Diluting Hydro w/ water?
Old Jun 26, 2007 | 07:27 PM
k_h_d's Avatar
k_h_d
This is mostly for Heather but if anyones else has an answer please chime in.
Would one see benefit from using Hydro on a dry car and diluting it with some ratio of water / hydro? Would it give the great shine and filling capabilities and act like a quick detailer? I really like its results on windows and the paint and it would make a nice spray to use...
Oh also... Is its smell engineered or is it just a bi-product of the different chemicals and polymers involved? I have to say it is probably my 2nd most favorite smelling product behind Slick. Well, it may actually smell better than slick, that is a tough one.
Old Jun 26, 2007 | 08:21 PM
kenchan's Avatar
kenchan
khd- no, you have to buy a gallon and use full strength.
Old Jun 27, 2007 | 04:28 AM
k_h_d's Avatar
k_h_d
I am getting ready to buy a gallon. BUT since you are suppose to use it on a wet car anyways so that it dilutes it self I was wondering what the ratio would be to dilute it directly and still be effective
Old Jun 27, 2007 | 05:37 AM
kenchan's Avatar
kenchan
i know where you're coming. but Hydro can be used wet or dry.
the concentration level varies from how wet your car is. to get the
optimum, i say just use it 100% concentration if on a dry surface.
Old Jun 27, 2007 | 06:23 AM
Loony2N's Avatar
Loony2N
Mr. Hydro, how much rubbing in is involved in using it dry?
Old Jun 27, 2007 | 09:29 AM
kenchan's Avatar
kenchan
no rubbing! you can gently work the product into the paint to spread
evenly. no rubbing or buffing needed.
oh wait, were you referring to me?
Old Jun 27, 2007 | 10:32 AM
Prima Car Care's Avatar
Prima Car Care
Would one see benefit from using Hydro on a dry car and diluting it with some ratio of water / hydro? Would it give the great shine and filling capabilities and act like a quick detailer? I really its results on windows and the paint and it would make a nice spray to use...
No, you should not dilute Hydro with water. It just isn't designed to work that way, despite the logic based on how Hydro mixes with the water on the car when used wet.
Instead, simply use less Hydro when using it on a dry surface. You'll find it spreads quite easily so you don't have to use much at all! This achieves the same goal of using it like a QD by mixing it with water but it will function much better this way.
-Heather
Old Jun 27, 2007 | 10:33 AM
Loony2N's Avatar
Loony2N
Like you had to ask...
USNAE2
16
Jun 17, 2022 07:17 AM
PsychoRallye
21
Feb 17, 2019 06:08 AM
ian260
Mar 29, 2017 06:08 AM
vulkandino
Oct 31, 2015 08:29 PM
martinb
Oct 7, 2015 05:00 PM
