K&n 69-2005ttk
#27
#28
#30
#31
#32
FYI, I have run the DDM, the AirVIP2 and just a K&N with the OEM air box with the following results.
DDM: Loud. Intake temp between 30 to 35 degrees above ambient.
Air VIP2: Not as loud. Intake temp between 19 to 23 above ambient.
K&N, OEM box: Not loud. Intake temp between 18 to 21 above ambient.
Power gain was about the same with each configuration. Intake temp was monitored on each, all the time, using a Scanguage II and the Garmin HD.
#33
@ 3leafz, Thanks for the photo! That is how my elbow looks, but there is a tube running down the back. I'll get those photos posted up tonight.
@ Tank251, I believe K&N, OEM Box means the K&N "drop in" filter. So the filter is the same size/dimension of the factory filter, but has the K&N filter pleating with oiled media.
#35
Power gain was about the same with each configuration. Intake temp was monitored on each, all the time, using a Scanguage II and the Garmin HD."
The drop in K&N filter does nearly the same as the DDM and VIP, correct?
#36
So based on the post by jbewley "K&N, OEM box: Not loud. Intake temp between 18 to 21 above ambient.
The drop in K&N filter does near the DDM and VIP, correct?
#37
Yeah I was hoping jbewley would reply with more details. So many questions. Zero you bring up an interesting point. Can "you" (the driver not you Zero) notice the gains when driving? I have seen people say they can tell after the DDM or VIP and others. So I wonder is it the noise or performance? It would be interesting to see numbers (hp, torgue, 0-60 or 1/4 mile) for the K&N, DDM, and VIP.
#40
MiniVelvet
04-21-2014 03:33 PM
mkov608
08-22-2011 12:04 AM
