Wheel fitment question...
Old May 5, 2011 | 03:39 PM
KidLuck's Avatar
KidLuck
Hi, can somebody please help me with this. I'm not really sure how offset works and I've read through as much as I can, but... I want to put a set of 20" x 8.5" wheels on my countryman s all4. Tire Rack shows wheels that are compatible at that size, but I'm looking at different wheels and I'm not sure why they would or wouldn't fit.
The wheels I want to put on are:
Offset: +35mm
Backspacing: 6.06"
Bolt Pattern: 5-120
The compatible wheels on Tire Rack are:
Offset: 45mm
Backspacing: 6.61"
Bolt Pattern: 5-120
Don't really know how spacers work, but if somebody could help me I'd greatly appreciate it... Thanks.
Old May 5, 2011 | 04:13 PM
iwashmycar's Avatar
iwashmycar
The et35 (mm) wheels are going to stick out 10mm further than the et45's.
So you will not need spacers. One centimeter isnt much of anything really. Puts them out closer to the arches is all.
Stock Mini coupes are usually et48 for example. An et35-38 will fit just fine on them, and also look better that way, vs. tucked up in the fenders
Im not sure what a stock Countryman wheel width is either... but that will help push them out a tad if the stock rims are narrower than 8.5
edit: looks like stock are 7.5" wide. Thus if you were to get the 20's with the same 45mm offset, then they would stick both in AND out 1/2" (making up the extra inch in rim width). With the 10mm helping you out, it should pretty much stick out that extra 3/4" and your inner wheel clearance will be about the same (or maybe 1/4" less)
Old May 5, 2011 | 04:55 PM
KidLuck's Avatar
KidLuck
Ok. So if I go with the 20s (+35 offset) they should fit without spacers... They'll stick out a bit (3/4") and tighten up my wheel well a bit... Do you think they'll rub at full turn or bottom out easily? I know you can't tell for sure, and thanks so much for your help.
Old May 5, 2011 | 05:56 PM
iwashmycar's Avatar
iwashmycar
Yeah I don't know for sure.... Usually at any stock height there is a ton of room. Itll all depend on tires. You can easily make a rim/ tire combo equal the diameter of the stockers. You could always go turn full lock and see if you have a little to spare with the extra width.
You can usually add some width without any rubs. I would venture to guess the Countryman is still rather unclaimed territory when it comes to wheel fitment.
To answer your question, yes, I am nearly completely certain that with the lower offset making up for the rim width, that they'll fit just fine, long as you don't go adding too much rubber!
Old May 6, 2011 | 03:04 AM
KidLuck's Avatar
KidLuck
Great! Thanks for your input. I'll post some pics when I'm done ...
Old Jul 18, 2011 | 01:57 PM
KidLuck's Avatar
KidLuck
20's fit nice
After three orders, two cancelations and way too much time on the phone with wheel/tire techs, I got my baby some twenty inch shoes...
Attached Thumbnails Wheel fitment question...-img_2149.jpg   Wheel fitment question...-img_4516.jpg   Wheel fitment question...-img_4514.jpg
Old Jul 18, 2011 | 02:23 PM
GeoffreyM's Avatar
GeoffreyM
Looks good!
Any rubbing issues anywhere? What tires? Are they run-flats? How's the ride and what did you take off?
I think that's it...........:-)
Old Jul 18, 2011 | 02:35 PM
KidLuck's Avatar
KidLuck
No rubbing. The new 20" setup is nearly the same overall diameter and 225 vs. 205 width. I'm using Hankook 225/35/20 Ventus V12 non-runflats and the ride is stiff but still softer than the stock runflats.
Old Jul 19, 2011 | 12:04 PM
KiwiRob's Avatar
KiwiRob
What brand are your wheels, they look great, however I think you need to lower it a bit.
Old Jul 19, 2011 | 02:12 PM
KidLuck's Avatar
KidLuck
They're 20" TSW Nurburgring in matte gunmetal.
I was expecting the height to be way taller with the 20s, but it ended up sitting just right for me. I like the height. I live about 70 miles north of NYC and the roads can get nasty (rough roads, potholes, gravel/dirt roads) Any lower might turn out to be a nightmare. The thin rubber is a bit scary, but after a few decent pothole dives the wheels remain unscathed...
Old Jul 19, 2011 | 04:50 PM
JudgeS's Avatar
JudgeS
Why you changed the wheels not the suspension, the overall wheel diameter if done right should be basically the same as your stock 17s or 18s by having a tire with a lower profile (sidewall), otherwise your totally wrecking your spedo/odo accuracy.
Looks good although I don't think I'd go bigger than 19s.
Old Jul 20, 2011 | 03:36 PM
KidLuck's Avatar
KidLuck
Yeah, Staten Island is wheel hell... I wouldn't waste the $ when you know the wheels will get destroyed.
Old Jul 20, 2011 | 09:32 PM
nckash91's Avatar
nckash91
just had a quick question will a 20 off set fit on a 07 mini cooper s
Old Sep 6, 2011 | 10:53 PM
Tom W's Avatar
Tom W
So what are the wheel specs that you went with? Width/Offset etc
Old Sep 7, 2011 | 07:15 PM
hoppes-no9's Avatar
hoppes-no9
Wow, looks great!
Rennfahrer555
General Discussion
38
Nov 1, 2022 03:04 PM
Kimolaoha
Dec 5, 2020 09:32 PM
ASRman
Aug 13, 2015 09:33 AM
Rennfahrer555
Aug 13, 2015 09:07 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
