R60 Order my CMs Today - Need help
Old Feb 23, 2013 | 08:57 AM
rdd337's Avatar
rdd337
Hi All, I will order my fist CMs today and I need some input from experts here:
1) Should I buy the extended warranty called "Program Maintenance" $1895- total 6yrs 100,000?
2) Option "Piano Black Cockpit Surface" - free but is this just a black sticker across the dashboard? not so clear on mini website. should I select this? I selected "Dash Surface in Black Checkered" so I dont know if the piano black cockpit surface will match or not.
3) Still debating if I get HK sound system or not.
4) Run Flat Tires or not?
these are the options im getting for sure: auto trans, flat load floor, Xenon, anthracite headliner, rear sensor, arm rest front. everything else is standard. im trying to build below $30k if possible.
Old Feb 23, 2013 | 09:06 AM
dkizerian's Avatar
dkizerian
I wouldn't get piano black. It's shiny and seems to always have dust and fingerprints.
I'd get the HK as it HAS to be better than the stock, which leave a bit to be desired.
Tacoman03's Avatar
Tacoman03
Not sure about the cockpit surface...but if you enjoy listening to music, the HK system is a no brainer. My 17 yr old daughter gives the HK system a thumbs up since I passed our CM onto her for her first car....as far as the run flats, ours came with as we were not given the option in 2011 when we ordered ours, but within 2 months after delivery, i had those bad boys switched for Non Run Flats....would opt for Non Run Flats if you can.....
Old Feb 23, 2013 | 09:08 AM
Wobpb377's Avatar
Wobpb377
I would not get the ms program. Id upgrade to the HK like others have said. And here are two photos of piano black and the carbon. Sorry for poor photo quality. Sun wasn't working with me.
Old Feb 23, 2013 | 09:11 AM
rdd337's Avatar
rdd337
thanks for the replies. Any input for the extended warranty?
Old Feb 23, 2013 | 09:14 AM
rdd337's Avatar
rdd337
thanks for the pictures but this is for the "Dash Surface" option, do you have a picture for the "cockpit surface" with piano black and without? thanks for your input about MS & HK sound.
Old Feb 23, 2013 | 09:18 AM
rdd337's Avatar
rdd337
btw i selected black checkered for the "Dash Surface"
Old Feb 23, 2013 | 09:40 AM
Leader's Avatar
Leader
Isn't the extended warranty something you can purchase anytime during the OEM warranty period (i.e. the first 36 months)?
The extended warranty makes more sense if you know you love the car and are going to keep it well beyond the original warranty period.
Why not put off that $1895 decision until you decide how much you like the car?
All your other choices look good, BTW.
Old Feb 23, 2013 | 09:44 AM
rdd337's Avatar
rdd337
Thanks. I was thinking about this too. If I can add it before the manfacture warranty expires then Ill wait and see if I like to keep the car any longer.
Old Feb 23, 2013 | 10:16 AM
FredoinSF's Avatar
FredoinSF
Read the fine print. Is it a warranty against parts that fail or maintenance where they change the oil once a year? If former, it depends on whether you think you will keep the car that long and think you will have a major failure during that period. If maintenance, it's a pass IMO.
I have it and I like it (others don't) but it looks like you already decided to go with somehting else so that's perfect.
I did and I think it's just OK. Makes me wonder what the standard system sounds like.
CM's only come with run flats. You can pick summer or all season, but they are all runflats.
Old Feb 23, 2013 | 10:32 AM
dgator39's Avatar
dgator39
Q1 no you can wait you have 3 years before you cross that bridge
Q2 piano = NO, go with the other option
Q3 HK for sure it sounds great and is worth it
Q4 run flats are not the smoothest ride but good to have for safety especially with the lack of spare
HAVE FUN MOTOR ON...............
Old Feb 23, 2013 | 08:41 PM
52804x4's Avatar
52804x4
Personally I would get the extended warranty! My CMS4 will be a year old next month and has been back for warranty work 5 times. My standard 36k warranty will be up in about 8 months. I am going to have to shell out the $1900 in cash now to extend the warranty so that they will cover this clutch when it dies in the next few months. (And it WILL)
Old Feb 23, 2013 | 10:15 PM
FredoinSF's Avatar
FredoinSF
Check the fine print because most warranties do not cover wear items. The clutch typically falls under wear items category.
Old Feb 24, 2013 | 08:17 AM
chrunck's Avatar
chrunck
I'd get the cockpit surface in whatever finish you're going to have on your doors.
Old Feb 24, 2013 | 08:56 AM
sbdubya's Avatar
sbdubya
Extended Warranty for Repairs- No wait and buy it from another provider ie Costco much cheaper.
Piano- Yes, I have it and think it looks good.
HK- Yes, I have it and it is good except for the low end bass.Not much thump there but there are many threads on how to improve it.
It is going to have run flats no matter what from the factory. Replaced mine at 12k due to a side wall break after hitting a nasty pothole.Ride is much better with non rf's. The rf's will probably only last 20k-25k miles.
Good luck and Enjoy.
Old Feb 24, 2013 | 12:06 PM
mbabischkin's Avatar
mbabischkin
Check with your insurance company on the Extended Warranty...
Geico has a 7 year 100,000 coverage that works out to be 10% or less of the cost of a policy from MINI - however you need to add it to your coverage within 15 months of purchase. The Geico policy has a $250 deductable - but I'll take $490 over 7 years over $6k or so over 5 years...
bneer
Jul 15, 2019 04:41 PM
F55MidnightBlackCooperS
Jul 6, 2016 03:13 PM
SunnySideUp
11
Aug 26, 2015 06:42 AM
bneer
Aug 20, 2015 05:38 PM
spec35
Aug 18, 2015 07:07 PM
