R60 Electrical Problem After Broken Side View Mirror
Old Nov 7, 2018 | 06:05 AM
JBarlow12's Avatar
JBarlow12
Hey all! Due to an unfortunate accident, the mirror on my '13 Countryman (base) was all but snapped off. I have since replaced it, and that part is good to go.
What I am having trouble with is immediately after that happened, the panel that controls the windows and everything went dead. I have tried to do a search for the solution, but I can't come up with anything.
Can somebody either:
A> Point me towards where this has been discussed
B> Recommend steps to take to try and remedy this situation.
Thank you all for your assistance!
Old Nov 7, 2018 | 06:31 AM
MiniToBe's Avatar
MiniToBe
did you check the fuses? did the wires snap by the way?
Old Nov 7, 2018 | 06:38 AM
JBarlow12's Avatar
JBarlow12
Thank you for the response. No wires snapped, and all of the fuses seem to be intact. I suppose that it never hurts to take a second look.
Old Nov 7, 2018 | 12:33 PM
JBarlow12's Avatar
JBarlow12
I just checked it again and all the fuses seem to be good.
Old Nov 7, 2018 | 12:44 PM
MiniToBe's Avatar
MiniToBe
did you disconnect the battery and reconnect to "reset" the system?
Old Nov 7, 2018 | 01:02 PM
JBarlow12's Avatar
JBarlow12
I just did that, and it didn't change anything.
One thing of note--the glass on the mirror itself is broken. I am waiting on a replacement to arrive today. Would that affect anything?
Old Nov 7, 2018 | 01:04 PM
MiniToBe's Avatar
MiniToBe
It shouldn't.
Other than the window controls, can you still lock/unlock from inside?
Do the lights work? And fog lights?
Old Nov 7, 2018 | 01:10 PM
JBarlow12's Avatar
JBarlow12
Locks function normally
All lights and fog lights appear to be normal.
Old Nov 7, 2018 | 01:18 PM
MiniToBe's Avatar
MiniToBe
do the rear ones work? do they work from their own switches?
im trying to zero in on either the controller or the FRM module (behind driver kick panel)
Old Nov 7, 2018 | 01:21 PM
JBarlow12's Avatar
JBarlow12
Lights, yes
Windows, no. I’m not sure if the window lock was engaged when this happened. The front passenger window does work.
Old Nov 7, 2018 | 01:28 PM
MiniToBe's Avatar
MiniToBe
the lock shouldn't affect the driver side though. you can check if is engaged. do you have a diagnostic tool that would tell you if the switch is operated? if not, you might have to either buy a switch or the tool to check it
Old Nov 7, 2018 | 01:33 PM
JBarlow12's Avatar
JBarlow12
My apologies if I wasn’t clear. All of the locks function normally. The front passenger window functions normally. Neither of the back windows will roll down, as well as the front driver side. I don’t know if the rest window lock was on when the window was damaged.
Old Nov 7, 2018 | 01:37 PM
MiniToBe's Avatar
MiniToBe
i'm sorry, by lock, i meant window lock/disable button.
also, did you check if the wires into the switch are tight...maybe when it snapped, it pulled them enough to not make a contact.
Old Nov 8, 2018 | 02:20 PM
JBarlow12's Avatar
JBarlow12
Sorry for the delay in getting back to you. The window lock/disable button does not function. None of the buttons on that panel function.
I will check the connection. I just haven't had a chance yet. Thank you for taking the time to walk through this with me.
N1ml
Nov 28, 2023 01:35 PM
ALLMAGAutoParts
How to
May 24, 2023 05:36 AM
jbing
21
Jan 2, 2014 07:20 AM
Verruckt
Jan 7, 2003 08:47 AM
drstevenj
14
Nov 26, 2002 06:13 AM
