
Remember to bring extra pads. Those stock size pads only last 3 normal track days at the most.
I think I am going to buy an extra set for my Wilwood FSL (7420) from Dustin at autoxcooper.
Old Mar 21, 2011 | 07:14 PM
  #433
slinger688's Avatar
slinger688
Mark
Hey OC,
you thinking of joining us?
Old Mar 21, 2011 | 07:39 PM
  #434
S-Driver's Avatar
S-Driver
Not even "big boy' tech! They won't even look at your car..
Old Mar 21, 2011 | 07:56 PM
  #435
slinger688's Avatar
slinger688
Sounds like Bill P. with the no look tech.
Old Mar 21, 2011 | 08:09 PM
  #436
Eddie07S's Avatar
Eddie07S
Ya, already have an extra set of Carbo 12s that I got from someone I wonder who that nice guy is . Only a little used but slightly over heated That's not you, slinger, burning up a set of brakes is it, or is that just me
Old Mar 22, 2011 | 04:08 AM
  #437
slinger688's Avatar
slinger688
Hope you have a spare (one session only) when you need it. May be a little track worn.
Eddie, s-driver, gkp, VV, suss, OC, claymore are you guys interested in ti-shield heat shields for brakes? Supposed to bring down the temperature of your brake fluild with a Ti insulating layer between the brake pistons and the pad backing plate. Take a look at this:
http://hardbrakes.com/
We may be able to get a GB together.
Old Mar 22, 2011 | 04:37 PM
  #438
S-Driver's Avatar
S-Driver
Maybe.....what's the cost?
Old Mar 22, 2011 | 04:47 PM
  #439
slinger688's Avatar
slinger688
$85 retail with free shipping for any brake caliper. That is for the 5mm thickness. Not sure what the GB would be, but on their website, they said they would do a GB.
Old Mar 22, 2011 | 05:07 PM
  #440
Eddie07S's Avatar
Eddie07S
Just a slight correction - the shims are 0.5 mm thick or 0.020 inch by their web page. If I remember correctly Ti and SS have about the same thermal conductivity although Ti might be stronger. I was thinking of making a set from some SS sheet that I have
Old Mar 22, 2011 | 05:14 PM
  #441
slinger688's Avatar
slinger688
Yep, you are correct. 0.5 mm. You want to make some for us too? Since you are making them, can we get them in TI?
Old Mar 22, 2011 | 05:28 PM
  #442
Eddie07S's Avatar
Eddie07S
Change of subject to LRP - does anyone have any idea as to how loud an exhaust system can be and still meet their "quiet" system requirements? This is a quote from the SCDA page: " Please note that cars will need to be muffled to 86dB at all Lime Rock Park events". Does this mean that only factory exhausts are allowed?
I don't think my Invidia system will make it. 86db is really a pretty quiet system. Is there any way to test a car out? Or do you know if anyone has run an aftermarket system there?
Old Mar 22, 2011 | 06:23 PM
  #443
slinger688's Avatar
slinger688
There is no problem with many aftermarket exhausts. I ran an Stage 2 exhaust with my Lotus there and still managed to get it under the noise limit. And that was pretty loud in my judgment.
However, that said, there have been a few cases of cars that have been pulled off due to noise.
Old Mar 22, 2011 | 07:28 PM
  #444
S-Driver's Avatar
S-Driver
I have a Magnaflow and haven't had any problems there..
Old Mar 23, 2011 | 04:01 AM
  #445
ONEFASTGOKART's Avatar
ONEFASTGOKART
Going to do Events with SCDA this year...
Instead of doing events with COM Sports Car Club, I am going to do events with SCDA. I've already Registered for 3 events. Plan on doing a total of 5 events.
Here's the events I'm going to sign up for. * = Registered for this Event.
6/6 - NHMS*
7/11 - WGI*
8/8 - NHMS
8/29 - LRP*
10/27 - NHMS
I started doing track events last year with COM Sports Car Club. I did a Total of 3 days at NHMS.
According to the E-Mail I received from Ian Prout, I'll be in the Intermediate 1 Run Group for the Events I registered for.
I'll be using my GP, which will have a Stratmosphere Cat Back, WMW 17% S/C Pulley Package, New-Man Camshaft, Retune, Hotchkis 22mm Adjustable Rear Sway Bar, and Safety Products such as an Autopower Race Roll Bar. I'm going to change Harnesses. Currently using a Schroth Rallye Cross 4-Point but I will be changing to a Schroth Profi II FE 4-Point, which I'll add a Anti-Sub Cam Lock and Double Anti-Sub Straps to, for Track Events. Will also be purchasing a HANS Sport Model because I prefer to be Safer than Sorry!
I can't wait until I get to go to WGI and LRP!!
Just curious...Roughly, how many MINI Owners go to SCDA Events??
Thanks.
Old Mar 23, 2011 | 08:17 AM
  #446
slinger688's Avatar
slinger688
OnefastgoCart,
Not a lot of minis go the SCDA but there are a few. Sometimes when we have a planned meetup, there will be our usual crowd; s-driver, VV, GKP, suss, Eddie and myself. Sometimes we get the mpg crowd and claymore.
We are all track fanatics so it would be nice to meet up with you.
I have done comscc but find that they dedicate too much time to time trials, which entails lots of waiting around.
Ps: WGI and LRP are much better tracks than new Hampshire.
You have put in a whole bunch of stuff for three track days. Just worry about the line and seat time first and btw put in some good brakes.
Old Mar 23, 2011 | 02:22 PM
  #447
ONEFASTGOKART
Yeah..Forgot to mention, I'm also planning on getting a Wilwood 11.75 Race BBK. If not that one, then TSW MDM BBK
One thing I've noticed when it comes to COMSCC vs SCDA, is that the SCDA arranges drivers by Experience, and not by what Modifications they have, which COMSCC does.
Be nice to meet up with some other MINI owners who love to track there MINIS.
Old Mar 23, 2011 | 03:44 PM
  #448
orangecrush
I can’t comment. For the last 3 years, I’ve only run with groups that run by experience level regardless if you’re in a stock car or highly modified.
I think as a rule of thumb, typically with higher experience, more mods come with the car anyways.
According to that thought, I should be one of the most advanced drivers here....lol.
Mark
Old Mar 23, 2011 | 04:04 PM
  #449
slinger688's Avatar
slinger688
That is because COMSCC runs time trials so they classify the participants in car classes similar to those used in SCCA. They award prizes at the end of the time trials to the faster drivers by car class. You cannot have a supercharged viper running in the same class as a plain Miata if you have a prize on the line.
SCDA just runs DE with no prize for coming in first or last or anything in between, so they run by experience.
Old Mar 23, 2011 | 04:30 PM
  #450
S-Driver's Avatar
S-Driver
Yeah.....brake upgrade is a must. Since you have a GP you can route the ducking as well without having to ditch the factory fog lights.
The 11.75" brake kit is nice as it will allow you to run 15" rims...that's what I do. Lighter and cheaper...
Also.....we're trying to get 6 people to sign up for a track day @ LRP on June 22nd with CART. If we can get 6 then the cost will be under $300. It's 3 run sessions, a TT, and then most likely an open track after that.
