Cooper (non S) Modifications specific to the MINI Cooper (R50).
Swaybar
Old Sep 18, 2007 | 10:39 AM
D3m0N's Avatar
D3m0N
Swaybar
Will and 2006 S Sway bar fit on my 2003 Non-s without modification of mount points and such?
I would assume yes but dont know for sure
Old Sep 18, 2007 | 10:46 AM
UKSUV's Avatar
UKSUV
Ummmm......
Old Sep 18, 2007 | 11:13 AM
lotsie's Avatar
lotsie
Should fit, everything back there is the same.
Mark
Old Sep 18, 2007 | 11:33 AM
D3m0N's Avatar
D3m0N
next question is the s sway bar longer than the non-s I have heard multiple things on this but no consensus
Old Sep 18, 2007 | 01:39 PM
welshmenwillnotyield's Avatar
I don't think so. It's thicker, though.
Old Sep 18, 2007 | 02:01 PM
minimarks's Avatar
minimarks
I've read that a lot of Cooper's upgrade to an S rear swaybar. So I would say yes. I'll check in my Bentley and see what it says.
Old Sep 18, 2007 | 02:14 PM
Johnna's Avatar
Johnna
Good point. It is thicker so you'll need to have the matching bushings and mounting hardware. Other than that, it should be a direct swap with the existing rear sway bar.
Old Sep 18, 2007 | 04:09 PM
Jonv's Avatar
Jonv
I beileve the It's all the same just the thickness on the MCS (17mm?). Saw it somewhere in a Grassroots mag a long time ago...
Old Sep 19, 2007 | 05:52 AM
Tio Barry's Avatar
Tio Barry
Stock MC swaybar is 16mm; MCS comes with 17mm. I replaced my 16 mm with the 17mm and reused the same bushings - when the antisway bar gets any larger new bushings are required.
Old Sep 22, 2007 | 04:46 PM
resmini's Avatar
resmini
So, how much did the extra millimeter help?
Old Sep 22, 2007 | 10:42 PM
retroom's Avatar
retroom
Swaybar
I too would like to know if you noticed any difference after installing the "S" 17mm bar. I have an "S" 17mm swaybar sitting in the garage.
Thanks,
retroom
Old Sep 22, 2007 | 11:03 PM
tazio's Avatar
tazio
I, too, have an S rear bar in my garage, with bushings and hardware. PM me if you are interested in purchasing it.
Old Sep 23, 2007 | 10:20 AM
Tio Barry's Avatar
Tio Barry
Well - it is not a night and day difference but the car does feel less 'tippy' around corners. Install required removing the left rear strut bolts - I found that proper torque upon reassembly was critical; ie I got new bolts to eliminate a 'loose' feel.
Old Sep 23, 2007 | 11:27 AM
ajakeski's Avatar
ajakeski
If you are going to go through the work of changing the swaybar, why not put in a heavier after-market one? Both the MC and MCS weigh about the same, if the MCS swaybar is considered inferior in the MCS, I would have to assume it's about the same in the MC.
Old Sep 23, 2007 | 11:33 AM
tazio's Avatar
tazio
Ah, but the front-to-rear delta you achieve with an S rear bar on a Cooper is about the same as you get upgrading the rear bar of an S to 19mm, and more than enough to balance out the handling, if you work the tire pressures. And it's a LOT cheaper. For example...
Old Sep 23, 2007 | 08:37 PM
retroom's Avatar
retroom
Swaybar
Well said Tazio. I'm not looking for a drastic change and since I already have the S bar, I'll save some $$$.
retroom
Old Sep 25, 2007 | 08:45 AM
R50 Paul's Avatar
R50 Paul
If that doesn't suit your needs then save up and get a 19mm, that is one of the best mods one can do to a Cooper.
Old Sep 26, 2007 | 06:57 AM
Johnna's Avatar
Johnna
MCS swaybar available
If anyone with an MC in the Denver area is interested, my old MCS swaybar is available to a good home.
Old Oct 13, 2007 | 04:35 PM
FP's Avatar
FP
I have a new MCS sway bar with bushing and all that I got for free from the NAM member who sold me his 17" S-Lites take-offs. I guess I should have it swapped. How much time do you think a garage needs to do the job?
Old Oct 17, 2007 | 04:46 AM
Speedwing's Avatar
Speedwing
Should be about a 45 minute job.
Old Oct 17, 2007 | 07:34 AM
FP's Avatar
FP
Thanks for your help.
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
kohlersc
Sep 28, 2015 09:49 AM
gnhovis
Sep 28, 2015 06:28 AM
R53UndaPSI
Sep 21, 2015 09:42 AM
tag1260
Aug 5, 2015 04:27 AM
