R60 Mini won't move
Old Apr 13, 2025 | 02:09 PM
kinghood's Avatar
kinghood
Mini won't move
Hi folks, i have a problem with my Mini S, All4, R60 N18B16. Its not moving at all. When i press brake and change gear the display show what gear i select but car wont move. I read the error codes with ISTA, but in EGS module there is no errors. When put car in Drive, the driveshafts is not spining at all. I atach some live data. Any help? I bought car with this problem, so i dont know the history of the car.
Old Apr 14, 2025 | 03:22 AM
BlazingE60's Avatar
BlazingE60
For what it's worth, when I have the transmission in Park, my "Performance Variables" show an Engine Torque of 2.35% and Turbine Speed of 630 rpm. You show zero for both these values. My R60 is FWD, not AWD, but I wouldn't expect that to make a difference.
Old Apr 14, 2025 | 10:19 AM
kinghood's Avatar
kinghood
Exactly i was expecting to see torque rpm closer to engine rpm, so i think that i need to dissasemble the gearbox and search for any damage. Is it possible the oil pump of the transmission to be the main problem?
Old Apr 14, 2025 | 06:28 PM
BlazingE60's Avatar
BlazingE60
I have not read up on the transmission internals to know if a failed oil pump would result in no / limited "Turbine Speed". If there is no oil to sling against the turbine, seems logical.
Do you have the GA6F21WA service documentation from minitechinfo.com? If not, it would be worth the daily access fee to download and read.
Old Apr 16, 2025 | 02:01 AM
supazuk's Avatar
supazuk
Do any of the seals show signs of fluid leaking ?
Have you only tried this on cold idle or have you let it idle for 30 plus mins?
I would drain measure and inspect fluid and then refill to eliminate at least that variable
From experience when CVT is over a quart low it will not move, if it is just a little low it will not move until warm
I am no means a tans mission expert However If not a fluid issue I would investigate torque converter or front pump
Old Apr 17, 2025 | 11:27 PM
kinghood's Avatar
kinghood
Its not cvt, its GA6F21WA, as known as 09g in vag cars. No sign of leaks, i check oil level when the trans oil reach 35 degree, its ok. I'm gonna dissasemble the gearbox and the first think to check is oil pump. When i test the car was on a jack stand with wheels removed i wonder does the fact that the car is not on wheels will take any efect not to spin axels.
Old Apr 19, 2025 | 09:44 PM
kinghood's Avatar
kinghood
Well, everythink is clear now. The oil pump is gone. Its not pumping oil in TC and thats why its not spining with closer to egnine rpms.
Old Apr 21, 2025 | 05:08 AM
BlazingE60's Avatar
BlazingE60
Thanks for following up with pictures. Any thoughts on root cause for oil pump failure?
How many miles on this 11/2010 build Countryman?
Old Apr 21, 2025 | 09:31 AM
kinghood's Avatar
kinghood
112 000 miles, well the car arrived with mixed trans oil and coolant so i suspect that oil cooler gasket has gone. So i removed the oil pan and the mechatronic and send it for repair, and removed the transmission to change friction plates, bushings and pistons and clean all the mess which was everywhere inside the box. When i checked the oil pump i didnt see the bushing which is in pump housing, so i think that is main problem for broken oil pump gear. Sorry for my bad English, i'm from Bulgaria. Hope to help somebody with my expirience because i didn't find any information about my problem, thats why i share everything.
Old Apr 22, 2025 | 04:36 AM
supazuk's Avatar
supazuk
No need to apologize, your English is excellent as is the tech you have shared
Old Apr 25, 2025 | 10:31 AM
jawilli6's Avatar
jawilli6
Goodness, yikes.
audihere
133
Apr 30, 2023 10:53 PM
haztronic
R60/R61 Stock Problems/Issues
Apr 10, 2017 09:55 PM
guka747
Mar 6, 2017 11:00 AM
kelviny
Dec 7, 2011 07:06 PM
Mesarina
Jul 17, 2006 06:29 AM
