R60 2 Lighting questions
Old Feb 22, 2011 | 04:35 PM
magpullin's Avatar
magpullin
1. How do you remove the dome light cover?
2. Is there any way to disable the automatic headlights? I would
rather they not come on whenever they feel like it.
Thanks for the help....
Matthew
Old Feb 22, 2011 | 04:42 PM
GeoffreyM's Avatar
GeoffreyM
1. Place a putty knife under it and gentle pop it off. (Then replace it with a really cool LED.....like maybe RED!)
2. You can disable them if you turn of the DRL feature, but that means the running lights turn off too. If you mean the Automatic that deals with light levels, then you just twist the light stick to off, but for it to do anything the DRL feature must be turned off.
Sidenote, I am tinkering with NCSExpert(the program BMW uses to change codes) to get to the body computer and make it so that only the low level Daytime lights tun on when the DRL option is enabled. I'll post when I have info.
Old Feb 22, 2011 | 04:48 PM
magpullin's Avatar
magpullin
Thanks Geoffrey, playing tag with you between my posts, lol.
I just don't like auto lights, I want them on and off when I say, but I
guess that's not an option now :(
Old Feb 22, 2011 | 06:44 PM
BoCRon's Avatar
BoCRon
Funny how you can get used to something. When I got my '06 the auto lights threw me for a bit then I got used to them and then relied on them. Now I'm driving the nightmare rental and I get somewhat irked that I have to stoop to turning lights on and off. Seriously, it doesn't just know?
Annette
Old Feb 22, 2011 | 09:05 PM
chrunck's Avatar
chrunck
Originally Posted by magpullin
I just don't like auto lights, I want them on and off when I say, but I guess that's not an option now :(
Are there not 4 options on the stalk anymore? My wife's 2010 Clubman has Auto, Off, Parking, and Headlights in that order. Is there no off setting anymore?
Old Feb 23, 2011 | 04:13 AM
GeoffreyM's Avatar
GeoffreyM
There is but the new setting for DRL is the small light above the Fog and Headlights on, so if you have this option selected, even in the off position they are on.
Old Feb 23, 2011 | 05:05 AM
Sealy's Avatar
Sealy
Sounds like we're mixing apples and (pure) oranges. These two systems should be separate. If you have DRL active, yes - your lights will be on at all times at a reduced wattage. If you have your light switch set to AUTO - your lights will come on or to full power when it gets dark. If you do not want AUTO, don't use it. If you don't want DRL, that's another setting change - that the mfg usually makes difficult to keep you from fiddling with it.
Old Feb 23, 2011 | 06:11 AM
GeoffreyM's Avatar
GeoffreyM
I agree. I also think there should be more choices, they certainly have the computer to do it. I want to have the running lights just above the fogs on as DRL's and not the headlights. I also want the ease of the the Auto function. Unfortunately you cant have both. Hurry up and wait!
Old Feb 23, 2011 | 06:21 AM
Sealy's Avatar
Sealy
I also think there should be more . . . I want . . . I also want . . . !
And people in Cottage City want a Pure Red that's red. Life is all about compromises.
Old Feb 23, 2011 | 06:28 AM
MINILLA's Avatar
MINILLA
Leave 'em on...it's safer!
Alkaidovich
Jan 30, 2021 01:35 AM
AZN Optics
Aug 16, 2015 11:52 PM
massmini03
Aug 12, 2015 11:19 AM
oldkid6
Aug 11, 2015 08:13 PM
jrezzo
Aug 9, 2015 10:32 PM
