R60 Anyone installed driving lamps themsleves on a Countryman?
Old Jan 14, 2013 | 02:42 PM
Mr_Bueno's Avatar
Mr_Bueno
I'm being quoted a redonk amount for labor on the driving lights. This forum has so much, but I searched a bit and can't find any threads on DIY driving lamps.
Is there a step-by-step guide with pics somewhere in this forum?
Old Jan 16, 2013 | 12:53 PM
Mr_Bueno's Avatar
Mr_Bueno
Beuller?.... Beuller?...
Anyone?
Old Jan 16, 2013 | 04:20 PM
GeoffreyM's Avatar
GeoffreyM
Check over in the mods section. There is one.
Old Jan 16, 2013 | 04:47 PM
sap_2000's Avatar
sap_2000
I did. Took about 4 hrs. Not a job for people with 10 thumbs, but absolutely doable. The instructions are ok, but the wiring diagram of the fuse box did not match, so had to measure a bit.
I made a post about the install last spring. Look at my posts and you'll find it
Old Jan 16, 2013 | 05:05 PM
sap_2000's Avatar
sap_2000
Here is the post
https://www.northamericanmotoring.co...ml#post3497349
Old Jan 16, 2013 | 10:45 PM
FredoinSF's Avatar
FredoinSF
I did my own VIP quad light kit install. Easily doable if you can follow instructions and somewhat DIY inclined.
Old Jan 17, 2013 | 08:02 AM
kerrys914's Avatar
kerrys914
Agree and same here. I have the dual VIP kit and it wasn't that bad to install. I did mine over two days just (mounted the lights day one and then did the wiring on day two). Nice and slow and faily easy.
Old Jan 17, 2013 | 03:44 PM
jthorst75's Avatar
jthorst75
I noticed in the instructions above that there is no switch in the diagram or even in the kit itself. sap 2000 told me that the Euro CMs do not have a switch. I had to refer to other instructions just to wire it in properly. Does this mean that the Euro CM's driving lights are on when the headlights are on? I am not sure that will fly legally over here? Anyways I am installing mine now and I am confused of the 1.5 hr time given for the install. I have to triple that for it to make sense and this is my second install. Only if Mini would charge 1.5 hr labor, that would be nice but highly unprobable.
Old Jan 17, 2013 | 05:38 PM
MiniCM12's Avatar
MiniCM12
I see you have a CMSA4, but I added lights to a base CM. I installed the factory mounting brackets (FYI - get the kit from Mini since you need to replace the grill too), then I added PIAA 510's. I wired into the high beams. Mounting was a little effort - but doable. Total time - 3 hrs.
Old Jan 18, 2013 | 03:04 AM
sap_2000's Avatar
sap_2000
No. They turn on with the hi beams. The #41 pin is supposed to give feed to the relay when you activate hi beams. In my CM as well as on others, I javelin red its not pin 41 as the instructions seems to be for r56. But easely found the right pin with a multimeter while turning on and off the hi beams..
The "driving lights" are hi beams and not driving lights/ lo beams. I think the name is misleading.
Old Jan 18, 2013 | 05:10 AM
kerrys914's Avatar
kerrys914
I have mine wired (right now) to run anytime I want. I the a switch on the drivers side that controls them (on/off) independent of my headlights.
So far it meets my needs just fine and was very easy to do.
Cheers and good luck
Old Jan 18, 2013 | 05:11 PM
jthorst75's Avatar
jthorst75
So I finally got this finished. Pin 41 red/yellow (which was used per manual) did not work for me but I wasn't aware that they were only to be used with the high beams. So I tapped into the power wires for the switch. Now they can be switched on via supplied switch in any light position. I am happy for now.....I wouldn't mine updating the bulbs to match the blue in the Xenons. Overall install (besides wiring) was easy, the routing thru the engine compartment was a pain.
Old Jan 18, 2013 | 09:12 PM
ok4now's Avatar
ok4now
Yes
I did install Hella 500 driving lights. Didn't had time to wire it tho.
Look wise, it came our perfect in my mind and I think it looks better than oem.
squawSkiBum
Oct 2, 2015 09:21 AM
DWooderson
Aug 10, 2015 09:12 AM
