Navigation & Audio Please, i need help wiring my amp!
Old Feb 3, 2015 | 09:38 PM
Luke Howland's Avatar
Luke Howland
So i ran the power line already, ground is no big deal, remote is no big deal, amp dual subs are wired to the amp. All i need to do now is run audio wire back up to the front an plug in some where?!.. i have a roll of audio wire here. i Think i know where the x9331 plug is but i don't understand it. Can i run the audio wires into the front speakers or something?? Please help!
Ps: 2007 r56
Old Feb 3, 2015 | 09:57 PM
raidel00's Avatar
raidel00
You can either use a line out converter and use the front speakers....the pin diagram for the x9331 is on the forums. OR you can use the integral audio harness (
http://www.amazon.com/Integral-Audio-Amplfier-Speaker-Harness/dp/B00GQJOUCS/ref=sr_1_1?ie=UTF8&qid=1423029242&sr=8-1&keywords=x9331+harness http://www.amazon.com/Integral-Audio-Amplfier-Speaker-Harness/dp/B00GQJOUCS/ref=sr_1_1?ie=UTF8&qid=1423029242&sr=8-1&keywords=x9331+harness
). I used that and it made it fairly simple...it's expensive. I ran the remote wire from the pin 1 and added a resistor to it as a turn on delay and I added a ground loop isolator because I had a little bit of noise.
The Integral Audio install instructions help a lot too http://www.integralaudio.com/install...C1101S-R56.pdf
Old Feb 13, 2015 | 04:51 PM
richardsperry's Avatar
richardsperry
Screw that. Get the signal from the stock amp in connector. Just pigtail a RCA to the front channel wires.
wildwestrider
11
Jan 29, 2016 05:06 PM
minimofo
Dec 26, 2015 12:03 PM
buggyeye401
Sep 28, 2015 04:09 PM
dragonby
Sep 25, 2015 08:10 PM
