Cooper (non S) Modifications specific to the MINI Cooper (R50).
curious
Old Sep 19, 2006 | 08:44 PM
justintime's Avatar
justintime
curious
could you put an intercooler into the MC with it still being NA? I wonder what it would dooo
Old Sep 19, 2006 | 08:56 PM
ScottRiqui's Avatar
ScottRiqui
I wouldn't do much of anything. The reason the intercooler works on the MCS is that the compressed air that comes out of the supercharger is *much* hotter than the outside air. This means that the outside air flowing over/through the intercooler will cool off the hotter compressed air inside the intercooler. The heat transfer only occurs because of the temperature difference.
In a naturally-aspirated engine, the air flowing through the intake tract won't be much hotter than the outside air. Without the temperature difference, there's no (or very little) heat transfer from the intake air to the outside air.
Scott
Old Sep 19, 2006 | 08:58 PM
justintime's Avatar
justintime
exactly, so with the intercooler on the MC would the air almost be too cold? is there such thing as to cold hahah. it seems like it would help..
Old Sep 19, 2006 | 09:08 PM
ScottRiqui's Avatar
ScottRiqui
No, the intercooler wouldn't do anything. If the air inside the intercooler and the outside air are close to the same temperature, then there's no significant heat transfer, and the intercooler is basically just a pipe.
An intercooler only works if the air passing through the inside of it is a lot hotter than the air flowing around the outside of it. This is true in a supercharged or turbocharged engine, but not in a naturally-aspirated one.
Scott
Old Sep 19, 2006 | 09:23 PM
k-huevo's Avatar
k-huevo
An intercooler would have a detrimental effect. Flow would be interrupted/slowed by the impeding core fins. On a NA motor smooth transitions in the flow path are more crucial than for FI with only atmospheric pressure to move air into the head.
Old Sep 19, 2006 | 11:25 PM
Crusoe's Avatar
Crusoe
If you want cool air, duct in some air off your AC into your intake chamber.
Old Sep 19, 2006 | 11:58 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
For the MC, better than any intercooler alone would be a turbo kit.
Alternatively, if you have already done the easy upgrades like:
Intake
Cat-back exhaust
plug wires
ECU tuning
Larger throttle body
Then next upgrades for power would be:
Ported and polished cylinder heads
Race Camshaft
Header with race catalytic converter
Other upgrades:
Quaife differential
Light weight rims and wider sticky tires
Old Sep 20, 2006 | 02:03 PM
justintime's Avatar
justintime
I was just curious what an intercooler would do to an NA car haha, thanks guys. I wasnt actually wanting one :p
Mazarin
Electrical
Dec 7, 2015 08:23 AM
USA-RET
Nov 9, 2015 07:27 PM
USA-RET
Oct 27, 2015 10:42 AM
simo711
Oct 1, 2015 05:36 AM
BushOner
Sep 29, 2015 08:42 AM
