R60 Silverstar Ultra advice
Old Mar 20, 2011 | 02:09 PM
mrod79's Avatar
mrod79
hello all,
I went to my local pep boys to look into getting silverstar ultra headlights.
They had several models of ultras available, but wasn't sure which would fit/work with the CM.
Here where the choices available:
9007SU BP
9003SU BP
H7SU BP
9004SU BP
Which model do I choose?
Old Mar 20, 2011 | 02:21 PM
mini coop's Avatar
mini coop
Look in your owners manual. It will be listed under the bulb replacement section of your manual.
Old Mar 20, 2011 | 02:23 PM
mrod79's Avatar
mrod79
CM's are already on 2nd gen models?
Where do I check which model I have?
Old Mar 20, 2011 | 02:46 PM
siriuszero's Avatar
siriuszero
Assuming you have halogen bulbs for your lows, the owners manual says you need H13s.
Sylvania's website says you need H13, H13ST, or H13XV as a replacement
Old Mar 20, 2011 | 03:37 PM
J_Westy's Avatar
J_Westy
Silverstars are marketing hype.
Do yourself a favor and consider a better bulb.
AFAIK, these are the best H13 bulb:
http://www.amazon.com/Philips-9008-X.../dp/B00480KPLW
Old Mar 20, 2011 | 03:45 PM
JudgeS's Avatar
JudgeS
I think PIAA's are better, if you can get over the ridiculous price, I'd say get Hoen's instead but they don't make H13's (better alternative for the fogs though)
http://www.amazon.com/PIAA-19618-H13.../dp/B001CTRKFQ
Old Mar 20, 2011 | 04:59 PM
J_Westy's Avatar
J_Westy
Quite honestly, PIAAs are hype too.
To the original poster, do some online reading and decide for yourself.
This is a good place to start if you need the basics:
http://dsl.torque.net/tech/bulbs/bulbs.html
Old Mar 20, 2011 | 05:46 PM
JudgeS's Avatar
JudgeS
The only reason they are "hype" is the price, they do look better, and are better quality than any bulb out there short of Hoen's (which are about the same quality, look, much better price), but are they twice the price better, I don't think so.
Old Mar 20, 2011 | 06:03 PM
J_Westy's Avatar
J_Westy
"Look"... arguably, but better light? No.
In an H13, it's hard to beat the Philips X-treme +80 bulb. And at $35 shipped, you can't beat the price either. (Not paying for the hype BTW)
Here's some info from the link I posted above.
Originally Posted by Daniel Stern
Some people feel that "whiter" light is better. Some people prefer the appearance of the headlamp when fitted with these bulbs. And then there are the True Believers, who ascribe all kinds of magical (and imaginary) benefits to "whiter" light.
Some companies (PIAA...) even capitalize on this by claiming that their 55W bulbs are as bright as 85W bulbs, among other pseudoscientific claims. Here's how this claim works: Higher-wattage bulbs of a given type generally appear whiter than lower-wattage bulbs. Think of the last time you replaced a 60W bulb in your home with a 100W bulb. So the idea with these "blue" filtered bulbs is to have a lower wattage bulb that mimics the color of a higher wattage bulb, but not its performance. However, there's no getting something for nothing. The altered light color does not mean you're getting more light, or better quality light, just that the light is of a different color.
In fact, you get less usable light from such a bulb than from a regular clear bulb, and here's why: A blue filter removes nonblue components of the light passing through it. Halogen bulbs produce very little light in the blue frequency range. When you put a blue filter on the bulb or lamp, you are reducing the amount of usable light that gets from the glowing filament to the reflector, to the lens and from there to the road. Prove it to yourself using nothing more than the windshield in your car...drive towards a yellow-orange Sodium vapor street light and watch the light as it shines first through the clear portion of the windshield, then through the blue strip at the top. Up there through the blue, it certainly looks "whiter"...but it's also dimmer. If a bulb's sales material focuses on the color of the light rather than the amount of light, you should ask critical questions about the amount of light the bulb produces before choosing to use it.
Old Mar 20, 2011 | 06:15 PM
AXO's Avatar
AXO
I have Silverstars in my 08 MCS and they made a huge improvement over stock. I want to say they were around $35.
Old Mar 21, 2011 | 10:52 AM
Mavryk03's Avatar
Mavryk03
do you have these on your car now? and where did you get them at a local auto parts store?
Old Mar 21, 2011 | 11:04 AM
J_Westy's Avatar
J_Westy
I have them in my 2005 (H7 size) and my wife's Jeep (H4 size). Awesome plain white light with no blue bling.
In an H13, you're really limited on options for quality light w/o hype.
Amazon is a safe bet price-wise -- link above. Otherwise some local shops carry them - for example Checkers in my area.
Old Mar 21, 2011 | 12:50 PM
Mavryk03's Avatar
Mavryk03
right on souinds good was looking at getting the xenons for the mini but dont know if i want to spend $600 ( $500 for xenons and $100 for the white turn sigs) since they dont let you just get the lights.
Old Mar 21, 2011 | 01:00 PM
ghamma's Avatar
ghamma
Choosing the better lights
I just placed my order for CMS ALL4 with Xenons. Before doing that I had the opportunity to drive the same vehicle with halogen and xenon lights. Then I looked at the pattern from the two types. The lensatic projector system combined with the brighter source produced a significantly more usable light pattern than the relatively unfocused halogen alternative. The automatic leveling comes along for the ride (required for street legal in CA).
I also chose the adaptive option because dumping more light into the turn on a very dark road at night is exactly the right thing to do.
I held off on my decision until I had the chance to directly compare the two options - and then it was a no brainer.
Old Mar 21, 2011 | 01:28 PM
siriuszero's Avatar
siriuszero
If you look around the CM forum, EVERYONE will tell you, if you have the option to order with xenons... GET THEM. They are worth every penny, they are far more functional, and look great!
Old Mar 21, 2011 | 04:28 PM
JudgeS's Avatar
JudgeS
By far the best value of any of the available options, and actually cheaper than most other car companies.
Old Mar 21, 2011 | 04:33 PM
mrod79's Avatar
mrod79
Forgot to post this, Silverstar Ultra H13's are not yet out for Countryman.
From what I was told by Pepboys, they will be released during the Fall.
I'm going to try the Philips X-treme bulbs.
Old Mar 28, 2011 | 08:01 AM
Mavryk03's Avatar
Mavryk03
I'm wondering how well the Philips X-treme +80 bulb or piaa or the silverstar work compared to xenons. Never had xenons so dont know how well they work and the price compared to these other bulbs are way much more? What does everyone think about that?
Old Mar 28, 2011 | 10:12 AM
siriuszero's Avatar
siriuszero
I will refer you to [this] post if you would like to hear users' opinions on the merits and values of xenon lights.
(synopsis: worth the money )
Old Mar 28, 2011 | 10:57 AM
Mavryk03's Avatar
Mavryk03
I have read some stuff in there as well, check this site out about some xeneon-max 100% bulbs, http://www.ringautomotive.co.uk/xenon-max.asp not sure about these, are these about the same as the xenons that come in the mini if you look at the video on the left?
Old Mar 28, 2011 | 03:12 PM
dlpruk's Avatar
dlpruk
I have 205/55/17 Bridgestone Dueller run-flats and sport suspension and love 'em both. The car rides beautifully with just the right amount of firmness, roll resistance and compliance and is far better in those respects than my Clubman was - both on the OEM 16in Goodyear Excellence run-flats and after swapping to normal Vredestein Sportraks. People who dis run-flats from experience with the first versions may not realse how much they've improved.
Old Mar 30, 2011 | 07:58 AM
Mavryk03's Avatar
Mavryk03
Think your in the wrong thread buddy, this is about xenons and different light
Old Apr 8, 2011 | 06:00 AM
Mavryk03's Avatar
Mavryk03
Did anyone happen to look at this website and or have these lights in their mini?
scfiveo
Sep 27, 2019 02:27 PM
rikaro
Nov 24, 2015 02:05 PM
zdw2082
Oct 5, 2015 09:59 AM
bradstyle
Oct 1, 2015 11:15 AM
bahman
Sep 30, 2015 01:59 PM
