Cooper (non S) Modifications specific to the MINI Cooper (R50).
Want To See Something Cool
Old Nov 24, 2007 | 08:43 PM
enrike's Avatar
enrike
Hi everybody i,ve been here for a while because of a lot of things to do on my cooper here is some pictures of the work done . I think this might interest some of you stay tune for more pics
Eric Courchesne
Attached Thumbnails Want To See Something Cool-img_0184.jpg   Want To See Something Cool-img_0185.jpg   Want To See Something Cool-img_0187.jpg
Old Nov 24, 2007 | 08:49 PM
enrike's Avatar
enrike
More pics
See the small linkage between the fifth cylinder TB hahahah.
Throtles are fro GSXR10000 2002
Pistons from GSX1100 86-88 Wiseco
Rods will be Acura B18b
Cat CAM
Jackson racing headers
Eric Courchesne
Attached Thumbnails Want To See Something Cool-img_0188.jpg   Want To See Something Cool-img_0190.jpg   Want To See Something Cool-img_0165.jpg
Old Nov 24, 2007 | 08:55 PM
enrike's Avatar
enrike
I also installed a steering kwickener for Snow and dirt conditions
The tilt steering is still working
Bye
Attached Thumbnails Want To See Something Cool-img_0173.jpg   Want To See Something Cool-img_0127.jpg   Want To See Something Cool-courchesne.jpg
Old Nov 24, 2007 | 09:07 PM
glnr13's Avatar
glnr13
looks sick!!
Old Nov 25, 2007 | 06:58 AM
enrike's Avatar
enrike
Can somebody move that thread to 1st gen forum i made a mistake
Sorry
Eric Courchesne
Old Jan 12, 2008 | 10:08 AM
Some Guy's Avatar
Some Guy
Wow, that is really sweet. Love how you got creative by using the stock throttle body like that.
Old Jan 12, 2008 | 12:56 PM
Beecher's Avatar
Beecher
man, how did i never see this before? Independent bodys are on my this year plan (they were my right now plan, but got sidetracked with half adozen other mini purchases). Feel free to pm or email, or post impression for me. I would love to know all i can about how the bodies run. thanks
Beecher
Old Jan 14, 2008 | 05:17 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
This is great that someone did this. I have seen a few, but not many.
Old Feb 22, 2008 | 04:37 PM
J Propane's Avatar
J Propane
I guess this combo must be pretty quick as they finished in second position at their first rally with the mods, after leading most of the way.
Congrats!!!!
Pour la Coupe John Nichols, les résultats, après cette première compétition, s’organisent dans l’ordre suivant :
1. Daniel Gauthier (pilote) et Daniel Pilote (co-pilote) sur VW Golf
2. Yohan Tessier (pilote) et Frédéric Prigge (co-pilote) sur Mini-Cooper
3. Maxime Labrie (pilote) et Robert Labrie (co-pilote) sur Honda Civic
4. François Jolibois (pilote) et Nancy Beaulieu (co-pilote) sur Honda Civic
5. Patrick Rainville (pilote) et André Rainville (co-pilote) sur VW Golf
Old Feb 22, 2008 | 04:38 PM
J Propane's Avatar
J Propane
Last edited by J Propane; Feb 22, 2008 at 07:42 PM. Reason: thread moved, thank you!
Old Feb 22, 2008 | 06:38 PM
UKSUV's Avatar
UKSUV
Bye
I wanna know about the steering gizmo!
Old Feb 22, 2008 | 08:39 PM
AutoXCooper.com's Avatar
AutoXCooper.com
R50 Rules
Old Feb 23, 2008 | 12:58 AM
xnotfunkylex's Avatar
xnotfunkylex
I really like the orange paint. I also wouldn't mind the engine mods. Does any one know what kind of power gains come from this?
Old Feb 23, 2008 | 01:05 AM
Der Abt's Avatar
Der Abt
Badass setup you got there.
Kind regards
Der Abt
Old Feb 23, 2008 | 01:12 AM
Der Abt's Avatar
Der Abt
With that list and probably a bunch of other stuff he hasn't said yet he should be making at least 145hp.
Cams, header, cat. delete, pistons, rods, and all the work on the engine block itself and on top of that there are probably other things he forgot to mention.
How much exactly is hard to tell, every part from every brand can result in different gains.
Enrike dyno that thing would you
Kind regards
Der Abt
Old Feb 25, 2008 | 08:16 PM
enrike's Avatar
enrike
Long time since i`ve been here the tread now growing since it been moved from 2nd generation.
We started the engine a month ago with good and bad results
first, the compression ratio was to high 14.7:1 we had to install 2 .95 head gasket to reduce to 12.6:1 by that way the head rised up so i had to grind the key hole in the cam gear to keep the cam dialed and i also installed a 2nd gasked on the plug for the chain tensionner because the chain was a little to tight .
Second on the first test drive the car was way too rich around 30% ,so we had ruffly tuned with Dimsport software and now the car light up at 5500rpm thru 8150rpm but there is a problem i am unable to run more than 3 speeds thru revlimit the DME sense something wrong and came in "limp home mode".
seem to be codes p1109 and p1689 that cause that.The cops where behind me when i camed back to garage cause i forgot to install the liscence plate but he was cool and let me go.
With the ITB's the vacuum is very low and fluctuating i think that's why the DME kissed me.
First rally was the next week end so i decided to try remove the Cam and replace it with a Cooper S stock cam....Still limp. so i went back to stock intake to go racing but surprise, the ports have been enlarged so much that the rubber gasket was in the ports so i had to fill the groove with epoxy and install a composite gasket.
we had good results in the rally we were leading the 2wd championship by 3 and a half minutes when the fuel supply line came off, plenty of gas was spell in the engine bay, we where lucky, no fire.the driver simply plug it back and continue the rally.when the car came back to refuel there was only 3.8litres left in the gas tank.
The smooth torque curve of that setup was all it takes to drive the wheels thru the icy roads in CANADA.
Next rally will be tarmac so we will put back ITB`s and camshaft unless someone here have a solution to my problem I will go with a stand alone system because i have seen the power capability of the engine and i can tell you it is exciting,it`s more powerful than the Focus SVT i used to run so i ruffly estimate the power to 185hp but i will soonly dyno it. I will also post a video on youtube so you can hear the extreme sound of a S1600 engine.
will also post soon the litle flip we did last week end witch is the reason of our DNF at Rally Falardeau 2008.
www.rallyscoring.com
For you who want to know more on the kwickner the steering is now 1.5 turn lock to lock.Cool on ice and gravel but to tight on Tarmac .
Eric Courchesne
Old Feb 27, 2008 | 06:54 AM
MINI LP's Avatar
MINI LP
Do you have a web site of your rallye team ?
Old Feb 27, 2008 | 07:10 PM
enrike's Avatar
enrike
our web site is www.90-droite.fpriggeracing.com but is not updated you can see the serie website at www.couperallye.com both in french.
here is a link to some cool pictures of the las rally we did ,
http://picasaweb.google.ca/mediasral...8PhotosDeFreud
Old Feb 27, 2008 | 08:35 PM
J Propane's Avatar
J Propane
Nice flip. Lucky you only inflicted so little damage!!!
IQRaceworks
53
Jun 28, 2024 07:29 AM
PsychoRallye
21
Feb 17, 2019 06:08 AM
gar56
Nov 15, 2016 06:41 AM
rustof
11
Sep 25, 2015 10:35 AM
zipitydooda
Sep 18, 2015 10:33 AM
