Drag Racing 1/8 and 1/4 Mile MINI Runs
Fastest non-nitrous or twincharged MINI
Old Feb 5, 2006 | 02:05 PM
  #151
isellem's Avatar
isellem
lets get back to the topic at hand... read the name of the thread!
By no means have i ever claimed that i am the most educated drag racer on the planet... but apparently you think you i am... well i guess i cant change your preception on that
also you say that we are the 3rd fastest mini and then 3rd runner up... so are we 3rd or 4th? 1st runner up is 2nd place... 2nd runner up is 3rd place... way to go
and you like any form of motorsports you drag race by classes... we are a street car (full weight, ac, interior etc...) non nitrous, non turboed MINI on street tires...
Until you or anyone else can post times even close to ours... we are the undisputed KING... CHAMPION... WINNER... BEST... FASTEST... QUICKEST... MINI in our category!
THANKS FOR PLAYING!
Old Feb 5, 2006 | 02:15 PM
  #152
isellem's Avatar
isellem
wow you must have woken up on the wrong side... By no means have i ever claimed to be the most knowledgeable drag racer on the planet... I welcome everyones input that is logical!
Old Feb 5, 2006 | 02:16 PM
  #153
dave's Avatar
dave
pug poo picker-upper
Some posts have been removed from this thread as a result of some highly unusual (to say the least) posting behavior on the part of a poster. Those posts quoting that member have also been removed.
back to topic
Old Feb 5, 2006 | 02:37 PM
  #154
isellem's Avatar
isellem
back to topic
you the man
Old Feb 5, 2006 | 07:43 PM
  #155
1FSTMINI's Avatar
1FSTMINI
What the heck did i miss. :impatient
Well I'm looking to see what it does on the bottle so you can keep your title....For now!
Old Feb 6, 2006 | 08:00 AM
  #156
isellem's Avatar
isellem
a bunch of nonsense...
i can't wait to see your times! Im hoping for 12's out of you!
Old Feb 6, 2006 | 10:12 AM
  #157
1FSTMINI's Avatar
1FSTMINI
You n me both....But im not poppin off at the mouth about times cuz i have no idea what ill run now....just from what ive seen is all i can say on how fast i "think" it is.
Old Feb 6, 2006 | 12:23 PM
  #158
isellem's Avatar
isellem
good man good man... you are obviously a REAL drag racer
Old Feb 7, 2006 | 11:24 AM
  #159
Paul Webster's Avatar
Paul Webster
The last couple of pages has nearly made me want to take the car out again, but alas I have to concentrate on the business before I can go and play again LOL
Old Feb 7, 2006 | 11:59 AM
  #160
Tüls's Avatar
Tüls
Turbius Maximus
do it....do it....do it....
Old Feb 7, 2006 | 12:39 PM
  #161
1FSTMINI's Avatar
1FSTMINI
Well i got the bottle....just have to find the time to put it in.
Called the place i bought it from and got a few different HP adjustments for the pills. I was gonna start off with a 40 shot and go from there.
Old Feb 7, 2006 | 03:41 PM
  #162
isellem's Avatar
isellem
40????
id start with 75
but seriously... as long as the injectors can handle it (i don't know if you have a wet shot or a dry shot...) do a 75 shot...
Old Feb 9, 2006 | 06:56 AM
  #163
kwkshift's Avatar
kwkshift
do a 75 shot...
...on the first stage....
Old Feb 9, 2006 | 01:44 PM
  #164
isellem's Avatar
isellem
150 on the big end!
Old Feb 9, 2006 | 04:28 PM
  #165
1FSTMINI's Avatar
1FSTMINI
Im runnin 380s and its a wet kit.
i was gonna start with nos .035 fuel .016.....then try nos .040 fuel .021
i still have to check the fuel pressure at WOT to figure out the fuel pill.
Old Feb 9, 2006 | 04:32 PM
  #166
isellem's Avatar
isellem
start with a 75 shot...
come on man man up!
Old Feb 9, 2006 | 04:46 PM
  #167
Tüls's Avatar
Tüls
Turbius Maximus
.40 .21 ....that's a pretty good sized shot right there.....becarful...LOL
Old Feb 10, 2006 | 04:46 AM
  #168
1FSTMINI's Avatar
1FSTMINI
Thats a 75shot
Old Feb 10, 2006 | 07:13 AM
  #169
isellem's Avatar
isellem
thats what i would start with!!!
Old Feb 10, 2006 | 04:03 PM
  #170
Paul Webster
57psi at WOT with stock injectors
Old Feb 11, 2006 | 06:52 AM
  #171
1FSTMINI's Avatar
1FSTMINI
Thats what someone also told me.....So a .040 NOS .020 FUEL will be fine for a 75shot. Im runnin 380cc injectors.
You guys dont think i have to change anything with the MTH file? I personally dont think so....I can always play with the fuel pills to compensate either way for fuel.
Old Feb 11, 2006 | 07:23 AM
  #172
Paul Webster
I would personally go and check it yourself with an accurate guage, all I can comment on is what we've observed and accomplished with ours.
With the mods you've done you should be producing more hp than our stock engine and thus using more fuel, the stock pump might cope with your nitrous hit and the fuel you are already using.
You should have a fuel pressure guage which is visable when using nitrous anyway so you can monitor the fuel pressure just in case it does drop off, could save you loads of $$$ in the end.
Good Luck
Old Feb 11, 2006 | 08:22 AM
  #173
Tüls's Avatar
Tüls
Turbius Maximus
the only thing I would say about having the MTH is watch your timing...that could be very bad....
Old Feb 11, 2006 | 11:22 AM
  #174
Paul Webster
On a stock ecu under normal wot its 24 deg, with nitrous its 16 deg
I presume that even if the MTH map alters the stock timing when the nitrous / fuel goes in it'll still wind itself back to 16
Old Feb 11, 2006 | 01:58 PM
  #175
Tüls's Avatar
Tüls
Turbius Maximus
kewl...just checking...I have only check Data on my TC timing...ofcourse what fuel you are using helps too....
