3rd Gen FAQs 3rd Gen Common Questions & Answers!
Bimmercode App
Old May 19, 2020 | 09:19 PM
  #326
pdx_wee_car's Avatar
pdx_wee_car
Originally Posted by shmandrew
Does anybody know the coding parameters for the side indicators (the turn signals in the A-panel)?
I recently installed a set of LED indicators that were not supposed to require any additional resistors or anything but they're occasionally hyperflashing on me. I'm curious if there's a bulb type setting I could change or turn off any hot/cold monitoring for them. No bulb errors other than the occasional hyperflash, which typically occurs the first few times I use either turn signal after starting the car. Curiously, the hazards always blink at normal speed.
If I can't resolve via coding, I'm going to have to look into returning these as this is a PITA to live with.
I had this when I swapped to LEDs. It works fine for the first 2-3 cycles then goes 'hyperflaah' like there's a bulb out. I didn't find the solution via coding, I had to install a CAN Bus adapter that goes between the lights and the factory plug and takes care of the 'low voltage' signal for the lighting system.I found this article about it:
https://www.superbrightleds.com/blog...rflashing/275/
and this link to various products to stop the hyper flashing sequence:
https://www.superbrightleds.com/cat/...istor,60,3609:
Old May 20, 2020 | 01:05 PM
  #327
shmandrew's Avatar
shmandrew
Thanks for the tips. I'll look into this. Not really my ideal way of dealing with the situation but I guess I'll take what I can get.
Old May 23, 2020 | 08:56 AM
  #328
Walt's Avatar
Walt
Question Error D90D16 in Error Memory after using BimmerCode
I brought my MINI F56 into the dealer for service a few weeks ago for repair. After I got it back, I quickly noticed that all my changes I made with BimmerCode were gone.
Not a horrible problem. I simply ran BimmerCode, and set everything back the way I like it.
My problem, now, is that I am getting an error code. It is shown by also running BimmerLink, and it is in Error Memory. The error is under Body Domain Controller, and is "D90D16 Control Unit Light (BEL),(LIN): Wrong Version Installed".
Anyone else noticed this error happening after using BimmerCode? Any fix? I can delete the error, but it eventually comes back.
PS: In searching, I found only this: https://www.reddit.com/r/BmwTech/com...main_any_help/
Old Jun 10, 2020 | 01:31 PM
  #329
invaliduser's Avatar
invaliduser
Anyone managed to get this to work via Bimmercode?
Old Jun 11, 2020 | 10:26 AM
  #330
xentar's Avatar
xentar
[QUOTE=invaliduser;4539689]Anyone managed to get this to work via Bimmercode?/QUOTE]
Yes, I'm using this option on my MCS right now.
From your Bimmercode app, you need to go to Headunit then toggle expert mode, then 3000 HMI, search for JOHN_COOPER_WORKS_HMI, set it to Active, then code it.
Once completed, you need to go to your center console settings, Center Instrument, I think it's under Basic Display then choose the JCW from the list.
Old Jun 11, 2020 | 04:58 PM
  #331
Walt's Avatar
Walt
I have to ask, what is that displaying? I mean, what causes the centered red line to move clockwise or counter clockwise?
Old Jun 12, 2020 | 05:02 AM
  #332
Jstancampiano's Avatar
Jstancampiano
I have that display in my 2018 MCS with no options....came standard. It's in vehicle section under excitement.
Joe
Old Jun 12, 2020 | 06:18 AM
  #333
xentar's Avatar
xentar
When you press on the gas, the red line will move clockwise then when you step on the brake, it will move counter clockwise. The harder you press on either the gas or brake pedals, the more it will move.
Old Jun 12, 2020 | 08:54 AM
  #334
invaliduser
I have the 6.5" display that I'm assuming is the base display for the LCI cars. There is still no option in Bimmercode to access this headunit.
Old Jun 19, 2020 | 03:50 PM
  #335
SwoleMini18's Avatar
SwoleMini18
Has anyone figured out how to either
1. Have the rear fog lights remain on at all times
or
2. Have them work as brake lights WITH a pre-LCI car that has EU UJ tail lights installed
I don’t have the fog light toggle switch.
When I enable the fog lights as brake lights, my UJ tail lights don’t light up as brake lights.
help would be greatly appreciated !
Old Jun 29, 2020 | 11:08 AM
  #336
Dmytro Sorokevych's Avatar
Dmytro Sorokevych
Need help. Nbt evo , Connected USB2 cable to the armrest , but cant make it work. When i code comm_port usb1_usb2 - both of usb stop working.
Old Jul 4, 2020 | 10:07 PM
  #337
Dmytro Sorokevych
Find the way how to make it visible and not to conflict with stock usb. ( usb1_sia ) Works like snap in adapter. But still no luck connecting or charging.
Old Oct 5, 2020 | 12:11 PM
  #338
RocketJohn's Avatar
RocketJohn
this worked for me on my '21 Cooper S E in EXPERT MODE
Old Oct 5, 2020 | 05:45 PM
  #339
maaii's Avatar
maaii
Do you change the headlight switch ?
You need to code it to meet the spec in BDC.
It's easy to solve this problem, you can use bimmercode.
Old Oct 5, 2020 | 06:36 PM
  #340
Walt's Avatar
Walt
Yes.
Did that, as shown in in the first post here. Just to note, with changing light switch to one that adds the rear fog button, the rear fog works, after coding for it.
Bimmercode seems to have caused this new error ("Wrong Version Installed").
Old Oct 5, 2020 | 07:16 PM
  #341
maaii's Avatar
maaii
Yes.
find this "LCE_BEL_LIN_VAR" in BDC ecu and change to "10_BEL_FLC_NSW_NSL"
Old Oct 6, 2020 | 07:30 AM
  #342
Walt's Avatar
Walt
Will do! Thanks.
Old Oct 17, 2020 | 10:47 AM
  #343
Walt's Avatar
Walt
Exclamation Coding for a new/replacement Light Switch Assembly
Originally Posted by vetsvette
Activate Rear Fog Lights feature for lighting switch:
3064 Mapping_Nebelschlussl_L_output = nsl_l
3064 Mapping_Nebelschlussl_L_Function = nebelschlusslicht
3064 Mapping_Nebelschlussl_R_output = nsl_r
3064 Mapping_Nebelschlussl_R_Function = Nebelschlusslicht
First, thanks to @maaii for pointing me in right direction. I figured I would write up something, and post it here in the hopes that it might someday help someone.
When one replaces the Lighting Switch Assembly, in addition to the coding changes quoted above (taken from the first post in this thread), you also need to do one more coding change.
Go into the Body Domain Controller (BDC), and scroll down to find...
3069 LCECONFIGURATION
In that section, scroll down to find...
LCE_BEL_LIN_VAR
In that, you'll find various 3-letter codes used to describe your Lighting Switch Assembly. Those values are among ...
BEL = beleuchtung = lighting.
FLC = (automatische) fahrlichtsteuerung = (automatic) headlight control.
NSW = nebelscheinwerfer = front fog lights.
NSL = nebelschlussleuchten = rear fog lights.
LWR = leuchtweitenregulierung = headlight range adjustment (not in North America)
For example, I originally had Auto headlights, but no fog light switches. So, my initial value was: BEL_FLC
My new/replacement Lighting Switch Assembly added a rear fog light switch (but still no front fog light switch). So, my new value is: BEL_FLC_NSL
Old Oct 17, 2020 | 12:45 PM
  #344
TVPostSound's Avatar
TVPostSound
One caveat.
I found out the hard way.
unbeknownst to me the dealer coded my car with a factory update.
called me and said it failed, and needed a new light switch.
I realized that the factory coding for my car VO
did not have rear fog switch.
I ran to the dealer and replaced with the old switch. The dealer then had coding success.
then had to later reinstall my new switch and recode all.
so don’t sell your old switch.
Old Dec 10, 2020 | 07:13 PM
  #345
e9stibi's Avatar
e9stibi
LCE_BEL_LIN_VAR
Hi - I am importing my US Mini F56 (2019 Cooper S) to Germany and need to have rear fog light for registration. I read al the postings and bought BimmerCode. I already installed the new switch with the NSL button and now need to program. In the post that is quoted I do not see the initial step:
Activate Rear Fog Lights:
3068 NSL_Verbaut = Verbaut
Code first, then cycle ignition, then restart Bimmercode for the below options
to show up
I need to do this, correct?
Another question is on how to turn of the orange front position lights that are not allowed in Germany. Can some provide me the steps to turn them off?
Thanks!
Old Dec 11, 2020 | 07:46 PM
  #346
Walt's Avatar
Walt
to show up
My post was intended to focus only on the Light Switch and my new additional findings. Not the Rear Fogs in general. Yes, to activate some/all of the Rear Fog functions, there are more steps than what I quoted. I didn't want to repeat what was already given in this thread, in other's posts, just add to them.
Old Dec 12, 2020 | 04:37 AM
  #347
e9stibi's Avatar
e9stibi
Walt - thanks for the fast response and clarification. I did not want to criticize at all. I am just new to Mini and Bimmercode to help my wife with her Mini Cooper S after the dealership told us BMW will not help us. I wanted to make sure that I had the steps right.
BTW. My Bluetooth 4.0 plug from Amazon did not work at all and I returned it. It did not even send a Bluetooth signal and I checked with my other car to ensure it is the plug. That will set me back a couple of days but I am glad that it did not fail while coding. I have this funny feeling with electronics from China ...
Old Dec 17, 2020 | 11:10 AM
  #348
TVPostSound
Thanks!
The other caveat, is being able to turn the position lights off while driving, but must be able to be used when (mandatory in Germany) parking..
Old Dec 17, 2020 | 12:14 PM
  #349
e9stibi's Avatar
e9stibi
just an update. I followed the coding steps for the rear fog lights and they work as intended. I turned the front orange side markers off that sit in the wheel housing and do not think I have an issue with parking light in Germany because the fronts are still lit white when the car is in park. Did I miss anything?
Old Mar 18, 2021 | 01:23 PM
  #350
kfmuller's Avatar
kfmuller
I've got quite a few things coded using Bimmercode. I just added the Homelink, auto dim, compass mirror to my 2016 JCW (July 2015 build). It was essentially plug and play, but I did code a few things using Bimmercode because it showed a couple of errors regarding not being the correct mirror, UGDO error, and something else. Needless to say, it's coded fine, and no errors.
I also was one of the first adopters a few years ago of the Union Jack rear lights - and, coded all the errors away on those.
My only current issue is that I still show a 8041C3 error in Bimmerlink. This is the only one I ever see. Right now it says Coding: lamp mapping failed. Error not present currently but stored. Error would not cause a warning indicator light. So, I thought I'd try to figure out what is causing that one. I've looked over my coding for the rear tail lights, brake force display, comfort access, etc., and everything seems to be in order. The error occurs in Car access system of Bimmerlink. I do remember messing around with Daytime running light stuff so that the rear Union Jacks would stay lit up all the time, but I changed those back. I also noticed that it currently says High Beam warm and cold monitoring as Not Active - but, it also says Bulb for High beam lamp. I'm wondering if High beam lamp should be coded to LED since I thought the whole front lamp was LED when you have the LED package. I have LED with the cornering lights.
