Best polish for glass?
Old Mar 31, 2014 | 07:57 PM
navybsn's Avatar
navybsn
Not cleaner, but actual 8 years worth of build up on a window polish. I've read mediocre reviews on everything. Anybody have a secret recipe for perfect glass?
Old Mar 31, 2014 | 08:01 PM
danjreed's Avatar
danjreed
Cerium Oxide..
Old Mar 31, 2014 | 09:20 PM
Fly'n Brick's Avatar
Fly'n Brick
http://www.griotsgarage.com/category...urPicks&page=1
Check both pages. Really good stuff.
Old Apr 1, 2014 | 08:26 AM
Aspen's Avatar
Aspen
I really like Auto Glymm Glass Polish. It strips off gunk then dries to a powdery film that just wipes off streak free. The only downside is dust, so do your interior glass first then wipe down the dash and door panels.
Old Apr 1, 2014 | 02:39 PM
Capt_bj's Avatar
Capt_bj
talking exterior here:
toothpaste . . . .
not gel
paste
mint is optional
you want a gentle rubbing compound .... that's toothpaste
you want a gentle abrasive to cut thru the crud and not damage the glass
on the other hand
I run over all my glass with a razor blade (window scraper) every few months. You'd be surprised what my blades pull off . . .
side bar: windshield wipers work WAY better on CLEAN glass ....
Old Apr 1, 2014 | 05:33 PM
kg4fxg's Avatar
kg4fxg
Griots
I may not know much, but I have been extremely pleased with Griots. A good place to start for a one stop shop in detailing.
Old Apr 30, 2014 | 10:38 AM
Striped Toad's Avatar
Striped Toad
I clay bar (exterior) mine. Then Mothers cleaner wax inside and out.
Old Apr 30, 2014 | 01:53 PM
kyoo's Avatar
kyoo
in for this - considering clay bar - i made the mistake of using that rain-x stuff, wipers stutter on the glass now
Old May 2, 2014 | 06:42 PM
navybsn's Avatar
navybsn
I just ordered Driven glass cleaner and will give it a shot. Everything out there has mixed reviews so I figured why not. Going to hit it with a Nanoskin fine sponge, then Driven, then Griot's Glass Sealant. The glass probably isn't as dirty as I think, but it's just never been a priority.
Old May 2, 2014 | 08:53 PM
Fly'n Brick
Feedback on the glass sealant would be appreciated, Boats. I've not used any of that stuff.
Old May 3, 2014 | 05:17 AM
JPMM's Avatar
JPMM
I have used this stuff, its really good, had water stains on house windows that would not come off ,grabbed my bottle and wow. After using it on a car the glass feels like it has been clayed. Get the 3" white pads that are for glass polishing and the manual, by hand holder. too.
Old May 3, 2014 | 05:50 AM
Gil-galad's Avatar
Gil-galad
+1
Old May 3, 2014 | 08:03 AM
jimba's Avatar
jimba
Originally Posted by Gil-galad
+1
+2
Old May 10, 2014 | 01:42 PM
navybsn's Avatar
navybsn
So I did the front and back glass on both cars with the following process:
1) Nanoskin fine grade sponge with ONR as lube
2) Driven glass polish
3) Griots window cleaner
4) Griots glass sealant
Pretty decent results considering I had never done it before. Didn't remove every water spot, but definitely cleared up the windows. Noticed some small chips/pits in both windshields. Might give it a second go later and will also give it a shot on the side glass. New wipers all around. I've never been a detail freak but I do keep my cars pretty clean. Not too difficult to do once every few months. Took about 1.5 hours for both cars. Definitely worth the trouble.
Old May 10, 2014 | 02:46 PM
Capt_bj's Avatar
Capt_bj
vinegar on the inside and rubbing compound on the outside . .
next question . . .
Old Sep 30, 2014 | 06:59 AM
davidg5700's Avatar
davidg5700
next question . . .
I've got a question for you, Capt....
Would something like Meguiar's Ultimate compound work?
I've got microchips on the windshield I'd like to make less noticeable and have a bottle of that on my shelf to try.
Old Oct 3, 2014 | 04:31 AM
D.D.'s Avatar
D.D.
Be VERY careful using any of these products on boats. Hatches and ports are usually a plastic derivitive, lexan. These may be coated as a protectant. ANY abrasive will cut through the protectant and remove it, therby rendering it useless. The hatch will look good almost perfect. However, what you will now need to do the remainder of the hatch's life is constantly remove salt, rain, water spots. You removed the sealer and the hatch will now stain easier.
Old Oct 4, 2014 | 04:36 PM
Capt_bj's Avatar
Capt_bj
rubbing compound will get rid of crud on the glass quickly
but to get rid of 'micro chips' ... you are asking the compound to rub the glass back to a smooth surface ... rub off the surface to the pit depth? Bad plan IMO.
I tried it on my 79 with special pads and compounds and gave up LONG b4 I had success . . .
Old Oct 5, 2014 | 11:58 AM
SC R60's Avatar
SC R60
I've seen a few machine w/compound videos. That's viable.
Heard the claybar method works too.
I cannot recommend it since I haven't tried it, but I've heard of using 0000 steel wool by hand on the windshield to polish it. I can't remember if you glass cleaner or other substance as a lube along with though
Old Oct 6, 2014 | 06:51 AM
davidg5700's Avatar
davidg5700
Yeah, I would agree that taking the surface down to pit depth is inadvisable. What I am wondering is if the compound will help to take off the sharp edges of the chips that have a tendency to catch the light and make the imperfections more visible.
I really don't have a few weeks to dedicate to shaving a quarter of a millimeter or so off the glass.
Old May 12, 2015 | 03:53 PM
fastzombie's Avatar
fastzombie
I have never tried a clay bar, have people had success with this method?
Old May 12, 2015 | 05:21 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
vinegar on the inside and rubbing compound on the outside . . next question . . .
vinegar & baking soda is about the most effective cleaning combo and it is crazy cheap.
Old Jun 23, 2015 | 06:31 AM
grussell's Avatar
grussell
I claybar'd my entire Mini last weekend including all glass. I used a spraybottle with water and the clay bar. I washed the car and while still wet used the claybar and the spray bottle when needed. followed with a full wax job. The results were excellent.
Old Jun 29, 2015 | 03:34 AM
r7denz's Avatar
r7denz
Ceriglass is one of my favorites. It can be applied by hand if you don't have a buffer, and this polish can remove light scratches on a windshield.
Lex2008
How to
47
Jun 15, 2022 06:18 AM
OutMotoring
Mar 3, 2017 06:29 AM
bahman
Aug 6, 2016 07:19 AM
daidaibi
Mar 21, 2016 08:25 AM
Ryephile
Detailing 101
Sep 16, 2015 06:32 AM
