New Product: Dab N' Smear
Old Sep 29, 2008 | 03:13 PM
UKDragon's Avatar
UKDragon
Iguana Tamer
I saw this commercial this weekend and was considering trying this out.
Has anyone else used this yet? What are your thoughts?
I haven't had much luck with the old 'paint and toothpick' technique myself
so this looked like a good option..IF it works!
http://www.dabnsmear.com/Default.asp?bhcp=1
Old Sep 29, 2008 | 03:29 PM
IzzyG's Avatar
IzzyG
Eh, sounds too good to be true. Chips are often lower than the unchipped surface so it doesn't make sense.
R56 Ed's Avatar
R56 Ed
Wow... that stuff looks great! I wonder if we could accomplish the same thing by using our normal touch up paint followed 30 seconds later by a soft cloth with a bit of solvent on it? I've got a few chips and will have to give it a try. Thanks for the great idea!
Old Sep 29, 2008 | 03:34 PM
MichaelSF's Avatar
MichaelSF
This is a remade or same product as the old Dr. Color Chip. Some OK results with darker flat colors, but NONE of the results or application of the product were as easy as ads make it appear.
I would pass. Most products of these type are junk. Why the rebadge from the old product? Usually that means word got out that the original was junk so the sellers rename it and try to sell the same snake oil under a different name.
IMHO
Old Sep 29, 2008 | 03:35 PM
OctaneGuy's Avatar
OctaneGuy
Always be wary of any demonstration when they don't show you an extreme closeup of the repair. Touch up paint applied to a car can make it look great from 2 feet away. Closer and you'll see the blob.
There are many products on the market that use this solvent approach. Langka and Dr. Color Chip do that. I only have experience with Langka and it'll take all the touchup off if you aren't careful when using it.
Richard
Old Sep 29, 2008 | 03:47 PM
UKDragon's Avatar
UKDragon
Iguana Tamer
Hrm. Thanks for the advice. Guess I'll just let my brother in law
test it out on his Mazda 6 first
Old Sep 29, 2008 | 04:23 PM
kenchan's Avatar
kenchan
^^ sounds like a plan.
Old Sep 29, 2008 | 10:54 PM
MichaelSF's Avatar
MichaelSF
Hell, you should have said that in the first place. That's what you should do.
Old Oct 4, 2008 | 07:35 PM
kenchan's Avatar
kenchan
so how did this gimicky door to door salesman product turn out?
Old Oct 5, 2008 | 05:44 AM
leicaguy's Avatar
leicaguy
Notice that you can not enlarge the video?
Old Oct 5, 2008 | 03:04 PM
kenchan's Avatar
kenchan
well yah, you're only suppose to look at the car from 15ft away.
Old Oct 5, 2008 | 03:05 PM
UKDragon's Avatar
UKDragon
Iguana Tamer
Yeah, their TV commercial isn't much better.
Old Oct 15, 2008 | 10:25 PM
eR1c's Avatar
eR1c
I've used dr color chip on two cars. I had better success on a flat color (red) than on my dark silver Mini. I also think the lack of primer on the Mini makes filling in chips difficult.
Old Oct 17, 2008 | 08:36 PM
lotsie's Avatar
lotsie
MINIs don't have primer
Mark
Old Oct 17, 2008 | 08:53 PM
OctaneGuy's Avatar
OctaneGuy
The second gen MINIs use the IPP paint process that eliminates the primer coat. Essentially there are two base coats and a clear. The savings to MINI is no Primer or need to bake the primer...saves money and energy.
Mark
Old Oct 18, 2008 | 08:02 AM
lotsie's Avatar
lotsie
Thanks OG, didn't know that. So is the first colour coat bonded somehow?
Mark
Old Oct 18, 2008 | 08:22 AM
OctaneGuy's Avatar
OctaneGuy
Yep the first base coat acts as a primer, the second coat of that base coat has the color and depth properties, then the third coat is the clear. They call it a wet on wet application. I'm not 100% certain that the Oxford plant uses this same process as I read about the IPP process from BASF's procedure, but it sounds the same. From what I understand, the IPP process is just as good as the traditional primer method, but saves on energy because normally they would primer it, then oven bake it--that step is eliiminated. It also means the manufacturer can push more cars out faster to assembly, and it saves them energy costs as well.
The only downside I've read is that sound dampening isn't as effective on non primered cars--but our MINI's aren't all that quiet, so it's not much of a conern.
Richard
Mark
Old Oct 18, 2008 | 09:11 AM
MichaelSF's Avatar
MichaelSF
Originally Posted by OctaneGuy
...our MINI's aren't all that quiet, so it's not much of a concern. Richard
My soft top is very quiet. So I don't know what all the complaints are about the MINI's paint not being quiet.
But then again, I have had a hearing loss all my life, maybe that has something to do with it
Old Oct 18, 2008 | 09:14 AM
OctaneGuy's Avatar
OctaneGuy
Quiet is a relative term and I was comparing it to luxury cars like Lexus' that isolate you from the road.
Old Oct 18, 2008 | 09:25 AM
MichaelSF's Avatar
MichaelSF
I "hear you" there. My 740i was living room quiet. I think what makes my MINI more quiet than others is my tires and wheels are stock. Even with my hearing loss [THAT makes all things relative, for sure] I think my soft top is still surprisingly quiet for a convertible.
By the way, I want one of those washers [early XMAS for myself], can you PM me on where and how I should do that. Thanks!!!
Old Oct 18, 2008 | 09:27 AM
OctaneGuy's Avatar
OctaneGuy
Sure PM coming.
Old Oct 18, 2008 | 11:32 AM
lotsie's Avatar
lotsie
We just got a new Clubman, and primer or no primer, it is WAY quieter than my 03.
So is there no baking of the paint? What about off-gassing, should new owners wait to apply wax? Ours was a launch edition, so it has done any gassing it would need to, but what about those that are only a month or so out of the factory?
Mark
Old Oct 18, 2008 | 12:47 PM
OctaneGuy's Avatar
OctaneGuy
This is a misconception. The paint is still baked, but only once. Normally it's baked after the primer stage, then base and clear are added then backed again.
The 2nd gens are baked only after the clear. No special attention is needed upon receiving the car because for all intents and purposes its the same.
Richard
Mark
Old Oct 18, 2008 | 02:11 PM
lotsie's Avatar
lotsie
So it's half-baked on the 2nd gens.
Thanks for the info Richard
Mark
Jerome R Jr W
Sep 29, 2015 11:42 AM
EVMini
Sep 28, 2015 10:20 AM
stellaherself
Sep 16, 2015 06:56 AM
mxr662
Aug 31, 2015 02:50 PM
Shane Wendel
Electrical
Aug 20, 2015 06:50 AM
