Cooper (non S) Modifications specific to the MINI Cooper (R50).
New Exhaust for MC. What would you like?
Old Jan 28, 2007 | 07:59 AM
  #376
erickvonzipper's Avatar
erickvonzipper
Originally Posted by jq77
HOLY CRAP! I would never get under a car unless it was supported by 4 (count them) jackstands. Dude don't give it another try...just leave it up to the pro's. It will probably cost under $100...
Four jack stands? That's much less stable than having two tires on the ground. Think about it.
Zip
Old Jan 28, 2007 | 08:48 AM
  #377
jq77's Avatar
jq77
True statement
That's a very true statement. I was thinking that the entire car would have to be up in the air.
Old Jan 28, 2007 | 09:04 AM
  #378
erickvonzipper
At any rate, I have given up. I tried everything I have to loosen those two bolts and they didn't budge. It goes into the shop this week unless kenchan comes up with an idea in the 'little problem' thread.
Zip
Old Jan 28, 2007 | 09:11 AM
  #379
jq77's Avatar
jq77
Probably...
Probably what's going to happen is that you will take it in to the shop this week and because you have been blasting the bolts with WD-40, when the car gets to the shop, he'll be able to knock it right out. Your efforts will not have gone to waste, and the important thing any way, is the end result.
Good luck! I'll look forward to seeing if you're happy with the finished product.
Old Jan 28, 2007 | 10:11 AM
  #380
erickvonzipper
Thanks, and I'll letcha all know when it's done.
Zip
Old Jan 29, 2007 | 06:05 AM
  #381
Aquasar's Avatar
Aquasar
I guess I was just lucky. I and was able to take it to a shop and do it myself while it was on a lift. The lift cost me $5 for about an hour. I used a breaker bar on those bolts. They were very tight I beleive they are set to 44lbs.
Art
Old Jan 29, 2007 | 06:29 AM
  #382
Foxtrot_Xray's Avatar
Foxtrot_Xray
I was looking at a parts diagram for the exhaust stuff (hey, what can I say, I'm anxious!) and noticed that on MY car, at least, there is a gasket referenced where it mounts to the cat. Obviously noone had to replace this, otherwise someone would have brought it up. How rusty were those bolts, and is there a chance I'd have to replace them after 4.5 years? (I don't want to get it up on a lift, get those bolts removed and not have replacements if I need them! )
[Edit: Nevermind! It arrived today, I opened it up and everything's in there! Mucho cool! It's going on today! ]
Cheers!
Me - still eagerly awaiting.
Old Jan 29, 2007 | 12:07 PM
  #383
Foxtrot_Xray
Got it installed, must say.. I like it! I'm still getting used to it (4 years with the stock, and never having anything BEFORE the MINI that had a setup worthy of a better exhaust), but it's nice. Since work got slammed today, I let my shop put it on, they commented how well it was put together and it went in solidly. There's JUST enough of the tip sticking out to show it off, and the "Megan" logo is on the side, underneath. (Not good or bad, but something I noticed.)
FOr me, it is kinda loud inside, especially cruising 'round 50Mph. However, I'm owing that to the fact I removed my back seats and haven't put in soundproofing yet. Other speeds - especially idling or slowing down - it's rather quiet. Idling is a barely noticeable rumble, very nice. At higher RPMs, I worry that it sounds too much like a ricer, but again that may be because I don't have soundproofing in the back yet.
Very good job, MR. I couldn't have picked anything better.
Old Jan 29, 2007 | 12:28 PM
  #384
Aquasar's Avatar
Aquasar
Congradulations... I am glad you like it. It took me a couple days to get used to the increased noise level but I still have the back seats. But I find that the increased noise calms down when you aren't using your lead foot. let me know how you mileage does. Mine has increased by a few mpgs.
Art
Old Jan 29, 2007 | 03:54 PM
  #385
smoothracing's Avatar
smoothracing
I love it.WOW it sounds great too
Old Jan 29, 2007 | 04:06 PM
  #386
Megan Racing's Avatar
Megan Racing
Vendor
*Happy Tears*
Old Feb 3, 2007 | 01:46 PM
  #387
Uncle_John's Avatar
Uncle_John
Mine sounds GOOD . . . Happy MINI!
Old Feb 3, 2007 | 02:37 PM
  #388
boolean_bones's Avatar
boolean_bones
You had better be at Custard Tuesday.
Old Feb 3, 2007 | 08:48 PM
  #389
erickvonzipper
Zip
There are two threads on the Megan system that cover some of the same ground. I posted the following in the other thread. I said in this thread (above) that I would update you when it was done, so:
<< I just finished my install. It was very staright forward. Sounds great. After the computer seemingly took a few seconds to adjust to the change, I took the car around the block, and there definitely is more zip (pardon the pun). Oh, and did I mention it sounds great? >>
Zip
Old Feb 8, 2007 | 03:03 PM
  #390
Konquest's Avatar
Konquest
I just finished installing the exhaust and it works great. I just had a question about adjusting the position of the exhaust tip. Right now its rubbing against the right side of the bumper. Is there an easy way to move it to the left so its centered?
Old Feb 21, 2007 | 06:44 PM
  #391
Foxtrot_Xray
I just had my Mini up on a lift since the muffler's been installed, and decided to take advantage of it and poke. My rattle seems to be coming from the fact that the muffler is almost pressed up against the heat shield - however, I have plenty of clearance around the tip and the bumper. The rattle happens very, very infrequently, and when it does, it's not too noticable, so I'm not messing with it.
All in all, I've gotten a few comments, including a few coworkers stating that the sound is 'unique' (after I asked them if it was loud)..
Old Feb 21, 2007 | 11:12 PM
  #392
retroom's Avatar
retroom
Good or Bad?
By saying unique is that a "Good" or a "Bad" ? :impatient
retroom
Old Feb 22, 2007 | 06:35 AM
  #393
erickvonzipper
Well, here's a different take on it.
After I got mine in, my neighbor, who is slightly older than me, said that my car sounded the way a sports car is supposed to sound, like a proper British sports car. That was about the best endorsement I could hope to hear.
Zip
Old Feb 22, 2007 | 08:33 AM
  #394
Foxtrot_Xray
Oh, they meant it in a good way, definitely.
Old Feb 22, 2007 | 07:04 PM
  #395
Uncle_John's Avatar
Uncle_John
Zip
Interesting, I had a guy at work compare it to an old MGB with an Abarth. I've had mine on for three weeks now and I'm hooked on the sound. Last couple of days, it's been in the high 70s and I've had a chance to hear it with the roof open and windows down. It's good.
Old Feb 23, 2007 | 04:55 AM
  #396
dickdavid's Avatar
dickdavid
...Last couple of days, it's been in the high 70s and I've had a chance to hear it with the roof open and windows down. It's good.
That's what I've been doing as well. It's awesome.
Old Mar 7, 2007 | 05:52 AM
  #397
Aquasar's Avatar
Aquasar
This past weekend I was given one of the best compiments by a 05MCS JCW owner. He was showing me his exhaust and how it has mellowed in 10k miles. I showed him mine and the sound. His eyes opened wide and he exclaimed WOW sounds good...
Art
Old Mar 7, 2007 | 08:20 PM
  #398
Megan Racing
Vendor
I'm glad that my efforts to reach out towards the community have paid off and that you guys enjoy the product that you yourselves helped to develop. I'd like you thank each and every one of you who have made this possible and offered me your advice and opinions on such an opinionated matter. I am just glad that you all allowed me to do this service for you guys. Thank you.. really.
Old Mar 7, 2007 | 08:23 PM
  #399
erickvonzipper
You are quite welcome, although thanks are obviously in order both ways. You made a Megan Racing believer out of me.
Zip
Old Mar 7, 2007 | 11:34 PM
  #400
retroom's Avatar
retroom
Reorder
I couldn't get in on the first group buy. Will you be ordering more exhausts?
Thanks,
Larry
quote=Megan Racing;1410662]I'm glad that my efforts to reach out towards the community have paid off and that you guys enjoy the product that you yourselves helped to develop. I'd like you thank each and every one of you who have made this possible and offered me your advice and opinions on such an opinionated matter. I am just glad that you all allowed me to do this service for you guys. Thank you.. really.[/quote]
