R60 Help about mounting CHROME BRAKE COOLING DUCTS
Old Nov 10, 2011 | 03:11 AM
JoanManuel's Avatar
JoanManuel
Wink Help about mounting CHROME BRAKE COOLING DUCTS
Hi
Sorry for asking about something that seems very easy, but i'm not sure if will be only in apearance..
Some one can help me about how to mount this? some tip for mount unmount?
http://new.minimania.com/web/Item/G2.../InvDetail.cfm
Thaaanks!
Old Nov 10, 2011 | 11:16 AM
Theta's Avatar
Theta
I've searched ISTA for half an hour trying to find a guide for you without much luck. Here's a graphic of the part replacement.
It looks like it's just two clips on the bottom that need to be pulled out. I hate to say grab it and pull, but that's what it looks like:
Here's another view from behind the bumper - looks like clips to me. You can also remove the lower 'spoiler' / air foil and just unclip the lower ornamental grille from behind.
Old Nov 10, 2011 | 11:52 AM
Locust's Avatar
Locust
They look like they just snap into place. I was looking to get them too, so let me know how you get them on.
Old Nov 10, 2011 | 02:50 PM
Bmtespar's Avatar
Bmtespar
I am curious as well. Any idea of cost for them? I seem to remeber someone posting about it but can't remeber the post. I think they said you just pull hard on them. I'll ask the dealer tomorrow when I pick up my car.
Old Nov 10, 2011 | 04:11 PM
Theta's Avatar
Theta
The OP's link shows them at just under $100 from that sponsor.
If this helps any of you, here are the part numbers for these:
51 11 9 803 941 - Left Chrome
51 11 9 803 942 - Right Chrome
51 11 9 803 939 - Left Black
51 11 9 803 940 - Right Black
You really don't want to know the dealer order cost on these...
Old Nov 10, 2011 | 11:04 PM
JoanManuel's Avatar
JoanManuel
Thanks guys.. this week end I will see in the car if is easy to pull .. (before buying)... if some one has new infos. please dont forgot post somethng about it
Old Nov 11, 2011 | 05:12 AM
Rktcyntst's Avatar
Rktcyntst
I ordered my car with the the CR ones and had the dealer install before I picked up. I'll see if I can get some shots of the removed parts on the shelf in my garage to give you an idea of what's holding it in place. If I recall correctly, it's just a bunch of tabs that snap into place around the perimeter of the duct. Appears that it may just be careful removal by prying with a tool that won't scratch/mar.
I'll be I paid too much for this dealer install to be done...
Old Nov 11, 2011 | 11:07 AM
Theta's Avatar
Theta
Here's a big picture from -=gRay rAvEn=- from his marketplace thread. This shows the top clips (they're inverted), so it gives you an idea of where to squeeze from.
Old Nov 11, 2011 | 03:05 PM
ryanhaddad's Avatar
ryanhaddad
Here are the photos from another thread of the original ducts after I removed them doing this mod.
https://www.northamericanmotoring.co...ml#post3373195
Old Nov 11, 2011 | 03:19 PM
Theta's Avatar
Theta
Perfect!
Old Nov 15, 2011 | 10:38 AM
SewellParts's Avatar
SewellParts
I usually start by pulling at the outside corner of the vent and work around it. You can use a small screwdriver to help you pry around it. Very clean, lost cost, and easy mod.
http://mini.sewellparts.com/accessor...2011/4892.html
Old Dec 26, 2011 | 08:01 AM
hdzcar's Avatar
hdzcar
Brake Duct install
Installed the chrome brake ducts this morning. Took about 5 minutes per side.
I used some plastic door panel tools I had but any thin flat tool would work. Just look at the tabs on the new brake ducts so you'll know where to pry out to release.
Attached Thumbnails Help about mounting CHROME BRAKE COOLING DUCTS-brake2.jpg   Help about mounting CHROME BRAKE COOLING DUCTS-brake1.jpg   Help about mounting CHROME BRAKE COOLING DUCTS-brake3.jpg
Old Dec 26, 2011 | 08:35 AM
Sealy's Avatar
Sealy
Good work. Next Up: Clear turn lenses, silver bulbs.
Old Dec 26, 2011 | 09:30 AM
Cobra-racer's Avatar
Cobra-racer
Sealy,
Silver bulb replace is easy fix? I think that would look really cool in my CMS.
Old Dec 26, 2011 | 01:05 PM
Sealy's Avatar
Sealy
The sliver bulb part is easy - there's an extensive post about it. However, without the clear lenses, you're still going to have yellow eye.
Old Dec 27, 2011 | 05:10 AM
Cobra-racer
Yes, I have gone through the silver bulb post but I figured I would ask the "expert". I have clear lenses. Heck, it seems I have every freaking option including the flat load floor that I didn't order.
Old Aug 3, 2013 | 11:55 AM
marcimpala's Avatar
marcimpala
Thanks for the tips guys on the air ducts, I installed mine this week on my R60. It takes about 5 minutes and no tools, just work a small bit of plastic (like a frequent shopper card) into the groove and gently release the tabs. Do top two first then work around and gently pry out. BTW, Sewell had them for $59.
Old Aug 3, 2013 | 12:03 PM
marcimpala's Avatar
marcimpala
Here are some photos of the ducts
Help about mounting CHROME BRAKE COOLING DUCTS-forumrunner_20130803_150145.jpg
Help about mounting CHROME BRAKE COOLING DUCTS-forumrunner_20130803_150157.jpg
W0TM8
Dec 19, 2019 07:50 AM
ebowling
90
Aug 4, 2019 09:15 AM
minimofo
Factory JCW Talk (2009+)
130
Oct 14, 2016 06:14 AM
Powershift
Aug 16, 2015 05:14 PM
