Cooper (non S) Modifications specific to the MINI Cooper (R50).
Fog light centre bumper 2007 mini cooper
Old May 1, 2013 | 05:28 AM
enzie's Avatar
enzie
Hello all, I am sure this has already been discussed. But can someone tell me how or direct me to the forum to change the Fog lamp on the bumper? There is condensation build up and I am sometimes getting an error that the light in on when it is not. Thanks
Old May 1, 2013 | 06:54 AM
nutsofamily's Avatar
nutsofamily
https://www.northamericanmotoring.co...ml#post3672639
Old May 1, 2013 | 07:03 PM
enzie's Avatar
enzie
Was this link to a post for the center fog light? I need the oval one in the center on the bumper, where I do believe you can attach a trailer hitch by doing a major overhaul. I so do not want to haul the bumper off just to change a lamp...I'll live with the error code. Thanks
Old May 1, 2013 | 08:47 PM
rkw's Avatar
rkw
Reach under the rear bumper. The backside of the rear fog is exposed. If all you want to do is change the bulb, twist the bulb holder counter clockwise, and it will unlock and release from the light housing. If you want to remove the entire lamp from the bumper, press the tabs on the sides inward.
http://www.ecstuning.com/Mini-2007-C...ght/ES174886/#
Old May 2, 2013 | 05:47 AM
enzie's Avatar
enzie
That is the correct lamp I am talking about but if I'm not mistaken there is a hard black plastic cover covering almost all of the rear underneath. I'll have to take a picture when I get home from work and post it. It must come off to get to that lamp.. lol. I remember this because when I use back to black or armorall, I sometimes shine it as well..nothing like a shiny hiney!
Old May 2, 2013 | 08:17 AM
This link works***
http://www.ecstuning.com/ES174886/
rkw -
Was just going to post that showing the back side of the lamp houing.
Thanks for the post.
See if you can pop the lens out from the front of the bumper and then access the lens and bulb.
Once you post up a pic we should know. Here is the diagram of the rear bumper and I can also see this is the foam from the bumper impact right above it.
Old May 2, 2013 | 11:58 AM
enzie's Avatar
enzie
I welcome the comments and thanks for all your help.
Attached Thumbnails Fog light centre bumper 2007 mini cooper-mini-cooper-1.jpg   Fog light centre bumper 2007 mini cooper-mini-cooper-2.jpg   Fog light centre bumper 2007 mini cooper-mini-cooper-3.jpg
Old May 2, 2013 | 12:18 PM
I was just thinking that , you have the rear panel in place.
Underbody paneling, rear
http://www.ecstuning.com/Search/51711149159/
Just undo the plastic expanding nuts which is number 3 in the diagram across the bumper, pull the plastic down a little, reach up and pop the rear lens out. If you cannot band it enough undo the other #2 platic nuts toward the front of the MINI further under on each side , then the whole plastic should drop.
Thanks and hope that helps.
Old May 2, 2013 | 02:09 PM
enzie's Avatar
enzie
Thanks so much ECSTuning You have been most helpful!
Old May 2, 2013 | 02:42 PM
You are welcome.
Let us know when you are done.
Old May 17, 2013 | 01:46 PM
enzie's Avatar
enzie
I made out just fine. I have humidity in the light so I left the light out for a bit and parked her in the sun. I'll never get rid of it unless I replace the whole light I guess. Main thing, Thankfully no more error codes.
Old May 17, 2013 | 01:50 PM
Great Glad you got the light fixed.
You could in the future try letting the part sit out in the sun by itself and the top up where you insert the bulb ( bulb out of course ). That might get rid of most of out but if the lens where it seals to the housing lets water in, a new one will fix that.
Old Oct 17, 2014 | 03:27 PM
BrandonM3's Avatar
BrandonM3
Anybody know how to retrofit this light onto a MINI that doesn't have it installed from the factory?
Old Oct 21, 2014 | 01:17 PM
Check to see if there is wires back there ( pre wired ) for the Cooper. Then Get the light housing above. Then you will need to get this toggle and fill the blank area on the toggle bank where the black is, u can pop out the cap black plate on the face plate. Unless you want the face plate with the corresponding icon above the toggle bank. Then you will need it programmed at the dealership.
Toggle Switch. : 64113452459
http://www.ecstuning.com/Search/SiteSearch/64113452459/
Use this as a guide.
https://www.northamericanmotoring.co...-retrofit.html
jrezzo
Aug 9, 2015 10:32 PM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
