2nd Gen Countryman (F60) Talk (2016-2024) Second Generation Countryman discussion. F60
F60 JCW Pro Exhaust will it fit?
Old Nov 30, 2023 | 01:23 AM
Jeenyus's Avatar
Jeenyus
Simple question, can this be fitted to the 2023 JCW Mini Countryman? If not are there any good after market options?
I one think that bugs me with the this car is the way the back box sticks out underneath.
Old Nov 30, 2023 | 08:24 AM
All the info is here:
https://www.northamericanmotoring.co...uning-kit.html
The problem is flash for the system is tied to the car for the after install procedure. The early F60 JCW had the kit and tied to the car, but again no tune for the JCW cars (HP Flash). So its just a valvetronic exhaust (two tone).
Due to epa regulations the JCW F60 does not have a kit for 2020+ even though the -2019 Kits will physically fit. Its up to the MINI dealer if they want to install/flash.
https://www.ecstuning.com/b-genuine-...m/18302450808/ 2018/2019 kit JCW Countryman.
So you can have it installed and then try to have a shop find a work around on the flash.
I was at SEMA and took some pictures when this launched, this is when MINI was still at SEMA displaying their new JCW Tuning Kit systems. This was a couple years back and the last year they were there.
BMW group and MINI does not show at SEMA anymore :(
Old Nov 30, 2023 | 09:51 AM
Jeenyus's Avatar
Jeenyus
You are always so helpful ECS, im not sure what this flash is, mostly i jus want something that doesn't stick out so ugly, if its not flashed will that be an issue?
Old Nov 30, 2023 | 10:26 AM
Just have to make sure the valvetronic function works. If the dealership installs it and they pull up your vin, MINI will not let them flash to code anything. You might be bale to install yourself/local shopand then just get the valvetronic to function with remote. I dont know if the com box (black box included) will be ok on the wiring for the F60 JCW post 2020+. All the info is in that thread i have. I know people got the F56 JCW one to work on post 2020+ as those models are in the same boat you are.
Glad to help. I have the most info on these JCW tuning kits, MINI just got their hands tied on new EPA regulations for the USA and it cut off the kit development past 2020 for some models.
If not flashed or the controller switch FOB is not done its might not function on/off. But could be zip tied open anyway after install.
What some people did is installed and then hooked up their own Vacuum system to function the valve.
Old Nov 30, 2023 | 02:10 PM
Jeenyus's Avatar
Jeenyus
Ah, well the JCW 2023 F60 has valves in the current exhaust, i wonder if they are similar/compatible
Old Dec 1, 2023 | 01:20 PM
Do you have a shot of the rear underside?
The factory one i believe is not suppose to be valved. Not till 2025 on the newest JCW with Quad tips.
Old Dec 2, 2023 | 12:33 AM
Jeenyus's Avatar
Jeenyus
Here does this help?
Old Dec 4, 2023 | 07:12 AM
Yep they valved it, last time i heard one on youtube it was not near as aggressive as the JCW tuning kit counterpart. So they made a factory one due to epa on the JCW tuning kits not i dealer installed option.
Also its only on the newer countryman 2025+ JCW
Old Dec 4, 2023 | 11:00 PM
Jeenyus's Avatar
Jeenyus
mines 2023 tho
Old Dec 5, 2023 | 06:42 AM
Yep thats mean MINI must have made stock valved systems for JCW models in F60 2023+ , my guess is for the JCW F54 also 2023+ I have not seen one on the Cooper S stock or the F56 platform stock.
Old Dec 5, 2023 | 12:09 PM
Jeenyus's Avatar
Jeenyus
Ah ok so its new for the 2023 model, ok so in theory do you think it would retro fit?
The hangers are in the same place, and as it has a flap control from the ECU it wouldn't need an ECU flash, all you need to do is split the original connection to go to 2 valves/flaps rather than one right? of course the Blue tooth control wouldn't work but you don't need it too as the flaps would be opened by going in to sport mode as it currently does with the one flap.
So this could work right?
Old Dec 5, 2023 | 12:34 PM
Yes, physically should be the same. I bet you might be able to tap those wires for the factory valvetronic and then just use MINIs set up. But then you loose the on/off of that switch that comes with it.
No body has done this but i think you are on to something.
Old Dec 6, 2023 | 10:40 AM
Jeenyus's Avatar
Jeenyus
Im not bothered about the bluetooth on/off control as long as it controlled but the toggling in to sport mode. I'm speaking to someone in the US who's looking in to do it too, and i found a video of someone who did it to a 2020 300hp clubman.
Old Dec 6, 2023 | 11:43 AM
Cool, let us know.
Old Apr 9, 2025 | 12:11 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
This system added to a factory JCW only makes sense if you can tie the two valves together into the "Sport" mode button. Forget the added Bluetooth controllers....
Old Apr 26, 2025 | 02:19 PM
MINIdude44's Avatar
MINIdude44
I had a 19 pre LCI with the JCW tune kit, programming and exhaust with the dual valves. When I bought my 24 F60 JCW I took the exhaust and it bolts right up! (With some cutting and a new clamp)
I also took the Bluetooth module and fit it in the same spot the pre LCI goes. Works great! And sounds awesome. It’s a much deeper tone with the B48N than the regular B46.
I have one valve hooked up to the factory wiring (drivers side that opens up in sport mode) and the passenger side valve on the Bluetooth remote. So I get 3 levels of sound, closed for daily cruising, one side open on the Bluetooth when I’m feeling spirited, (passenger side valve). the piping on the passenger side is a bit longer than the drivers side, but still sounds good with one valve open. But in sport mode both are open and it ROARS! I love it!
if u want to tie both valves together for the sport mode button you have to tie into and run wires from the drivers side factory connector to passenger side valve. It’s possible but I like my 3 stage setup the best
no programming involved just hardware and wiring.
Old May 31, 2025 | 07:42 PM
wtorres141's Avatar
wtorres141
Am I understanding correctly? The 2019 JWC exhaust, with two flaps, is louder than the newer stock B48 JWC exhaust, with the single flap?
I have a 2022 JCW and I would like the exhaust a bit louder.
You had both exhausts on a newer JCW and the older one is louder?
I've not seen a comparison with aftermarket and the newer JCW exhaust. But plenty with the older JCW exhaust.
Old Jun 1, 2025 | 02:59 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
If you look at the exhaust, you'll see why the JCW Pro exhaust with the two flaps is louder. When the flaps are open, it fully bypasses the muffler. Whereas the factory JCW exhaust with the single flap still sends some exhaust flow through the muffler, just not as much as when its closed.
Ezuke22
Nov 27, 2023 02:02 PM
erdalozan
May 10, 2022 04:36 PM
Superat03
Apr 25, 2013 10:57 AM
Oettpo
Oct 26, 2007 09:14 AM
gnhovis
Aug 11, 2006 07:03 AM
