R56 Fog Light Bulb Change Ouch
I love the Retro look of the Mini and finally broke down and bought a set of Yellow Fog Light Bulbs. I thought the install was going to be easy. I was wrong!
1.) Step one: The inside fender well cap came off in a snap.
2.) Step Two: 1/4 turn on the bulb and it easily slips out the fog light housing.
3.) Step Three: (NIghtmare!
) The instructions state to depressn the two tabs on the side of the socket and the bulb should pull straight out. WRONG!
So after 5 minutes of playing tug of war, I figured I would use a pair of pliers to depress the tabs while I pulling the bulb out. Wrong! I crushed the socket and broke the tabs
. I stopped at this moment and took a breath. I decided to look at the replacement bulb. I noticed two tabs at the top of the plastic socket (NOT AT THE BOTTOM WERE YOU DEPRESS!).
I took a small flat blade screw driver and simply pryed the top of each tab and viola the bulb came out with no effort
. The other side took all of two minutes to install. Luckily the left crushed socket works fine.
I hope this will help anyone who plans on changing their fog light bulbs in the future.
By the way I Love the way the Yellow bulbs look!
I will post a picture tonight when you can see them best.
AXO
. 1.) Step one: The inside fender well cap came off in a snap.
. I stopped at this moment and took a breath. I decided to look at the replacement bulb. I noticed two tabs at the top of the plastic socket (NOT AT THE BOTTOM WERE YOU DEPRESS!). I took a small flat blade screw driver and simply pryed the top of each tab and viola the bulb came out with no effort
AXO
Thanks, I am Lucky the one still works.
They are Nokya Artic Hyper Yellow, H8. I bought them on ebay for $22 shipped
.They are super bright and so far, I am liking them.
I love the Retro look.
Sorry about the crappy Cell Phone Pic. They look much better in person.
I love the Retro look.Sorry about the crappy Cell Phone Pic. They look much better in person.
The yellow ones really do work better than the white in bad or low light conditions....
But please tell me you're not one of those idiots who thinks it's "cool" to drive around in clear weather with your fog lights blazing away!
http://s214.photobucket.com/albums/c...Picture008.jpg
Add me to the always on crowd!
(I use those as DRLs, decreased my close calls by 90%)
(I actually only use the other ones in the rain at night)
Question... With the head lights there are two bulbs, one for the high beams and one for low. ( so 4 bulbs total ) With the fog lamps, how many bulbs are there, Because my lower lights are on when the headlight switch is clicked once, then when I hit the fog lamp switch they get brighter at the top part. So is this the same as the headlights. So would I need 4 H8 bulbs and 4 h13 bulbs to get all matching color?
Same access panel as the fogs. There are instructions and diagrams in the Owner's Manual.
Hoen errors?
So I have read a great deal of changing all these bulbs to Piaa/Hoen.
Some links mention error cropping up others say they are fine.
Some point to audi forums where (euro style) where errors from these bulbs do occur.
Can someone verify that the H8 hoens/Piaa and w5w wedge bulbs DO WORK without error codes for a 2007 R56 Cooper with Xenon stock headlights.
" target="_blank">
">Some links mention error cropping up others say they are fine.
" target="_blank">
http://www.hoen-usa.com/fog.htm
[/URL]I would be replacing the fogs and city (upper wedge) lights to match as closely as possible, or perhaps use yellows.
Thanks!
