R60 Rivet Removal
Old Jul 26, 2014 | 12:41 PM
Mini-LSE's Avatar
Mini-LSE
Rivet Removal
I need to remove this wheel trim and wanted to see if anyone had any experience removing the small rivets?
Attached Thumbnails Rivet Removal-screenshots_2014-07-26-14-32-29.jpg   Rivet Removal-2014-07-26-14.29.57.jpg
Old Jul 26, 2014 | 01:14 PM
mikey_t's Avatar
mikey_t
Yep. They usually break. Make sure you have a few spares on-hand when you remove that trim piece.
Old Jul 26, 2014 | 01:15 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Not specific info to those, but they sell various tools to remove rivets. If you have some play in them you can often pry them out or you can drill from the top with a bit just large enough over the shaft size.
Old Jul 26, 2014 | 02:23 PM
Mini-LSE's Avatar
Mini-LSE
I did not realize that you just need to push them all the way thru the rivet and they come right out.
Thanks for the help.
Old Jul 26, 2014 | 05:33 PM
TJANK's Avatar
TJANK
Yes, you can punch in the center plastic pin of the expanding rivet and pull them out. If you can find the plastic pin you can reuse the fastener by pushing in the pin to expand the fastener (see 13 below). I like to have a couple spares incase I cannot find the pin, of decide to drill them
out.
http://www.realoem.com/bmw/showparts...71&hg=51&fg=16
Old Jul 30, 2014 | 11:02 AM
Yep,
Link to realoem diagram: http://www.realoem.com/bmw/enUS/showparts?id=ZC53-USA-01_2010_R60_Mini_Cooper_S_ALL4&diagId=51_8871#5177 9801884
Looks like #11 on the right hand side. Passenger 51779801884
http://www.ecstuning.com/Search/SiteSearch/51779801884/
Here is the #11 left hand side ( driver )
http://www.ecstuning.com/Search/SiteSearch/51779801883/
Those expanding rivets sometimes break, you have to use a very small flat head or driver to push the pin through , then pop off. they can use 2 different types a 11mm or 16mm , measure the old one and then match up .
11mm
http://www.ecstuning.com/Search/SiteSearch/07149807127/ES2136399/
16mm
http://www.ecstuning.com/Search/SiteSearch/52108099299/ES2675874/
Old Oct 16, 2018 | 05:33 AM
15junglegreen's Avatar
15junglegreen
Yep,
Those expanding rivets sometimes break, you have to use a very small flat head or driver to push the pin through , then pop off. they can use 2 different types a 13mm or 16mm , measure the old one and then match up .
13mm
16mm
Ecs did you mean 11 and 16 on the rivet sizes? That first link takes you to an 11mm rivet. Wasn’t there a kit available with an assortment of these?
Old Oct 16, 2018 | 05:39 AM
Updated and fixed, link to realoem updated also. Was an old thread so the diagram has been updated. No kit, just add to cart the totals.
Old Nov 1, 2018 | 08:29 PM
Alpha Motoring's Avatar
Alpha Motoring
IIRC the dealer told me most of the bodywork on the R60 takes 13mm rivets, don't waste your time trying to preserve them, they're extremely cheap and are meant to be one time use deals.
The_Kid
Nov 3, 2016 06:30 PM
BRracing
Oct 24, 2015 10:07 PM
Crimguy
Sep 10, 2015 01:07 PM
Sep 2, 2015 11:15 AM
Sep 2, 2015 09:05 AM
