R60 Handbrake
Old May 4, 2012 | 12:11 PM
stripesace's Avatar
stripesace
Handbrake
Anyway to replace this thing with something less intrusive? I mean... its a long shot.. but whats it hurt to ask?
Old May 4, 2012 | 12:27 PM
Mojito's Avatar
Mojito
Someone should be fired for that design. Doesn't work with the rail accessories at all
Old May 4, 2012 | 02:28 PM
ghamma's Avatar
ghamma
Search CountrymanTalk for "handbrake" and you'll find lots of discussions...
Old May 4, 2012 | 06:22 PM
grawk's Avatar
grawk
aftermarket opportunity!
Old May 5, 2012 | 06:36 AM
Koopah's Avatar
Koopah
Have at it!
Old May 5, 2012 | 04:54 PM
JasonCarp's Avatar
JasonCarp
http://www.motoringwerks.com/p-1808-...ke-handle.aspx
It says it fits the R60. Not so sure.
Old May 6, 2012 | 07:43 AM
countryman-s's Avatar
countryman-s
I bet that motorwerks handle fits sideways like the original
Old May 6, 2012 | 07:46 AM
countryman-s
From that exploded view it looks like a straight handle is possible? It's not easy to find wrecked mini's around here to attempt swapping.
Old May 6, 2012 | 09:01 AM
ghamma's Avatar
ghamma
From the drawing it looks like an alternative arrangement could be set up...a "normal" handle with latching and release for parking, combined with a more accessible handle (WRC style) that would not latch but one could use for handbrake turns? The latching handle would override, and it wouldn't have to be bent.
Old May 8, 2012 | 05:17 AM
tatacountry's Avatar
tatacountry
It would be great if this worked... i hope someone is brave and skilled enough to try it.
Old May 8, 2012 | 05:46 AM
iMom2005's Avatar
iMom2005
It seems to me that the part that they indicate fits the Countryman, is the Whalen Shift Machine...also advertised on that same web page. http://www.motoringwerks.com/p-1808-...ke-handle.aspx
"Whalen Shift Machine
The Stainless Steel, Brushed, Contoured Handle (left side of the photo) was designed to be the perfect complement for our matching Brushed Stainless Shift ****. If you are using one of these superb shift ***** on your BMW or MINI you will like the look with the complete the set with this handle."
Old May 8, 2012 | 06:27 AM
ghamma's Avatar
ghamma
Very interesting alternative...but I don't see how it can work on the R60 after staring at the drawing and then at the car.
Hmmmm....
Last edited by ghamma; May 8, 2012 at 07:57 AM. Reason: revised after staring at handbrake
Old May 8, 2012 | 06:53 AM
iMom2005's Avatar
iMom2005
The text on that web page is a wee bit perplexing ...handbrake, shift ****, left side of photo, fits a Countryman....
If anyone sorts it out, and finds a viable alternative to the stock handbrake, let me know.
Old May 8, 2012 | 07:17 AM
Koopah's Avatar
Koopah
All to often, people who post stuff for sale just roll-in the R60 to the list of models on which their product fits. Just go to the For Sale stuff on NAM and cheek out how many four-bolt wheels are advertised to fit the R60!
No doubt Whalen makes terrific products; I'm a customer for my 2004 MCS. However, I believe the fitment guide for the shift machine (which does fit the R60) was mistakenly cut and pasted into the handbrake handle info. The mechanics of the R60 handle have the release button actuating a lever that runs from the handle-end of the handbrake arm to its pivot point at the base. Theoretically this lever then disengages a toothed "stop" to allow the handbrake arm to pivot downward. Thus, the mechanics (and the 90º angle) are most likely not compatible with a plunger-type actuator.
Those interested in this item should call Whalen to verify compatibility with the R60.
FWIW,
Old May 8, 2012 | 02:37 PM
ghamma's Avatar
ghamma
One provided link points to a CravenSpeed handbrake product offered through MotoringWerks, part number CRMC-0059.
Tarin Shalow of CravenSpeed reports:
"You are correct, the Countryman handbrake is too different from other MINIs, our hand brake handle is not compatible."
Still looking...
Old Oct 7, 2013 | 04:48 PM
sportysally's Avatar
sportysally
Anyone know if the 2012 CM handbrake works like the 2006? If so, these guys might work. They also have a matching weighted shift **** like TMW/Whalen (2" diameter, SS) with two options for color. I'm thinking about buying both to save on shipping; but am hesitant until I can be more certain of the handbrake fitment.
http://www.storm-motorwerks.com/USA/...ke_handles_v1/
Old Oct 7, 2013 | 05:47 PM
chrunck's Avatar
chrunck
The pic on that website is at least a 2007.
I'm not totally sure how the handle attaches on the CM hand brake, but I doubt that would work.
Old Oct 12, 2013 | 06:12 PM
Koopah's Avatar
Koopah
RealOEM is your friend! I think there is absolutely no way the two would be compatible.
R56 Handbrake:
R60 Handbrake:
Old Oct 25, 2013 | 07:39 PM
sportysally
Originally Posted by Koopah
RealOEM is your friend! I think there is absolutely no way the two would be compatible. R56 Handbrake: R60 Handbrake:
Thanks for the suggestion. Maybe I can reference that site when asking Storm Motorwerks to make a shift **** that would work.
Old Oct 27, 2013 | 05:03 AM
Sealy's Avatar
Sealy
I rather like the hand brake set up. I think it compliments the usefulness of the center rail and arm rest perfectly.
Sealy - Who wishes there was some way to block more of the switches when he uses the cup holder.
RobbyD
Jan 29, 2019 01:22 PM
mickymow
Jan 25, 2016 01:54 AM
DaveTinNY
26
Sep 1, 2008 06:38 AM
mattcoon
Apr 11, 2004 05:15 AM
FraserBonnett
Feb 13, 2003 04:49 AM
