R60 Mini R60 DIY 2nd cat delete and resonator
Old Dec 14, 2014 | 08:56 AM
Katherine.mc's Avatar
Katherine.mc
Hello!
I'm new to the forum, however I've been doing research to delete my r60's second cat and resonator plus k&n air filter. I know that there are a few people who have done this however I haven't seen many DIY jobs. I know I need to get a 2.25" test pipe and was wondering if there are any recommendations as to where to find ones or any other tips before I start messing with my mini. Any feedback is appreciated!
Old Dec 15, 2014 | 10:13 AM
yetti96's Avatar
yetti96
I went to a mechanic with an exhaust machine so he could flair the fittings. Any exhaust shop will be able to do it cheap. Some may not cut the 2nd cat off, maybe you could cut it off before going.
Old Dec 29, 2014 | 12:12 PM
CPap's Avatar
CPap
Originally Posted by Katherine.mc
Hello!
You will need:
1. One of these - http://www.jegs.com/p/Patriot-Exhaus...97250/10002/-1 find the 2.25" OD pipe
2. Two butt connection band clamps. The band clamp should measure 2.25" ID on the inside of the band clamp.
3. One angle grinder
4. One pair of goggles
5. a lift or jack stands.
If you know how to weld, that's the better way to go... although I have had good success with the band clamps.
Heres a thread on how some people did it. https://www.northamericanmotoring.co...elete-cm4.html
Old Dec 29, 2014 | 03:12 PM
countrymanman's Avatar
countrymanman
Mine was easy. Drove up onto the rhino ramps, crawled under with a chaincutter I borrowed from o'reilly's. Cut out the cat and resonator, clamped in the pipe I also got from o'reilly's. Later I decided I wanted it cleaner, went to muffler shop and had them weld pipe so it was perfect. Once the cat is gone, they'll do whatever you want. They just won't remove it for you.
Old Dec 29, 2014 | 07:42 PM
miniwpbear's Avatar
miniwpbear
How much did the shop charge for the weld? Local or chain shop?
Old Dec 29, 2014 | 08:01 PM
countrymanman
I think $160 at master muffler. They made new downpipe back piece with flex pipe welded to myamyaftermarket exhaust
Old Dec 30, 2014 | 10:35 AM
miniwpbear's Avatar
miniwpbear
Originally Posted by CPap
You will need:
Are butt connection band clamp or lap joint clamp better for this job?
Are you using Mild Steel Exhaust Tubing from Jegs, 18 Gauge, 2-1/4'' Tube Diameter, 5' Length?
Is the size of 2 1/4" used so it slides over the stock 2 1/8" tubing? Wouldn't 2 1/8" tubing be better with butt connection clamps or use lap joint clamp if using 2 1/4" straight pipe?
Is the Mild Steel tubing quality sufficient?
What is the length of tubing needed; it says sold in 5 ft sections?
Old Dec 30, 2014 | 05:01 PM
CPap's Avatar
CPap
Are butt connection band clamp or lap joint clamp better for this job? Are you using Mild Steel Exhaust Tubing from Jegs, 18 Gauge, 2-1/4'' Tube Diameter, 5' Length? Is the size of 2 1/4" used so it slides over the stock 2 1/8" tubing? Wouldn't 2 1/8" tubing be better with butt connection clamps or use lap joint clamp if using 2 1/4" straight pipe? Is the Mild Steel tubing quality sufficient? What is the length of tubing needed; it says sold in 5 ft sections?
Either lap or butt will do the job. Just need the appropriate pipe size to make it work one way or another. 2 1/4" OD pipe matches what's on the mini. The ID of a 2 1/4" OD is 2 1/8". That's what's on the mini. If you go with that, then butt joint band clamp will work. If you go with a 2 1/4" ID pipe, then get the lap joint band clamps. Stainless steel pipe should only be used. The legnth is roughly 30" I can check tomorrow.
Old Dec 30, 2014 | 05:06 PM
miniwpbear's Avatar
miniwpbear
Thanks! Great explanation.
Old Dec 30, 2014 | 10:15 PM
Mojo'jo'jo''s Avatar
Mojo'jo'jo'
don't know how to add a pic on here yet but I have a pic of my second cat out in my album. went to a shop and asked them to make me a "track" pipe so now I can pass smog when the time comes.. Im in cali so its only for track wink, wink. was only $150 . I put Manic Dp w/nocats Alta intake with Manic tune and wow. so nice. best $$$ ever spent. Mojojojo is feeling good. putting my 22 rear sway bar on tomorrow.
Old Jan 5, 2015 | 02:39 PM
miniwpbear's Avatar
miniwpbear
Got it taken care of today on my Paceman at an exhaust shop for $100. Sounds great and a little extra pull also.
Old Feb 2, 2015 | 12:05 PM
etl330's Avatar
etl330
Any sound clips? Also any warranty considerations with doing this?
Old Feb 2, 2015 | 02:48 PM
CPap's Avatar
CPap
plethora amount of info on the subject here https://www.northamericanmotoring.co...ete-cm4-6.html
that page has a sound clip. start from beginning with all the info you are looking for.
06BLKchrgd
GP Talk (2006)
Feb 14, 2016 12:07 AM
tr3y003
Oct 22, 2015 10:48 AM
honderpilot
Aug 31, 2015 02:53 AM
Aug 10, 2015 02:03 PM
Aug 10, 2015 01:59 PM
