R60 Air filter question
Old Dec 11, 2010 | 04:57 AM
mattmed03's Avatar
mattmed03
Air filter question
For those of you that already are lucky enough to have your new baby...
I have an alta foam air filter in my r55 cooper s clubman. Is the air filter the in the countryman same size as th r55/56? If so I need to pick up a new paper filter before I sell Ziggy.
R60 in production (in assembly!)
Scheduled to be completed 12/13
ALL4 S
True blu with black roof and 18 inch black wheels
Mini navi / connected
Polar beige leather
Every other available option/toy/gadget
Old Dec 11, 2010 | 11:24 AM
FiremanMike's Avatar
FiremanMike
No direct answer as I am not familiar with the R55 filter HOWEVER here is a pix of the filter box of the R60. Too many screws to remove just yet. If you can tell from this, your welcome!
Old Dec 11, 2010 | 11:44 AM
mattmed03's Avatar
mattmed03
thanks
it sure does look identical as far as the airbox is concerned. hope you have some torx bits!
Old Dec 11, 2010 | 02:42 PM
MINIxB's Avatar
MINIxB
It should be about the same engine as what's in the MCS Clubbie.
Old Dec 20, 2010 | 04:07 AM
ALIENLOVE's Avatar
ALIENLOVE
I have ALTA CAI which I took out from my R56 and planning to put it on my Countyrman ALL4 do you think it would suit?
Old Dec 20, 2010 | 08:00 AM
mattmed03's Avatar
mattmed03
In theory.
it should work. Assuming the engineers haven't change tube lengths, fastener locations, etc. But what do i know...my countryman is getting snowed on in the port at Bremerhaven!
Old Dec 20, 2010 | 02:43 PM
ALIENLOVE's Avatar
ALIENLOVE
Hope you receive it soonest, mine will arrive hopefully end of March as per the dealers last:(
Old Sep 8, 2015 | 07:08 AM
shark715's Avatar
shark715
My dealer is claiming that my Countryman All4 needs a new engine air filter at only 43k miles. If I'm reading my service booklet correctly, it's not needed until the 5th oil change, so I'm a bit suspicious.
What I'm even more suspicious about is the price they quoted, $105. When the girl in their service department quoted me the price, I got the distinct feeling she was embarrassed to be asking that much. I looked at realoem.com, and it looks like the msrp on the filter is $19.24. Am I correct in assuming the air filter could not be easier to replace (I'm looking at the pic in post #2 above) and that a $75-$80 labor charge to replace the filter is just plain silly?
Old Sep 8, 2015 | 07:24 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Pretty simple to replace, takes a few minutes!
Old Sep 8, 2015 | 07:31 PM
Benibiker's Avatar
Benibiker
43K?! I always changed mine every 10K just because. Very simple to change, they must be quoting you labor. They cost $36 at Mini/BMW.
It is the same filter as the R56 2007-2013, same engine, same filter housing.
Old Sep 8, 2015 | 09:56 PM
bleonard1401's Avatar
bleonard1401
Sheesh! For ~$80, you can get an aFe Pro Dry S drop in filter replacement. Lifetime warranty, no oiling = no oil buildup on the MAF sensor. Works better than most of the aftermarket cold air intakes out there because it allows you to take advantage of the already in place snorkel intake.
HaveATank
Sep 4, 2015 08:04 AM
theblackfalcon
Aug 26, 2015 09:18 AM
HaveATank
Aug 24, 2015 10:26 AM
polotska
Aug 23, 2015 09:10 AM
Aug 21, 2015 08:44 AM
