R60 Rail Cup Holder Question
Old Aug 22, 2014 | 06:11 AM
Vegasbaby's Avatar
Vegasbaby
Thinking of buying the rail cup holder for my 2014 CM to use as a change holder. There's just nowhere to put change without sacrificing a front cup holder.
I've read some conflicting posts about it not fitting with the e-brake and armrest. Haven't been able to find any pictures though.
Anyone out there have this set up?
Old Aug 22, 2014 | 07:59 AM
puravida's Avatar
puravida
I use the Mini rail-mounted sunglasses holder to carry change. It fits nicely underneath the arm rest. No interference with e-brake or armrest.
Old Aug 22, 2014 | 09:19 AM
Vegasbaby's Avatar
Vegasbaby
I've got that on there now and my sunglasses don't fit in their anyhow. Just thinking the cup holder would be more convenient. I'll keep that in mind.
Old Aug 22, 2014 | 09:32 AM
nd3boy's Avatar
nd3boy
Unfortunately, I am travelling and the extra cup holder is home in the garage. But if I remember correctly, the front cup holder can not go in front of the e-brake handle and the shifter. You need to place it on the rail far enough back otherwise when you pull up on the e-brake, the e-brake may rub the side of the cup holder. Additionally, if you have the center armrest, it may not go all the way down.
Again...going from memory
Old Aug 22, 2014 | 11:22 AM
ericraymond's Avatar
ericraymond
Cool
I installed the two rubber cable organizers (bones?) into the rail to make a small box in the rail that can hold coins. It won't hold a lot of money, but it works for me.
Attaching a picture. It's between the phone caddy and the sunglass holder.
For more storage, there are the two areas under the radio/climate control.
Old Aug 22, 2014 | 05:19 PM
bmwr606's Avatar
bmwr606
+1
i do the same
Old Aug 22, 2014 | 06:18 PM
Ragnar4841's Avatar
Ragnar4841
Ditto this. Works great.
Old Aug 22, 2014 | 07:00 PM
mikey_t's Avatar
mikey_t
I made use of the rail attachment piece for the sunglasses and mounted a small tray on top of it with two sided tape as per the attached pic. Works a treat and its easy to get coins out of without interfering with anything.
Old Aug 23, 2014 | 08:09 AM
chrunck's Avatar
chrunck
This is what I do as well. Works perfectly, though I generally don't have a lot of change in the car.
Old Sep 7, 2014 | 09:14 AM
koreyy's Avatar
koreyy
I've done that and my e-brake keeps hitting on the side of the cup, decided to take off and install extra cup holder http://www.outmotoring.com/cupholder-countryman.html
I have manual transmission so it was very annoying to pull e-brake also tried phone holder sunglass holder but no.
Old Sep 7, 2014 | 10:34 AM
HateRegs's Avatar
HateRegs
Can we get a picture of that installed? I'm constantly havign trouble fitting tall drinks anywhere but the back seat, and that part looks ideal
Old Sep 7, 2014 | 11:18 AM
koreyy's Avatar
koreyy
Also rotate side to side. Very easy installation although you will have to make a hole to put one screw on. I think 3m tapes will hold it perfectly but for secure i just put on. Very convenience cuz fits any size cups and holds strong.
Old Sep 7, 2014 | 11:21 AM
HateRegs's Avatar
HateRegs
Attachment 98913
Attachment 98914
Attachment 98915
Wow thanks, from the simple image on the website I was picturing something that was closer to the current 2 cup holders. Your images make it so much clearer
cawwwtun
May 3, 2016 08:03 AM
sevin
Aug 24, 2015 09:26 PM
Aug 24, 2015 03:14 PM
Kahnfucious
Aug 15, 2015 08:43 PM
