R60 Can I replace just one tire?
Old Apr 22, 2015 | 11:26 AM
pennidragon's Avatar
pennidragon
My left, rear tire has a nail and it,s close to the sidewall so I think I'll have to put a new one on. The other 3 tires still are very good, only 4,000 miles on them so far. Can I just replace the one bad tire or should I get two and replace in pairs? I have an S All4.
Old Apr 22, 2015 | 11:46 AM
mickeymo's Avatar
mickeymo
with 4K miles, I think you can replace just one
Old Apr 22, 2015 | 12:10 PM
TBRoye's Avatar
TBRoye
If you can make it the same brand and style as the other 3. I flatted a tire as I was getting off the freeway taking wife' clubman to first service. Had dealer put and new one on as the other didn't have many miles. Same brand, style and size. no problem
Old Apr 22, 2015 | 01:30 PM
The Patagonian's Avatar
The Patagonian
On the back yes but not on the front. Given the front wheels are connected via the diff I wouldn't want different diameter tyres.
Old Apr 23, 2015 | 07:57 AM
cristo's Avatar
cristo
Alliance Member
If there are only 4K on the tires, check new vs old with a tire tread gauge.
If they're really close (within 1/32" - 2/32" tread depth), they should be fine
front or back. If there's more than 3/32 difference, best to put on the back
as noted above.
Actually, a difference of a couple /32" of tread makes a very tiny difference
of diameter, percentage wise. The change in wheel speeds is like driving
on a very, very slight curve, which most roads you drive on have, anyway.
Old Apr 23, 2015 | 08:57 AM
pennidragon
thanks for the input guys! will be taking it to my mini dealer in a week to get it replaced
Old Apr 23, 2015 | 09:20 AM
Zephyr1's Avatar
Zephyr1
Yeah, a difference in tire pressure has more effect on rolling diameter than 1-2 /32's
Old Apr 23, 2015 | 01:40 PM
y8s's Avatar
y8s
I replaced a single tire and the other three had over 20k on them. This is on an All4. Budgetary constraints yelled louder than my engineering degree.
Seriously I wouldn't worry about it if there is still a reasonable amount of life between the tread and wear bars.
Old Apr 23, 2015 | 02:45 PM
hsautocrosser's Avatar
hsautocrosser
Unless you have a tire warranty the dealer is a very expensive place to buy tires.
Old Apr 23, 2015 | 04:36 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Definitely measure the tread and see where they are at. If it's not a big difference, you should get able to get away with it.
-Luccia
888.280.7799 | 6am - 5pm PST
Old Apr 23, 2015 | 11:51 PM
bmwr606's Avatar
bmwr606
tirerack.com will "shave" a new tire to match the OD of part worn tires
Old Apr 24, 2015 | 09:24 PM
pennidragon
yeah i know i usually get all my tires from tire rack but my mini dealership gave me a quote for the pirelli p7 all season RF that's only $23 more compared to tirerack (but tirerack i gotta pay $15 for shipping and also my dealer gives me 10% off everything so it's not too bad) tirerack does have a $60 off promo now but it's for 4 tires
Old Apr 24, 2015 | 09:27 PM
bjcarter2's Avatar
bjcarter2
As bmwr606 said, Tire Rack will shave tires. I had them do once once when a tire was severely cut on the sidewall. You just tell them how much and they will do the rest.
Old Apr 24, 2015 | 09:33 PM
pennidragon
yep just saw the post from bmwr606 (thanks for info!) and read it on their website, I just ordered a tire tread gauge on amazon and I'm going to get a reading on the other 3 tires. if it's only 1-2 off from 10/32' ill just have the dealer change the one bad tire, if it's more ill order from tirerack and have them shave it off. thanks for all the help guys
gmonde
Sep 8, 2015 06:37 AM
Colt45Magnus
Sep 7, 2015 10:47 PM
Powershift
Aug 16, 2015 05:14 PM
JamJam43087
Aug 16, 2015 02:02 PM
sabjcw
Aug 14, 2015 07:40 AM
