R60 replacement speaker under seat
Old Jul 5, 2013 | 11:51 AM
hotknife's Avatar
hotknife
Guys,
next week my CM will have a "date" to fix the new speakers. They will only replace the speakers, there will be no add. crossover and amp. So today or tomorrow I`ve to order the
Hertz ECX-100 or the Focal ISC (still do not know which one)
What about also replacing the speakers under the front seats. I`ve found some photos of those 6.5" speakers. Does anybody have an idea what kind of speaker will fit? I think the replacement speakers have to be very slim because of the plastic body placed in.
Below some photos I found, first the original speakers (door speaker and under seat speakers, than the replacement speakers from German Maestro (I do not know the size of them).
So any suggestions regarding the speakers under the seats?
Take care
Old Jul 5, 2013 | 02:46 PM
fkelly5's Avatar
fkelly5
It is my understanding that the speakers under the front seat are subwoofers. The speakers in doors play the highs and mids and the under seat provides the bass.
Old Jul 5, 2013 | 11:45 PM
hotknife's Avatar
hotknife
fkelly5,
yes you are right.
What do you think about replacing the stock woofer for better ones like e.g.
http://www.hertzaudiovideo.com/Doc/h...65L.5_tech.pdf
Take care
Old Aug 20, 2013 | 09:25 AM
Rai1gun's Avatar
Rai1gun
I'll chime in on this, considering doing the same.
This is my CMS stereo install so far, and very happy with it.
https://www.northamericanmotoring.co...adapter-2.html
That being said, relying on 4" drivers to carry 75-100 watts RMS 150Hz-20kHz is asking a lot. Replacing the woofers under the seats and letting them handle 100Hz-400Hz would be great!
What I would really like to know is how the stock system is handling the crossover between the front door speakers and the seat subs. Are they wired in parallel or is there a passive crossover somewhere? I just disconnected the seat subs when I replaced the 4 door speakers.
If I could be very comfortable about how to remove the seat sub enclosures and what drivers to replace the stock ones with, I'd add a 2CH amp fed from my P-DSP, and run a true 3-way active crossover setup. Removing the seats is pretty easy, so that's not going to stop me.
I think the drivers are 6.5". Maybe just use a quality JL audio woofer that would fit?
http://www.crutchfield.com/p_136XD20....html?tp=35757
http://www.crutchfield.com/S-mrdQ0aF...-C5-650cw.html
Old Aug 20, 2013 | 09:58 AM
hotknife's Avatar
hotknife
Have placed the German Maestro Kick A Woofer under both seats "powered" by a Mosconi Gladen One 60.4 amp.
http://www.german-maestro.de/US/sw6509.htm
Old Aug 20, 2013 | 10:05 AM
Rai1gun's Avatar
Rai1gun
How does the sub enclosure come out? It wasn't obvious when I disconnected them.
Did you seal off the enclosure or leave it ported? Pics make it look like it's ported.
What freq band are you sending to them? What do you have in your doors?
Old Aug 20, 2013 | 10:39 AM
hotknife's Avatar
hotknife
Rai1gun,
pleas check
https://www.northamericanmotoring.co...ml#post3795937
Channel 1 + 2 amp front door left + right
Channel 3 + 4 amp kick a woofer under seat
Withount connection to the amp (rear filler) back door coax 4"
phase shift off
xover on
lp rear on
level rear on
channel mode 4ch
hp on 150-200hz
FSA on
level front high
Mosconi amp does not need any remote
Tapped the original radio cable and connected them with the amp (my local shop did it, because I`m a truly "white collar guy).
Old Aug 20, 2013 | 11:07 AM
Rai1gun's Avatar
Rai1gun
Very nice install! I think the best part may be that you stayed out of your trunk entirely, no sub or amp back there.
I'll do the seat subs and amp soon, and then upgrade front doors / dynamat down the road. Door panel resonance is an issue, as well as road noise---when you are into a project like this, at this point.
I'm still not clear on the removal of those sub enclosures. I'd alread read the 'cut out' bit, and that concerns me. Can you elaborate on how those came out?
Old Aug 25, 2013 | 02:26 PM
Rai1gun's Avatar
Rai1gun
I pulled my passenger seat out again for more sub enclosure recon. Some pics:
The enclosure came out pretty easily. It's only held in place by two bolts (you'll see them) and where the port butts into a duct cutover at the base of the door pillar. The driver itself is down firing.
The cavity the enclosure sits in is fairly cavernous. It might be possible with a custom enclosure to get an 8" driver in, as well as a small amp and crossover if needed. Ventilation might be an issue, however.
Old Sep 7, 2013 | 08:30 AM
Rai1gun's Avatar
Rai1gun
I'm building custom enclosures out of 3/4" MDF, foam and Dynamat. Dropping in these. Will post with photos and results.
Peerless SLS 6.5" 4 Ohms ($56 each, hefty HQ driver for the price!) powered by a JL audio XD200/2 75 watts RMS (also under drivers seat)
Will band pass them ~80-250Hz I think. Mid-bass to supplement the 4" coaxial Focals in the doors.
Old Sep 22, 2014 | 12:01 PM
GregoryK's Avatar
GregoryK
Hey Guys. Did you check this out as a simple solution.
This I believe is a specific replacement...
http://www.crutchfield.com/S-h9IqrL1...IFBMW-SUB.html
Old Sep 22, 2014 | 12:56 PM
mikey_t's Avatar
mikey_t
You do realize this thread is a year old right?
Old Oct 1, 2014 | 03:29 AM
atoy74's Avatar
atoy74
Exactly. Can anyone who's tackled this project chime in? I'm about to upgrade my sound system and would love an elegant solution.
Old Sep 9, 2015 | 10:45 AM
osinkboy's Avatar
osinkboy
Any update on this old thread?
Was anyone able to find a good easy solution?
theblackfalcon
Oct 11, 2015 09:49 AM
jnrjr79
Navigation/Audio
18
Sep 18, 2015 05:51 AM
Mini'mon
Aug 26, 2015 01:02 PM
Powershift
Aug 16, 2015 05:14 PM
DWooderson
Aug 10, 2015 09:12 AM
