R60 Help needed for a epic undertaking..
Old Jun 6, 2011 | 12:43 AM
Nimrandir's Avatar
Nimrandir
Talking Help needed for a epic undertaking..
Guys i'm trying to retrofit the sport button on my cooper S all 4 (here in italy isn't standard), i need a kind soul to help me figuring out the cable setup...
I need a picture of the connector X14272 in the JBE (Junction Box Electronics):
This is mine, and technically is missing 2 wires in the black part of the connector...
This a pic of the JBE
I need someone to look and tell me if there are 3 cables that go in the black part of the connector... Pleaseeee help me!!!
Old Jun 6, 2011 | 05:39 AM
KiwiRob's Avatar
KiwiRob
why would you bother, the sport button makes bugger all difference, it's even harder to detect the changes in steering and throttle response than the sport button made in my Clubman.
Old Jun 6, 2011 | 06:17 AM
Nimrandir's Avatar
Nimrandir
Well... it's a 0$ mod, so why not And most of all because now i'm at 99% of the work... Just miss the right pin!
Old Jun 6, 2011 | 07:13 AM
KiwiRob's Avatar
KiwiRob
Do you also have to reprogram the ECU to get the better throttle response?
Old Jun 6, 2011 | 07:18 AM
Nimrandir's Avatar
Nimrandir
You need to reprogram the ECU and tell it that you have the sport button. I already did that, now what is missing is the physical switch to turn it on
Old Jun 8, 2011 | 01:23 AM
Nimrandir's Avatar
Nimrandir
No one willing to help?? :( Its a 15min job!!
Old Jun 8, 2011 | 04:26 AM
Miniblue2's Avatar
Miniblue2
Can you wait for the weekend? Also where is it located and how do you remove the carpet?
Bill
Old Jun 8, 2011 | 11:22 AM
Nimrandir's Avatar
Nimrandir
You're my hero and Yeahm i can totally wait
So it's located on the passenger side, bottom on the right... You can see a small "door".. By opening it u'll get the fuse box... Now u need to remove the plastic surrounding it... To remove it there are no screw, it's just a pulling thing...
I'll soon post some pics to show you the parts to remove
Old Jun 9, 2011 | 04:54 AM
Miniblue2's Avatar
Miniblue2
Ok. I'll post pictures of what it looks like and try to answer your question.
Bill
Old Jun 9, 2011 | 05:04 AM
Miniblue2's Avatar
Miniblue2
In your picture (color), where is connector X14272? Also, I'm having trouble correlating between the picture and the B&W figure.
Maybe it will be clear when I have the actual in front of me.
Thanks,
Bill
Old Jun 9, 2011 | 02:34 PM
Nimrandir's Avatar
Nimrandir
Thanks,
Bill
Yeah, i know... I also had some thinking with just the BW pic, that's because the bw draw is horizontal while in real life the box is vertical
In this picture is the last one on the right bottom... Left near the C-G write, under the RL12...
Old Jun 10, 2011 | 04:02 AM
Miniblue2's Avatar
Miniblue2
That makes it easy. I'll post later today or in the am.
Bill
Old Jun 10, 2011 | 06:05 AM
Nimrandir's Avatar
Nimrandir
Thanks a lot!
Old Jun 10, 2011 | 01:57 PM
Miniblue2's Avatar
Miniblue2
Looks like I have only one wire as well. Let me know if this helps or if I need to dig deeper.
Bill
Attached Thumbnails Help needed for a epic undertaking..-624-sm.jpg   Help needed for a epic undertaking..-626-sm.jpg
Old Jun 10, 2011 | 02:50 PM
Nimrandir's Avatar
Nimrandir
Bill
You have the sport button right? If so...... damn... They changed the position of the sport button pin......
Thank you so much.... You were very kind and to me, you're the essence of a real online community
Old Jun 10, 2011 | 03:20 PM
Miniblue2's Avatar
Miniblue2
Yes, I do have the sport button. I was afraid the box looked a bit different.
It was a pleasure and good luck in your quest.
Bill
mini_z's Avatar
mini_z
Hope this helps:
Originally Posted by el_Zilcho
You can't using the mini options.
There is this http://www.waymotorworks.com/auto-sp...de-module.html
Not sure if it would work for the R60 though.
Old Jun 11, 2011 | 04:18 AM
Nimrandir's Avatar
Nimrandir
Originally Posted by mini_z
Hope this helps:
unluckily it will not work on the R60 because of the missing cable in the connector :(
Old Oct 12, 2019 | 01:33 AM
Alessandro Caporale's Avatar
Alessandro Caporale
good morning, I apologize for the inconvenience. even if it's been a long time have you managed to find the right cables? thank you so much Alexander
mishanja
Jun 22, 2016 09:59 AM
iwant2knowwhois
11
Sep 19, 2015 12:18 PM
Rennfahrer555
Aug 13, 2015 09:07 AM
minipopkart
Aug 13, 2015 05:22 AM
Aug 12, 2015 01:24 PM
