R60 all4 owners: notice a popping sound when reversing and turning sharply?
Old May 10, 2012 | 09:55 AM
inh's Avatar
inh
This has happened to me a few times: when backing out of a parking space and turning the wheel to full lock I can hear and feel a sort of popping/jerking. It is a lot like what happens when you leave a 4 wheel drive vehicle in 4wd and try turning on pavement. Makes me wonder if its the all system acting up...
Old May 10, 2012 | 10:53 AM
ozarkgolfer's Avatar
ozarkgolfer
Not on my ALL4 - I would take yours back to the dealer and if they give you the old 'they all do that' insist on a test drive in their demo to determine if they really do!
Old May 10, 2012 | 12:55 PM
ghamma's Avatar
ghamma
Checked mine today
+1
Old May 10, 2012 | 01:00 PM
Royson G's Avatar
Royson G
Yes, I have noticed this on mine.
Old May 10, 2012 | 01:13 PM
bmwr606's Avatar
bmwr606
have not noticed this ...
since seeing this thread, i have made a point of going full lock, both right and left while reversing, no noise, no jerking, and i would know it if it was happening, my 4wd p/u does not have a center diff and will hardly move on dry pavement at full lock
scott
Old May 10, 2012 | 02:00 PM
Brad79's Avatar
Brad79
I have this issue as well with my All4
Old May 10, 2012 | 03:27 PM
inh's Avatar
inh
I tried to narrow down when it happens but no luck so far. The drive train was warm, however. I'm going to see how it is when I leave work and then again in the morning before anything has warmed up.
Old May 10, 2012 | 03:50 PM
52804x4's Avatar
52804x4
I also get this "popping" with my CMS4!
Old Jun 18, 2012 | 05:56 PM
Brad79's Avatar
Brad79
Has anyone figured out the root cause of this issue?
Old Jun 18, 2012 | 06:28 PM
shark715's Avatar
shark715
Although mine does not make the noise (well at least not yet with only 500 miles on the clock), it does sound most like a CV joint, and if that's the case, it's likely nothing to be concerned about. Do you feel anything in the steering wheel when it happens? If it's not a CV joint, it might be normal noise from one of the differentials. Again, as several owners are hearing it, it's probably not an issue. Then again, it costs little to demonstrate the noise to your service department and see what they say.
Old Jun 18, 2012 | 08:25 PM
inh's Avatar
inh
Wondering if it's just a case of RPMs dropping too low while reversing because you're paying more attention to what's behind you than the speed of the engine.
Old Jun 19, 2012 | 05:02 AM
lego's Avatar
lego
Isn't this "normal" for AWD?
I'm pretty sure it happened to a couple of Subarus I drove before, but that was a long time ago.
Old Jul 1, 2012 | 10:57 AM
greenfire's Avatar
greenfire
I have this exact issue. Seems to be when starting off on a tight turn. I think it is the 4wd binding. Im guessing since we start off with a 50/50 split of the 4wd there is some binding. Reminds me when you have 4wd engaged, say in an suv, on dry pavement.
Old Jul 1, 2012 | 12:01 PM
old81's Avatar
old81
M6
Had this on our ALL4 S back in January, it turned out the rear diff clutch pack was failed and it was replaced under warranty.
If it gets constant and not once in a while have the dealer check for a puma alert on diff clutch pack failures.
Don
patrioticmini
Aug 20, 2015 10:54 AM
spec35
Aug 18, 2015 07:07 PM
I_drive_slow
Aug 18, 2015 10:47 AM
damncajun
Aug 17, 2015 08:25 PM
BoCRon
Aug 17, 2015 01:21 PM
