R60 Need help with HK amp wiring
Old Jan 18, 2020 | 03:59 PM
2011rex87's Avatar
2011rex87
2014 R60 S All4
Does anyone know what 4 wires goto the under seat woofers? I have an amp and subwoofer I want to install. I need to know what wires to tap for audio signal. I searched all over the forum and did not find any R60 specific info.
Thank you.
Old Jan 18, 2020 | 04:09 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
look at newtis.info
Old Jan 18, 2020 | 04:29 PM
2011rex87's Avatar
2011rex87
I am on that site now but I am having alot of trouble figuring out what is what. You guys are alot smarter than me with figuring out exactly what I am looking for. Is there any possible way to help me and tell me what wire colors I need from that hk harness that I posted a picture of?
Old Jan 18, 2020 | 05:40 PM
Minnie.the.Moocher
Colors change, not always what it appears to be. However I see
left
yellow/black
green/brown
right
red/white
brown/white
as the wires to the under seat woofers.
I could be totally wrong but that is what I found. When I did my F56 I used a harness to avoid all that nonsense of tracing wires.
Old Jan 18, 2020 | 06:06 PM
2011rex87's Avatar
2011rex87
What about this link:
https://www.newtis.info/tisv2/a/en/r...ystem/EDXr4k8Q
Is that the correct info for 2014 countryman s all4 with hk audio?
Old Jan 18, 2020 | 06:20 PM
Minnie.the.Moocher
You really have to test them, the one I saw differed slightly. Easiest way would be to full the floor speakers and check the wiring.
Old Jan 18, 2020 | 06:37 PM
2011rex87's Avatar
2011rex87
I certainly appreciate your help. Can you link me to the page where you got your info from? Since it is different from the page I found. I want to see what the difference is.
Old Jan 18, 2020 | 06:45 PM
Minnie.the.Moocher
https://www.newtis.info/tisv2/a/en/r...ystem/EDRtNMt0
Your link maybe more accurate if you are using your vin#
Old Jan 18, 2020 | 06:53 PM
2011rex87's Avatar
2011rex87
Okay I see now. Your link is for the RHD and my link is for the LHD. I assume that stands for right-hand drive and left-hand drive. This mini is American version so I believe LHD is the correct diagram?
Old Jan 18, 2020 | 06:58 PM
Minnie.the.Moocher
You are probably right!
Old Feb 1, 2020 | 02:48 PM
2011rex87's Avatar
2011rex87
Successful install! Red with white, brown with white, yellow with black, and yellow with brown. I used the 12v accessory outlet in the rear as my remote signal to turn on the amp when the car is running.
Thanks again for the help.
Old Mar 22, 2020 | 02:48 PM
doctahjones's Avatar
doctahjones
I'm right in the middle of this...do you happen to remember which was + and -? I'd rather avoid the "better one.....(swaps wires)....better two" testing (ala eye doc testing &#128512
Factory sub
Yay for taking EVERYTHING out 😁
Old Mar 22, 2020 | 04:57 PM
2011rex87's Avatar
2011rex87
Yellow with black is + positive. Left channel.
Yellow with brown is - negative. Left channel.
Red with white is + positive. Right channel.
Brown with white is - negative. Right channel.
Old Mar 22, 2020 | 09:09 PM
doctahjones
Thanks a ton for that!
I didn't get to really really hook it up today. I got the power wires run, and tapped into the subwoofer feeds, but the 12v outlet back there is getting no juice. I didn't check the fuses yet, mainly because the sun was going down, it was starting to get -cold- and I still had to put everything back in/back together! I did jump the 12v from the battery over to the remote turn on, just to see if anything was coming through, and there was some bump so I know it should be good to go once I get the 12v sorted.
Then I also bought some mdf and grey carpet to make 1/2 of the flat load floor, since the prefab sub box is going to take up 1/2 the room back there. I'll post some pics once I get all that done too.
Old Mar 23, 2020 | 06:39 AM
2011rex87's Avatar
2011rex87
The 12v power outlet only gets power when the engine is running. If the engine is not turned on, it will not have power.
In a sense, that is a good thing, because you don't really want to run your subwoofer with the engine off (and alternator not charging) and drain your car battery.
There is probably a way to tap the HK amp power wire for the remote turn on, but at the time I did not have the correct size tapper (looks like the HK amp power wire is thicker gauge than the signal wires) and I did not want to cut and splice. It was easier for me to tap the 12v power outlet wire which was a smaller gauge similar the audio signal wires.
Old Mar 24, 2020 | 07:31 PM
doctahjones
What in the backwards......I mean I can understand someone attempting some logic, but that makes no sense to me! But then again, this is my first euro-import, i've always been nissan
But thanks for that tip, I never would have guessed that!
For me, I'd like to have bass without the car running
Old Apr 4, 2020 | 01:45 PM
lilxayuh's Avatar
lilxayuh
Request for personal questions about doing subs in my 2011 HK sound
this may be against rules but can you email me at isaiahshutes77@gmail to talk about this a bit? You are the ONLY person i’ve found to have done this and posted it online in the last 4-5 years and would love some insight
OdzBodkinz
22
Sep 10, 2022 04:05 PM
ericfreeman
Aug 1, 2019 04:43 PM
pokaco
Apr 6, 2016 11:21 AM
Luke Howland
Feb 13, 2015 04:51 PM
yellowbritishrocket
11
Mar 27, 2008 06:07 AM
