R60 Wheel bolt torque
Old Dec 25, 2011 | 05:53 PM
camucho's Avatar
camucho
Wheel bolt torque
I want to rotate the tires and save $350 that the dealership charges for rotation and alignment. I read the owner's manual, it states the proper torque is over 100 lbft (140nm), very high if I compare to my old CR-V of around 30lbft or 2002 Mini Cooper. Is this correct of is a missprint?
Old Dec 25, 2011 | 11:25 PM
oldvintageiron's Avatar
oldvintageiron
100 lbs is right. They are 14mm bolts, not the little 12mm studs like the old crv.
Old Dec 26, 2011 | 05:00 AM
yetti96's Avatar
yetti96
FWIW, the alignment does include adding 400lb of sand bags to the car to pre-load the suspension and align it then...BMW does it too. Still pricey, but not your typical tire shop alignment.
Old Dec 26, 2011 | 05:59 AM
John Richard's Avatar
John Richard
I'm pretty sure the exact figure is 107 pounds. The lug nut wrench supplied in the tool kit is not capable of removing the bolts. I had to buy a 19mm socket, breaking bar and torque wrench that will get the job done. I keep these in the tool kit.
Old Dec 26, 2011 | 06:23 AM
yetti96's Avatar
yetti96
I know this is a R60 thread, but here is from my '09 R56...
Old Dec 26, 2011 | 09:21 PM
Jeremy Brooks's Avatar
Jeremy Brooks
The 2012 R60 spec is also 103.3 ft/lb.
Old Dec 27, 2011 | 11:20 AM
camucho's Avatar
camucho
Sorry guys, I'm getting older. I *NOW* remeber the old CR-V torque is about 80lbft and the R50 Mini tire pressure is about 32 psi. Thank you for all the replies.
Old Dec 28, 2011 | 05:10 AM
Hobie44610's Avatar
Hobie44610
How often are you guys rotating your RF's? I just did mine at 5700Mi.
Was also a good opportunity to give the wheels a thorough cleaning while they were off.
Old Dec 28, 2011 | 06:59 AM
yetti96's Avatar
yetti96
Every 5k mi or every oil change, 7500mi.
Old Dec 28, 2011 | 05:44 PM
Jeremy Brooks
So I just had the dealer rebalance the wheels to get rid of vibration. And the paperwork says they torqued the bolts to 80 foot pounds.
I am guessing that this is automatically inserted text that their system puts in, and I'm 99% certain that they do not actually torque the wheel bolts, but just pneumatic wrench them on like any tire shop. But it's really irritating to see that my vehicle is now officially out of spec from the dealer.
Old Dec 29, 2011 | 04:01 AM
TNCountry's Avatar
TNCountry
Alright, good excuse to buy a bigger torque wrench.
SosoMINI
Nov 22, 2015 03:17 PM
ShadyCoop
Aug 24, 2015 06:05 AM
col127
Aug 21, 2015 02:11 PM
minipopkart
Aug 13, 2015 05:22 AM
minipopkart
Aug 9, 2015 12:13 PM
